01-09-2019, 10:49 PM
How the hell did I lose 2" of ride height?
I have an OME lift 3" all around(3 yrs old roughly) with medium coils in front. Had the heavy shocks in the rear but swapped to Bilsteins about a year in. 4xInnovations bumpers front and rear, but no winch yet- going to upgrade front this spring to handle the extra weight.
I recently tried to get an alignment at a buddies shop, but he called and said the LCA bolts were frozen and he needed to cut them off and replace the control arms. I said ok fine, he wouldn't BS me, I've known him my whole life, right? So he swaps them, aligns the front and rotates the tires. Over a grand in work. When I pick up my truck, he tells me there is some nasty tire rub(235/85/16) on the driver side and I should probably pull the lower bolt on my fender flares to avoid tire damage.
Strange, I had zero rub for the first 15k miles on the new tires...
Sure enough I drive out of there and there's some awful rubbing close to full lock, but after removing the bolt and hammering the pinch weld its still there. Starting to tear into my fender flares now. Tonight at the car wash I notice the front tires seem pretty tucked into the wheel wells compared to the rear. So FINALLY I break out the tape and my rear is still at 37" to top of the fenders, but the fronts are at 35".
The shop obviously f*cked something up, but what the hell could cause a drop of two inches?
'02 SR5
"Gas pedal's on the right.'
~Logan
01-10-2019, 02:13 AM
Real Name: Keith
Real Name: Keith
He used the standard stock parts?
01-10-2019, 08:41 AM
I'm intrigued to hear the end of this...
I'm also intrigued with how you could've left the shop without first visually noticing the 2" difference in height or notice the rake when driving.
01-10-2019, 09:16 AM
Did you have hockey puck lift spacers above struts that were eliminated on reassembly?
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
01-10-2019, 09:19 AM
It does seem like some spacers where removed but that should only be about an inch lost.
01-10-2019, 01:47 PM
You shouldn't have rubbing issue with that tire size. You'll want to get more caster put in the alignment to move the wheels forward.
As for the height issue... measure from the center of the hub to the fender lip to get ride of tire size issues. What are you getting?
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
01-10-2019, 03:03 PM
Doesn't 1" spacer equal about 2" lift?
_________
01-10-2019, 05:20 PM
If the spacer is in the coil than yea but not if sitting on top I don't think.
01-10-2019, 10:26 PM
Rear is 22", front is 20".
No spacers, just the OME 3" lift. Which technically was 2.5 front and 3 rear but mine measured 3" at all 4 corners when completed.
Just didnt pay enough attention to why that bolt was rubbing when it never had before. I thought it looked a little low but just didnt put it together, probably have too much else going on. Not great on my part!
'02 SR5
~Logan
01-10-2019, 10:37 PM
Do you have the OME 883 coils designed for 200lb extra weight?
01-10-2019, 10:46 PM
No, after talking with Toytec they assured me I needed to go regular coils for just the steel bumper, then upgrade to the heavy coils when I add a winch.
'02 SR5
~Logan
01-10-2019, 10:55 PM
Well standard 880 coils give 1.5" lift. 881s are standard weight give 2" lift and 3"with spacers. . 883s are the heavy coils that give 3" lift but are super stiff without weight. So if your running standard coils without spacers 2" lift is all you would net.
01-10-2019, 10:59 PM
Yeah the 881s were advertised to give 2.5" but after lifting my measurements were 3". But even if I measured wrong I still lost 1.5" of lift after the new LCAs were installed. And those OME shocks didnt come with spacers.
'02 SR5
~Logan
01-10-2019, 11:02 PM
Post up a side pic. I got 3" on 881s and toytec spacers. Added winch with steel line and bumper and sit around 2.5". And that's on a 96 that sits the lowest stock of them all.
Who installed the lift 1st time around. I don't see how you can loose that much left with just changing the lcas
01-11-2019, 03:08 PM
Oh boy! Your front is at "stock" ride height and the rear has a 2" lift. Something is up.
Can you post a picture of the front coils/shocks? (turn the front wheel to get a pic of the whole setup)
