Old 06-17-2019, 05:29 AM #1
Down by the Water Down by the Water is offline
Real Name: Andre
Down by the Water is on a distinguished road
Real Name: Andre
ABS Actuator Fluid Leak
Ok, brake light started coming on a couple days ago. I checked the fluid, was down to the MIN line in the reservoir. I topped it off, brake light stopped, great. Started looking for a leak and shortly realized fluid had leaked from the ABS actuator. Not the top where the brake lines go in but somewhere on the bottom or rear? Strangest part, it doesn't seem to be leaking anymore? Brake fluid level is steady. I never got an ABS warning light.
Obviously I need to replace the actuator and bleed the system. I'm just wondering what happened? Does the actuator ever vent fluid? Is that a thing? Brakes are working fine. I replaced the front rotors and pads about 5k miles ago. I did not disconnect the brake lines though so I didn't bleed the system. I had the rear brakes adjusted and the system bled last year at my local shop. As I said, brakes have been working fine.
Thoughts?
Down by the Water is offline   Reply With QuoteReply With Quote
Old 06-17-2019, 05:58 PM #2
rideexileex's Avatar
rideexileex rideexileex is offline
rideexileex will become famous soon enough
Generally that is a “no need to ever mess with” part on the brake system. Worst case, there are reports of air getting stuck in the actuator in brake bleeding scenarios, but never any fluid leaking.
All too convenient, but I am selling an ABS actuator from my 2000 if you need.
2000 4Runner Sport - TRD&AEM SuperCharged
Solo Long Travel & KING 2.5 & bumps, 4th gen rear axle & KING 2.5 12's
F+R ARB's, 4.88 Yukon's, 295 KM3s
rideexileex is offline   Reply With QuoteReply With Quote
Old 06-17-2019, 06:33 PM #3
Real Name: Andre
Real Name: Andre
We are leaving for California in a few days. If you still have it when we get back (July 2nd) I'll gladly buy it off you.
I'm more puzzled and curious. I suppose it's possible for any part to break or go bad. Like you, I assumed this was one of those with a very low probability of ever having to replace. I guess I'm just a lucky guy 🤨 haha
Thank you for the reply.
Old 07-06-2019, 09:31 PM #4
Real Name: Andre
Real Name: Andre
Do you still have the actuator? I'm back from Cali and ready to get that thing swapped out.
1996 T4R, no mods, 4x4 w/factory rear locker
Old 07-07-2019, 02:26 AM #5
Sending a PM
Old 01-16-2022, 07:28 PM #6
highalti2d highalti2d is offline
highalti2d is on a distinguished road
This is the only thread I could locate which is similar to my situation. I'm looking for input regarding whether this is something commonly encountered on 3rd gen 4runners.
I have a fairly clean & stock 1998 4runner Limited with 186k. Over the past couple of months, I've noticed a slight brake pedal pulsation which I attributed to possible warped rotors. A rear axle seal leak was repaired a year ago so the rear brakes are fairly new. I was planning on replacing front rotors and pads soon. However, the brake light in the dash illuminated due to master cylinder fluid dropping to minimum threshold. After sitting overnight, it appears brake fluid has been leaking from the ABS Actuator.
My findings so far: A new ABS actuator is over $700. Most used actuators appear to be in poor condition with unknown service life. Any input would be appreciated.
highalti2d is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 05:35 AM #7
Real Name: Andre
Real Name: Andre
ABS Actuator
Hey,
I bought the used actuator rideexileex was offering. I swapped it in, pretty easy, if a bit messy, and I haven't had any problems since. I took my old one apart and there's just nothing to service in them. I'm still not sure why it leaked.
Unless money is no object, buy a used one and install it. That would be my input.
DBW
Old 01-17-2022, 08:52 AM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I haven't seen one of those leak yet. Thanks for sharing...
Old 01-17-2022, 10:17 AM #9
Real Name: Andre
Real Name: Andre
Yeah, I know, strange failure...it's too bad they can't be fixed or serviced somehow. So, I guess it's a pretty rare problem (lucky me!!)
Old 02-04-2022, 09:06 PM #10
Thanks for the input. I bought a replacement ABS Actuator at the junkyard for $40. Went ahead and replaced the master cylinder, front pads, rotors and rebuilt the calipers. Everything is good so far. I'm really enjoying this 3rd gen (previously had a 5th gen TRD ORP but sold it back to the dealer after 3 years).
Old 02-04-2022, 10:05 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Good deal the junkyard one got you going.
abs/vsc , actuator , brake , brakes , fluid , system
Transfer Case Actuator Leak - Fix OPTIONS & Thoughts da1dp 4th Gen T4Rs 30 05-23-2023 09:27 PM
Transfer Case Actuator Leak(2004 LTD V8) LuvmyRunner1980 4th Gen T4Rs 11 12-23-2017 04:57 PM
2003 V8 4runner Actuator Leak Minneapolis gutie050 4th Gen T4Rs 8 11-27-2017 09:59 PM
Actuator leak temperature related? Bob22222 4th Gen T4Rs 3 02-06-2017 01:31 PM
Transfer Case/Actuator Fluid.... Atf??? MikeWhoTruong 4th Gen T4Rs 3 04-17-2011 12:09 PM
