Old 08-12-2019, 11:57 AM #181
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
291565 miles
Replaced driver side axle with junkyard spare axle I snagged at 40% off last month. That should keep the seal from leaking until I replace the wheel bearings. Cleaning up the wheel and brake shoes/drum was the most time consuming part of it.
Need to top off gear oil
Waxed the hood after hitting it with rubbing compound. Paint on the hood is pretty badly oxidized...
Topped off crankcase oil. Next oil change in 8.5K miles
Pics to follow
Sent from my Pixel XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 08-25-2019, 05:34 PM #182
292312
AC started smelling musty so I decided to clean it from the evap core. Bought a can of Klima-Cleaner Air Conditioner Cleaner and following the instructions removed my blower motor/fan to spray into evap core.
Removing the blower motor housing was really straight forward.
I didn't take pics but here are the steps:
1. remove the plastic floor trim by passenger door, 4 phillips screws
2. remove the plastic passenger kick panel trim, pull towards rear of vehicle
3. remove blower motor, 3 torx 25 screws
4. unclip power cable from the motor
There wasn't too much leaf debris in the cage fan, but the fan blades were dirty af, so much crud came out I decides to remove the cage from the motor to really clean it. This was not super easy, but not hard either.
Again no pics but here are the steps:
1. be careful, the cage fan may be brittle; it's 20 years old
2. remove the spring clip with pliers
3. there is a plastic locking tab opposite the flat of the motor shaft, gently pry it away with something thin a sharp. I used the blade of a micro screwdriver
4. OPTIONAL apply some penetrating oil to motor shaft and let it wick down between the plastic and the metal
5. PROBABLY NOT OPTIONAL use a heat gun on low or a hair dryer to warm up the plastic round the motor shaft
6. GENTLY, pry the fan cage off the shaft making sure to keep the locking tab back until it clears the groove in the motor shaft
Once the cage fan was off, I washed it in the sink and scrubbed the blades with an old paintbrush to remove debris. So much fine dust came of the fan it stained the sink. I hung the fan to dry and cleaned the dirt and dust off the motor and gently blew it clean with air. Be careful not to blow the dirt INTO the motor armature.
Then I went back to the car and applied the Kilma per the instructions on the can.
The Kilma comes with two caps, a red on with a short nozzle and a white one with a long tube attached. I used both, but I added a coffee stirrer straw to the red cap to reach the core from the blower motor housing opening more easily.
If you reach into the blower motor housing with the blower motor and fan removed you can feel the core about 2-3" in from the opening. I made sure to poke the straw applicator I made right up against the core in several spots while spraying being careful not to damage the core fins. The foam will back out into the housing before melting. Don't over spray, rather wait for the foam to melt, then spray more. Spray about half the can into the core from the blower motor side.
NB - put a double or triple-folded towel on the floor of the car to catch any foam or liquid cleaner that may drip into the car, it will be dirty and can stain your carpet.
I then removed the red cap from the Kilma and installed the white cap. Here is where my extended AC drain mod comes in handy.
I snaked the white tube that came with the Kilma up my AC drain hose, right up to the factory aluminum drain fitting. There is no need to push the spray hose into the aluminum fitting, it won't make the turn easily and the AC core is literally right behind it, getting the tube up to it is enough. I then filled the core housing, from the back side with the second half of the can and waited the 20 minutes per the instructions on the cam, using this time to start reassembling the blower, etc.
This is where the towel on the floor of the car comes in handy. I took paper towels and soaked up the melted foam cleaner from the inside of the blower motor housing, not by the core but where the screws go in to hold the motor to the housing. I used the melted, liquid cleaner and paper towels to wipe wipe the dust of the inside of the housing where the fan blades fling it, and any dirty cleaner that leaked out hit the towel rather than the carpet.
When everything looked good, I reinstalled the blower motor/cage fan assembly, connected the power and started the car to run the AC per the Kilma instructions.
I put a drip tray under my AC drain hose under the car and opened the windows, running the car with the AC on for about 15 minutes while standing outside to avoid the strong chemical smell of the Kilma. Running the AC for a while is required to evaporate all the excess cleaner out of the evaporator core, housing, etc.
Once the chemical smell was mostly gone I shut down the car and emptied the drip tray. The liquid in it wasn't super dirty, it was kinda grey in color, probably because I cleaned a lot of the crud off the fan blades before spraying the cleaner, but I've seen videos of black liquid draining out, which you don’t want on your garage floor or driveway or anything else you care about or you'll be doing more cleaning.
Well, that's it. That's the post.
I didn't take pics as I worked because my hands were dirty and the phone was upstairs but I'm sure there are a ton of pics on the internet or elsewhere on the forum.
All tolled, not including the Extended AC Drain mod (done about a year ago) it took me about an hour or so, probably more, and hopefully will be worth it, meaning the moldy smell doesn't come back in a few weeks.
Old 08-26-2019, 12:55 PM #183
phattyduck phattyduck is online now
Turn your AC off a few minutes before you get to your destination... and it will never come back. Basically, you need to dry it before stopping the car for long periods of time. It will, however, get dirty again.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
Old 08-28-2019, 10:27 PM #184
Yessir, I do that. AC off, fan on, let it blow for a few mins, shut er down.
Only got moldy smelling this year.
Old 02-02-2020, 01:35 PM #185
300,000
Pulled over on the way up to our winter camp site to snap this pic.
Planned maintenance at 300K:
-oil and filter change
-oil filter relocation
-timing belt and all associated chingaderas
-LBJs
Good thing I got a company car last week, the T4R is no longer my daily
Also, need to clean my MAF sensor and replace the air filter element.
Old 02-02-2020, 05:32 PM #186
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
Glad to hear you're still rolling strong in your rig man. 300k wow.
Just curious though... what campsite/where?
Post some pics!
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 10:28 PM #187
Post some pics!
El Capitan Canyon lol not quite dry camping
How you been?
Old 10-12-2020, 10:34 PM #188
303,751K
Replace battery and ultimately the starter after intermittent but worsening troubles. Bad starter sapped the battery until the starter finally gave up the ghost.
Here's the post on the starter issue.
Long story short, gasket on the starter failed, starter looks like it corroded from the inside out, speeding wear on the contacts until the starter itself failed to reliably start.
Had I been driving the 4runner daily the issue would have probably played itself out differently, but it is what it is.
I ended up replacing the starter with an Amazon aftermarket but will look for a factory unit to rebuild and keep on the shelf.
Next projects carry over:
-LBJs
-timing belt (and all the fixins)
Tough to justify all that work/time when I actually hardly drive the 4runner anymore, but I wanna keep her running
Old 10-13-2020, 10:15 PM #189
habanero's Avatar
habanero habanero is offline
Real Name: Throws like a girl
habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light
habanero's Avatar
Oil filter relocation....oh heck yes. Never done it, but every oil change I can smell the brain cells rubbing together- or maybe that's just all the drippy oil.
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R View Post
I know this is a weird ass question but do you shave your legs or something?
habanero is offline   Reply With QuoteReply With Quote
Old 10-14-2020, 01:09 PM #190
Fumoto valve with a small hose on it to get below the skid plate and a form-a-funnel under the oil filter keeps it (mostly) clean:
Though I am still down with the oil-filter relocation cause!
Old 10-14-2020, 07:29 PM #191
habanero's Avatar
habanero's Avatar
My husband has a Fumoto on his 4Runner and really likes it.
Maybe I'll have to bite the bullet on one of those form-a-funnels at some point. Better than the veggie oil bottle with the butt cut off that I use now, surely.
Old 10-14-2020, 08:56 PM #192
I, too, have a fumoto valve. Man those oil changes are easy. The filter relo will only help.
Stay tuned, kids
Sent from my Pixel 4 XL using Tapatalk
Old 10-14-2020, 09:40 PM #193
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The only issue with the filler relocation is the quality of the parts. My 2009 Tocuma came with the oil filter relocation from the dealer. I haven't had an issue with it.
However I have heard nightmare stories from people putting them on and failing. So I am sure some folks realize this can be an issue. I have no idea who mfg the one on my Tocuma but it would be a great one for the folks wanting to add one on a 3rd gen.
Old 10-14-2020, 11:09 PM #194
mattciampa93 mattciampa93 is offline
mattciampa93 is on a distinguished road
Inspiring thread! Just got a 4Runner with similar miles and want to keep it going.
mattciampa93 is offline   Reply With QuoteReply With Quote
Old 10-15-2020, 08:23 AM #195
Pics of your relo kit installed?
