I'm hoping there's an easy way to do this that I'm missing.
I'm at a loss on how to compress the 700lb coil springs for the front coilovers. I unfortunately didn't know I'd need them at the time, and just ordered with the standard springs.
There's so little clearance between the coils and shock body that regular spring compressors don't fit (can only fit one side, not one on each side to balance it), and the difference in OAL is +1" for the heavier springs, which doesn't let you just pop them in with the collar all the way loose.
What's the trick here?
