Old 05-21-2018, 11:00 AM #1
richamc01's Avatar
richamc01 richamc01 is offline
Real Name: Dick
richamc01 is on a distinguished road
richamc01's Avatar
Real Name: Dick
Exclamation Excessive front end bounce after lift install
I have tried searching and I cannot find the answer to my question. It seems as though most people have rear end bounce. My problem is in the front.
I just finished installing a 3" lift on my 99 T4R yesterday. I have not gotten an alignment just yet as I was hoping to figure out this issue first to avoid having to get another alignment afterward. I installed the following parts:
Front:
Bilstein 24-248730 (https://wheelersoffroad.com/i-308578...tegory:1388356)
Toytec 112-620 (https://wheelersoffroad.com/i-254903...tegory:1346101)
Front Dif Drop TT TAC-DR (https://wheelersoffroad.com/i-254903...ra-tac-dr.html)
Front anti-sway kit WHE 4RUNSWYKIT (https://wheelersoffroad.com/i-254903...runswykit.html)
Longer Sway Bar end links for REAR 99 T4R (https://www.rockauto.com/en/moreinfo...046&cc=1357455)
Rear:
Bilstein 5100 long travel 9602E703 (https://bilsteinlifts.com/shop/toyot...oyota-4runner/)
LC 8 wrap coils
Rear Bump Stop Drop Kit TT RM43010-TTL (https://wheelersoffroad.com/i-254903...43010-ttl.html)
Rear anti-sway Kit PTHANE 18-1116-BL (https://wheelersoffroad.com/i-254901...8-1116-bl.html)
Longer Sway Bar end links for FRONT of 95 T4R (https://www.rockauto.com/en/moreinfo...328&cc=1272529)
I installed everything at my buddy's house and he lives about 30 minutes away from me. When we were finished, I drove home and I noticed an excessive bounce in the front end. It doesn't matter what speed I am going. It rides as though it is sitting on the front coils with no shocks. I set the front coil clip on the 3rd notch up. These shocks are the 4Runner specific Bilsteins, not the Tundra shocks.
I have not taken measurements just yet to see just how much lift was gained but the front does site pretty level with the 8 wraps in the rear.
Here are some pics: I did not take a ton of pics as these were taken before and during the install and I did not know I had the problem yet. I will take more and upload.
Excessive front end bounce after lift install-20180511_214109377_ios-jpg  Excessive front end bounce after lift install-20180511_214040158_ios-jpg  Excessive front end bounce after lift install-2-jpg  Excessive front end bounce after lift install-1-jpg
richamc01 is offline   Reply With QuoteReply With Quote
Old 05-21-2018, 12:20 PM #2
ColoRAD's Avatar
ColoRAD ColoRAD is offline
ColoRAD is on a distinguished road
ColoRAD's Avatar
Pretty sure you have the Bilstein's cranked too high, with a 3" coil they should be on the bottom perch per ToyTec's website.
ColoRAD is offline   Reply With QuoteReply With Quote
Old 05-21-2018, 12:22 PM #3
richamc01's Avatar
Real Name: Dick
richamc01's Avatar
Real Name: Dick
I guess that makes sense. I was thinking the clip is what set the ride height. But it would make sense that the coil would.
Old 05-21-2018, 12:29 PM #4
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
I opted for the Tundra billies with those coils (24-248730) and I installed them on the bottom notch and have no bounce.
Question: what shock cushions/bushings are you running above and below the top plate?
IIRC the bilstiens only come with one shock bushing (unless wheelers bundles bushings with the shocks they sell)
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 05-21-2018, 12:43 PM #5
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
If you're front is level with 8 wraps then you've answered your own question. You need a plate bumper & winch to be on the 3rd perch.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 05-21-2018, 12:45 PM #6
richamc01's Avatar
Real Name: Dick
richamc01's Avatar
Real Name: Dick
Got it. Changing the clip now. I’ll report back and hopefully close this thread.
Old 05-21-2018, 02:08 PM #7
richamc01's Avatar
Real Name: Dick
richamc01's Avatar
Real Name: Dick
Clips changed. Test driving now to get an alignment.
Old 05-21-2018, 02:41 PM #8
richamc01's Avatar
Real Name: Dick
richamc01's Avatar
Real Name: Dick
Rides like a dream now. Thank you everyone for your assistance. It’s crazy how much of a difference moving that clip down an inch and a half makes!
bilstein 5100 , bounce , help needed , lc 8 wraps , lift
Is it possible to install front Daystar b.k. lift.... benztech82 4th Gen T4Rs 3 08-12-2017 08:05 AM
Rear end bounce, bounce, Please comment Madizmz 3rd gen T4Rs 19 01-12-2014 02:47 PM
just got a 99 4x2 auto 4 cyl - highway speed SHAKE and front end bounce brostar 3rd gen T4Rs 5 03-22-2009 01:17 PM
Front Pass Side Wheel Excessive Play - (pix) californiak 3rd gen T4Rs 4 08-21-2007 05:42 PM
