Old 11-03-2019, 10:40 PM #61
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
fun thread. and bleh, black hands from dander, oil and dirt. that looks like our door molding from when the cats rub on them.
a couple posts up you mentioned descaling. do you hit it with a wire brush, clean it to the point it's bare metal, then hit it with undercoat? i'd be interested to hear the highlights of the procedure you use. i've read some comparisons across several brands and POR and picklex seem to be well-regarded for prep. thanks
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 11-03-2019, 11:04 PM #62
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
It's really just minor spotty scaly surface rust throughout the frame and undercarriage. It's not too bad just worse than the perfectly rust free frames I'm used to. I'll just be tackling it mostly with 4" wire brush cups on an angle grinder and covering with 3M professional undercoating since I still have most of a case of it left.
I'm not too concerned about rust prevention necessarily because as long as you don't let the loamy soil stay caked in places where it stays moist there isn't really anything around here that causes rust. The trucks only rusty from spending some time back east in PA.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 01:45 AM #63
UnderFire's Avatar
UnderFire's Avatar
Welp, it's decided. Custom bumpers it is. As much as I'd like the look of chrome bumpers for that OE clean-Ness, I know in the end that just isn't gonna cut it. I've never been that enamored with any stock-ish truck and it's gonna end up being a waste when I get tired of it.
Tonight was the night, bye-bye f'd up stock bumper, for good.
This illustrates an important piece of information for anybody looking at a truck that's collected any amount of surface rust. It's the places you can't see that are gonna be the worst. Rust is kind of like mice. If you're seeing it out in the open, there's a far bigger problem hiding where you'd never know.
The inside of the rear of the frame rails are super crusty, the support pieces that are welded in for the rear tow points are actually eaten through in fact, and there is nearly nothing left of their Threaded inserts. Luckily I was able to carefully tighten 3 of those 4 bolts into place and save the brackets given with the aftermarket hitch. Nothing unsalvagable, but it'll take some work.
Long story short I weight reduced everything that wasn't welded on and did a little grinding to flip the aftermarket (curt) hitch over and slapped some new hardware on to hold it.
This will be the base for a tube bumper build over the course of the near future. I know exactly how I want to build it, just not exactly how to attach it to what's already there. I'll have to wait for my "A-ha" moment then I'll be building, probably slowly because I'm lazy.
Old 11-04-2019, 09:18 AM #64
apohl17's Avatar
apohl17 apohl17 is offline
Real Name: The Native Explorer
apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light apohl17 is a glorious beacon of light
apohl17's Avatar
Just read through this - I'm always stoked to see revival threads like this. Keep on keepin' on - can't wait to see your depiction of the ideal tube bumpers
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
apohl17 is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 11:44 AM #65
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Great Job @UnderFire . I basically do the same thing and been restoring since the 90s. All but One I paid $500 or less for. Mostly in my area. Its rusted out frames. I found better ways to fix them over the years and now moving into the Autobody side of things. I do it just to improve my skills and it's my hobby.
There is nothing like looking at completely rotted out frame and seeing the photos after restoration.
Its truly a shame we become a throw away society though. Are grandparents would be turning over in their graves as they were depression era kids and adults. Nothing would be thrown away and everything would be reused and recycled.
Oh well keep up the good work. I know with my fleet of 5. I will probably sell a few of mine off once they are completely rebuilt and partially restored. :]
Old 11-04-2019, 11:03 PM #66
Rolling_Thunder Rolling_Thunder is offline
Rolling_Thunder is on a distinguished road
So the chrome mirrors are from a 98-02 Tacoma I imagine?
Rolling_Thunder is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 11:10 PM #67
UnderFire's Avatar
UnderFire's Avatar
01-04 Limited spec, might've also been on earlier models, I've worked on a 99 limited Tacoma but don't remember if it did.
Old 11-05-2019, 03:21 AM #68
UnderFire's Avatar
UnderFire's Avatar
I'm really glad I don't live in the rust belt. If there's one thing I hate more than anything it's laying under crusty vehicles grinding away with all the dirt and junk falling on me. No bueno. Couple that with bolts snapping off left and right and I gotta say Major props to you, if it wasn't for the usually spotless frames here that bolts wind right out of, I just plain wouldn't do it.
Old 11-05-2019, 03:29 AM #69
UnderFire's Avatar
UnderFire's Avatar
Well, took me all of a day to decide that the hitch as-is wasn't gonna cut it. Angled round tubes and the fact that it stuck out so far made it a less than ideal base to build from.
So I busted out my favorite tool, the Sawzall (aka the universal wrench) and sliced the brackets right off. If anyone's wondering what kind of blade you use to slice through 2.5" 1/4" wall tube, I got one word, Lenox. Specifically the Lenox Lazer PowerArc extreme metal blades. They are no joke, second only to the carbide tipped Lazer blades. If you're at the store looking at sawzall blades and wondering why they're so much more expensive, just do it. You won't regret it.
It's at this point that you start to question all the choices you've made in your life that lead to you cutting apart a perfectly good hitch, just to make an objectively less practical hitch out of it.
Once I got the brackets all cleaned up I took a trip out to the steel pile and found the perfect piece. Anyone worried about strength don't be. It's 3x3" 1/4" wall square tube. Perfect fit for the brackets.
I don't typically do a whole lot of welding, but lately I have been. I'm actually surprised at how good of a bead I'm able to lay with the old hot snot machine right now. I'm sure I'll end up taking a six month hiatus and losing my edge before too long.
Too lazy to hunt down the hitch insert tonight and get it notched in so I'll leave it at that.
Old 11-05-2019, 10:42 AM #70
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I can understand that it can be a real PITA at times. However, there isn't any way around it on old neglected rigs. I had to save a few. As 3 of these 5 would have been headed to the scrap yard if I didn't bring them home.
I can see the hitch mod.. Not bad
Old 11-07-2019, 02:51 AM #71
UnderFire's Avatar
UnderFire's Avatar
Well, started tonight by getting the hitch all dialed in. I decided to up the ante a little further even and only half recessed it into the top of the crossmember. It's not just tight to the hatch, it's almost rediculous. Not like I'm gonna be towing with the 4 cylinder runner out of everything though, so I'm going all out, no compromise. Pokes out just far enough to be usable with a clevis adapter. Departure angle maxed out.
Then I had my "A-ha!" moment that I really needed. I know exactly how to mount the main hoops to the crossmember. Started out by spacing a piece of plate up with a couple little pieces of 3x3. This plate will sit on top of my main hoop, another similar piece of plate will tie the bottom of the tube directly back to the hitch crossmember. Should be strong, fairly light and not kill any clearance at all.
Go to bolt it on, Oops the stops for the spare tire are right in the way, blast em off real quick. Remember, no compromise.
Got one side welded up and even had time to bust out the bender and start slinging tube. First off a 90 degree into 3/16 wall. Let me tell you this is not easy to bend. I'm all of 6 feet and 240 lbs and throw tires all day and it kills me just doing a couple bends by hand. This settles that I'm getting the hydraulic conversion. One bend made though.
I ran into what I knew I would, the tube at the bend sticks out a little far for my liking, there's no better way to do it and still protect the hatch , so I'll have to live with it. Should look OK all done though.
And at this point I've decided. A swing out tire carrier is happening. The weld wheels on the runner are sold and I've ordered up a new set of 5 wheels. The lack of a matching spare wheel (and a little tiny bit of my laziness) was all that was keeping me from going with a swing out setup. If I ever want to get welds back on the runner finding 5 matching will suck, but it'll be worth it in the long run.
Mocked up and 2x3 should work perfectly. Steel run tomorrow even though I don't need it just yet. I might go. 1/8 wall tube on the less structural upper hoops and braces though, just to save weight and my back.
Old 11-07-2019, 08:38 AM #72
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Decent homemade hitch. I am curious how it will function for you. I take it your spare tire location will never be used again.
Being how you design this it really should be strong as the new 4 runners have hitches built right into the frame. This of course is all dependent on how good your welds are. ;)
Great job. :]
Old 11-07-2019, 10:44 AM #73
rkntoy's Avatar
rkntoy rkntoy is offline
rkntoy will become famous soon enough
rkntoy's Avatar
Looking good.
Still looking for manual hub spindles?
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
rkntoy is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 02:52 PM #74
UnderFire's Avatar
UnderFire's Avatar
Originally Posted by rkntoy View Post
Looking good.
Planning on stealing all the suspension off my other runner since it's just sitting around waiting for me to swap it onto different running gear, just haven't got that far yet.
Old 11-07-2019, 02:54 PM #75
UnderFire's Avatar
UnderFire's Avatar
Great job. :]
No sir, wouldn't even be able to fit a stock size spare since the hitch goes right through where it would be anyways. It's main function is gonna be holding a d ring mount and I think it'll do that no problem. Welds are about the best I've ever laid, I'm super happy with myself on em.
500$ , bought , interior , miles , scrapyard
I just saved 35k wrpsuite 3rd gen T4Rs 14 12-10-2018 01:48 AM
VSC Saved Me Whiplash Willy 5th gen T4Rs 28 12-28-2013 03:35 AM
Saved my stepdads a$$ gigerunner All Other Vehicles 0 12-08-2013 12:14 PM
Saved By the Nav. Koz Engines / Suspension / Wheels / Tires / Audio / Accessories 6 07-28-2006 08:32 AM
ABS saved my a$$ greentoy 3rd gen T4Rs 6 02-10-2006 05:54 PM
