Old 01-24-2019, 05:07 PM #1
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Awning mounted to OEM rack?
Just wanted to see if anyone mounts these to oem roof racks.. I eventually want an aftermarket roof rack but I need an awning for the wife and soon to be little one sooner than later. I was looking at the ARB 2500x2500 but I think it might be a bit too long for the oem rack to handle so I was also looking at the ARB 2000x2500.. was also thinking about getting the deluxe room attachment as well and using it as a tent/changing room.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 01-25-2019, 03:31 AM #2
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
As you likely know, I can't help directly from experience, but I thought I saw an ARB awning on a 3rd gen, with the factory rack. I believe it was here, but the images are down.
ARB Awning Install: 3rd Gen 4Runner w / Stock Roof Rack | Expedition Portal
So, doable, and seemingly worked well...
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 01-25-2019, 03:24 PM #3
T4topher's Avatar
T4topher's Avatar
Nice find! It’s too bad it won’t load the pictures, sounds like he came up with a pretty simple/effective way of mounting it. I’ll have to try and visualize what he is talking about. Sounds like he went with the 2000x2500 awning.. I’m just worried that won’t be big enough.. wish I could see all the sizes in person before I made the decision..
Old 01-25-2019, 03:28 PM #4
TonyB66's Avatar
TonyB66's Avatar
Maybe worth joining that forum to contact that poster? Since it seems it's doable alright, and can be done nicely, maybe just get one, and figure it out. You do nice work, so I'd bet you do a great job!
Old 01-25-2019, 03:37 PM #5
T4topher's Avatar
T4topher's Avatar
I saw someone had tried contacting him at the end of that thread. It’s almost 10 years old so I don’t expect him to be active anymore haha.. just from his description though I think I can figure out how he did it. I guess what I’m really trying to figure out is wether to get the 2500 or the 2000 (8’ wide vs 6’ wide).. I’d prefer the 2500 since it’s a 10-20$ cost difference but it would suck to find out I need a full length rack to mount it securely. Thanks for believing in me! Lol
Old 01-25-2019, 04:00 PM #6
TonyB66's Avatar
TonyB66's Avatar
I imagine people here have those two ARB offerings. If so, some measurements and photos might go a long way for you in determining which one to get... If sold locally, maybe worth a trip.
Old 01-25-2019, 04:43 PM #7
hoksibish hoksibish is offline
hoksibish is on a distinguished road
I have a knock off awning and i just drilled 4 holes through the bars and added washers top and bottom. I have had no issues with it since i put it up there several months go.
hoksibish is offline   Reply With QuoteReply With Quote
Old 01-25-2019, 05:03 PM #8
T4topher's Avatar
T4topher's Avatar
Nice! That looks great! Is that one about 8’ long? I’m not opposed to drilling holes in the crossbars at all.
Old 01-26-2019, 12:04 AM #9
Thank you. Drilling made quick work of it till i can get a proper rack. Yes its the 8' one.
Old 06-08-2021, 01:14 PM #10
Junrein Junrein is offline
Junrein is on a distinguished road
Do you have the link for the awning you got? Also, did it come with the brackets and hardware?
Junrein is offline   Reply With QuoteReply With Quote
Old 06-08-2021, 07:05 PM #11
4runnerfiend's Avatar
4runnerfiend 4runnerfiend is offline
4runnerfiend has a spectacular aura about 4runnerfiend has a spectacular aura about
if you take the Load bars off. un screw and remove the ends you can take the rubber out and there is a channel that you can use to slide a t bolt into and mount those simple L brackets on.
I used an piece that I had left over from a RTT mounting system. flat aluminum piece that had a little indent for holding the bolt head from spinning.
I then trimmed the rubber to fit.
IMG_0518 by chauncy333, on Flickr
IG: @4runnerfiend- 1999 SR5: TRD Supercharger, ELocker, Wheelers T1 Coils-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, Savage skids, Hot Metal Fab Front Tube bumper, Savage Rear tube bumper, TruckShopSD Sliders, DuroBumps, RidgeGrapplers, Doug Thorley Headers, yellow top, XRC 12k, ARB single compressor.
4runnerfiend is offline   Reply With QuoteReply With Quote
Old 08-05-2021, 10:31 PM #12
pdubskee's Avatar
pdubskee pdubskee is offline
pdubskee is on a distinguished road
pdubskee's Avatar
Thumbs up
this is what ive been looking for just ordered the napa awning , lets see how it will hold up !
2000 4Runner Limited -4wd- E-locker
pdubskee is offline   Reply With QuoteReply With Quote
Old 08-05-2021, 10:34 PM #13
pdubskee's Avatar
pdubskee's Avatar
What size t bolts did you use?
Old 08-06-2021, 04:23 PM #14
I actually made my own out of spare parts I had from a roof top tent. They were the aluminum channel slide guys... (don't know what they are called.) had to grind them down to make them fit. nice part is they have a notch that holds the bolt head from spinning.
arb , awning , oem , rack , room
FS: K9 Roof Rack, Shade Awning NJ Cde1218 For Sale: T4R Items 4 04-25-2018 01:54 PM
Looking for rack and awning suggestions SLang925 5th gen T4Rs 2 02-16-2017 12:26 AM
3/4 roof rack awning kolelt 3rd gen T4Rs 4 08-29-2016 09:55 PM
Awning mounted to Sport rack? swanny 4th Gen T4Rs 1 03-01-2016 06:51 PM
Awning to stock rack blight1234 4th Gen T4Rs 4 06-11-2014 08:23 PM
