Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 02-19-2019, 11:03 PM #1
abw73 abw73 is offline
Junior Member
abw73 is on a distinguished road
Junior Member
Passenger window switch not working independently
2001 SR5
Passenger window will not go up or down unless I press both driver and passenger switch in the same direction at the same time. Basically, both have to be up or down, otherwise it won't work. As soon as I let go of either switch, it quits working.
All other driver panel window switches work fine. Passenger power locks work, just the window switch won't work independently of driver side.
So far I have swapped out the passenger door motor and both driver and passenger switch panels. Problem still exists.
Checked for related fuses but didn't find anything.
No clue what else could be causing it. I searched the forums but couldn't find this problem. If a thread exists with this same situation, please let me know.
abw73 is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 11:23 PM #2
shadow247's Avatar
shadow247 shadow247 is offline
Senior Member
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
Senior Member
shadow247's Avatar
Try this.
First disconnect the battery, let it sit for 5 minutes, and reconnect.
Now turn on the ignition, but do not start the engine.
Push down on the passenger window MAIN SWITCH only for 5 seconds.
Pull up on the Passenger window Main Switch only for 5 seconds.
This should reset the switch module. I had to do it on mine after I left the dome light on for a few weeks and drained the battery.
__________________
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 11:36 PM #3
Junior Member
Junior Member
Ok thank you. Have already done many tests but not like you describe.
Will try it and follow up.
Old 02-20-2019, 10:29 AM #4
cfranck1's Avatar
cfranck1 cfranck1 is offline
Member
cfranck1 is on a distinguished road
Member
cfranck1's Avatar
Have you checked that the window "lock out" switch on the drivers door is not pushed down?
If it's pushed down, it will "lock out" all window controls at the 3 other doors. All controls would still work at the master switch though.
__________________
01 SR5 - 187k+/- 285 BFG A/T KO2 - 99 talls & front Trekmasters / Rear KYB - Hella fogs - Taco Mod - Fixed gaping hole in frame {SOLD}
02 Taco - 197k +/- BFG A/T KO2 285s + rims from 4Runner - saving up for suspension - House gets priority over Taco (for now)
cfranck1 is offline   Reply With QuoteReply With Quote
Old 02-20-2019, 10:30 PM #5
Junior Member
Junior Member
That was the first thing I checked.
Old 02-21-2019, 11:07 AM #6
nissanh nissanh is offline
Senior Member
nissanh has a spectacular aura about nissanh has a spectacular aura about nissanh has a spectacular aura about
Senior Member
Did you try to clean the contact points inside the switch on passenger door? If, not, you can try that.
nissanh is offline   Reply With QuoteReply With Quote
Old 05-01-2022, 06:06 AM #7
jon55nj jon55nj is offline
Junior Member
jon55nj is an unknown quantity at this point
Junior Member
I just had same problem. Are your referring to the MAIN switch as the passenger door switch or the driver side? Thanks.
Quote:
Originally Posted by shadow247 View Post
Try this.
jon55nj is offline   Reply With QuoteReply With Quote
Old 09-18-2023, 02:51 PM #8
4nrdtoy's Avatar
4nrdtoy 4nrdtoy is offline
Junior Member
4nrdtoy is on a distinguished road
Junior Member
4nrdtoy's Avatar
Tip freaking works?!
Thank you shadow247! I was gonna tear into the door today but tried your tip at my lunch time and it worked! Many many props to you!
4nrdtoy is offline   Reply With QuoteReply With Quote
Old 09-18-2023, 03:48 PM #9
LateRunner's Avatar
LateRunner LateRunner is offline
Junior Member
LateRunner is on a distinguished road
Junior Member
LateRunner's Avatar
Gotta be that MAIN SWITCH refers to the driver's master switch panel.
Quote:
LateRunner is offline   Reply With QuoteReply With Quote
Old 10-06-2023, 12:06 AM #10
chilipeppermaniac chilipeppermaniac is offline
Junior Member
chilipeppermaniac is on a distinguished road
Junior Member
Try this.
I have a 2017 4 Runner Limited.
The car has basically only been driven every so often in the yard in the past 4 years. I have 32k on it and just got the title and began to drive it. All the switches work except the Main switch for the front Passenger window.
3 of the 4 main ones work, plus each switch on the corresponding doors. I tried the 5 minute, 5 second reset, but either did something wrong or it is something else. I will try again tomorrow.
Has anyone ever just had 1 switch that actually was a bad switch and can just the one be replaced?
chilipeppermaniac is offline   Reply With QuoteReply With Quote
Old 10-06-2023, 09:30 AM #11
brillo_76's Avatar
brillo_76 brillo_76 is offline
Elite Member
Real Name: Jon
brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute
Elite Member
brillo_76's Avatar
Real Name: Jon
Unfortunately, this is the 3rd gen section. So the information only pertains to 3rd gens 1996 to 2002. Might have in the 5th gen section...
Sent from my SM-A536V using Tapatalk
__________________
7 3rd gens listed in the build thread (2 are parts mobiles)
Build Thread: https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer: https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information: https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
brillo_76 is offline   Reply With QuoteReply With Quote
Old 10-11-2023, 09:10 PM #12
Junior Member
Junior Member
Thanks Brillo.
I actually did find another place where some folks posted a solution. I am pretty sure it must be in a 5th gen place because the fix worked.
This one was to Use the switch on the actual door and put the window down, then hold the switch down for 10 seconds. At this point, the driver's switch for this door began to work again.
Old 02-13-2024, 01:16 PM #13
Tigersquid Tigersquid is offline
Junior Member
Tigersquid is on a distinguished road
Junior Member
Try this.
Looking through older posts and came across this. Will this work for a 2005 4runner also? The windows will work intermittently from their respective window controls. However they all work without issue from te drivers panel. For example most of the time my passengers will be able to roll down their window but I will have to roll it up for them. Or sometimes it will be in reverse where I will have to roll it up for them.
Tigersquid is offline   Reply With QuoteReply With Quote
Old 05-06-2024, 01:13 PM #14
4runnerbl 4runnerbl is offline
Junior Member
4runnerbl is on a distinguished road
Junior Member
Try this.
2016 Limited
My battery went bad and when I installed new battery driver side panel would operate all windows except front passenger window. Everything else worked properly. I went through these steps and it worked perfectly. Thank you for this information.
One note. I interpreted the MAIN SWITCH to mean the button on the driver side panel. That did not work, but doing this with the switch on the passenger worked perfectly. That is my misunderstanding, but thought I would clarify for any others as ignorant as me. Thanks again.
4runnerbl is offline   Reply With QuoteReply With Quote
Reply
Tags
driver , passenger , switch , window , work
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
One window switch not working- 5th gen BZ_T4R Problems & Warranty Issues 1 10-31-2020 09:25 PM
Passenger power window not working right abw73 3rd gen T4Rs 2 06-10-2018 04:58 PM
Passenger window not working? Revosickness 3rd gen T4Rs 0 11-15-2011 10:01 AM
1992 passenger window stopped working duner Problems & Warranty Issues 1 07-06-2005 02:00 PM
Gen4 Passenger Power Window Switch Mod? Mike552 4th Gen T4Rs 17 08-24-2004 06:34 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
