Old 10-08-2022, 05:20 PM #1
D'arce D'arce is offline
D'arce will become famous soon enough
5spd grenade...
The last couple months I would randomly hear a loud high speed ticking noise that lasted maybe a second. Almost like hitting the starter on a running motor. I got underneath and poked around a couple times, never saw anything and it drove normal so I just kept trucking. Whatever it is finally let go today. Popped back under and saw this. Dang. The cracks almost run the whole right side of the bell housing.
1996 4Runner with a 3rz-fe, e-locker and 5spd
2005 Passat TDI 5spd swapped
1997 E350 4x4 7.3 Powerstroke
D'arce is offline   Reply With QuoteReply With Quote
Old 10-08-2022, 06:11 PM #2
I guess this means I need a new trans since the bell housing looks built in. Maybe a r150 swap? Haven't looked into that yet. Any idea what is sticking out the side?
Old 10-08-2022, 06:54 PM #3
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
The picture looks like its sticking out the side of the bell housing and not the transmission, right? That looks like your clutch grenaded which would mean that you need a new clutch and bell housing.
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 10-08-2022, 07:07 PM #4
Not if the damage is to the bell housing. The bell housing bolts up to the transmission from the inside of the bell housing.
1997 Toyota 4Runner
Old 10-08-2022, 07:32 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Could only need a new bell housing. Was this an aftermarket or oem clutch that scattered?
Old 10-08-2022, 07:38 PM #6
It looks like its all one piece from the outside. Just filthy as hell I guess. Thanks
Old 10-08-2022, 07:39 PM #7
I have never opened it up. With almost 300k I am guessing its not the oem. But it would be just a guess.
Old 10-08-2022, 08:04 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Ah. I would say it was a cheap clutch as to why it scattered. I really doubt an OEM clutch would last 300K miles. I haven't seen one on anything last more then 250K. Unfortunately, you are going to have to pull it out the transmission and access the damages and go from there. I am just hoping its just the bell housing and nothing more. :-)
Old 10-08-2022, 08:24 PM #9
Just doing a quick search theres lots of r150 housings and W58/56 etc but I can't seem to find any W59. I did see where folks have swapped the bellhousing off the 05+ 2trfe manual to get an r150 behind the 3rz. It's neat but doesn't help me much lol.
Old 10-08-2022, 08:59 PM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Maybe you can just have it tigged welded the case back together worst case..
I am sure you can find one somewhere it may take some looking and digging around for a while. :-)
Old 10-08-2022, 11:12 PM #11
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Bell housing bolts to the gearbox section from the inside of the bell housing
Old 10-09-2022, 06:31 AM #12
I was thinking about this just a bit ago. Any idea what aluminum the bell is made from? I took a transfer case in a while back to have a spot welded up and the welder told me it was magnesium, not aluminum. For whatever reason he couldn't weld the magnesium.
Old 10-09-2022, 06:53 AM #13
Any replacement clutch suggestions?
Old 10-09-2022, 09:16 AM #14
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Aisin stock will work fine. That’s what I did for my 3RZ last year.
JZiggy is offline   Reply With QuoteReply With Quote
Old 10-09-2022, 02:03 PM #15
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Aisin is the OEM Mfg and I will only use those Toyota or Marlin Crawler which is a Aisin Mfg clutch...
couple , drove , finally , normal , trucking
Throttle Grenade throttle controller momo.75 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 05-10-2022 12:07 PM
97 3RZ 5SPD 35's DD smacaulay 3rd gen T4Rs 125 10-05-2015 01:01 PM
2nd gen 2wd 5spd? 94yotapj Classic T4Rs 8 06-27-2015 07:16 PM
Grenade Gear Shifter Adventure Copan For Sale: Non-T4R Items 5 04-11-2013 10:03 PM
3.4 5spd MPG 31's vs 32's huhwhye 3rd gen T4Rs 10 12-17-2007 01:13 AM
