Old 07-02-2020, 03:56 PM #1
Mudeprived Mudeprived is offline
Mudeprived is on a distinguished road
Unusual starting issues
The 99 is approaching the 200k mark and has been a really good vehicle since I bought it four years ago. It has the 3.4 with auto.
It has been starting with sort of a struggle the past couple weeks and not starting up on first try (a few times) the past few days. Seems like it takes a few seconds before it fires up, or doesn't but fires right up on second try. The times when it does start on first try, it sorta starts in a "sloppy" manner, where the rpms are low and it struggles to get to the warm-up rpms of 1500 or whatever it warms up at. This all happens in like two seconds. Once it's going then it's totally fine. It will do this struggle start hot or cold.
No CEL's, fresh battery, tuned up last fall, and starter feels like it is working like it should. Pump and filter replaced last year. Not sure where to start with this so I can prevent a total no-start and miss work or something.
Any ideas?
1999 Limited
265/75/16 AT51's
Bilstein 4600
Mudeprived is offline   Reply With QuoteReply With Quote
Old 07-02-2020, 04:30 PM #2
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Any ideas?
Contacts in the starter or dirty battery terminals
Any one click..
The brushes in the starter and alternators mostly go between 180k to 210k.
So I suspect the starter brushes are warn out.
brillo_76 is online now   Reply With QuoteReply With Quote
Old 07-02-2020, 10:14 PM #3
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Your IAC valve might be a little sticky not allowing the air flow the engine needs to run. It also sounds like it could be a fuel pressure issue, but since you said you replaced the pump and the filter, the first possibility sounds a bit more probable. Did you replace the fuel pump with an OEM one?
This video will help you test and clean your IAC Valve (Idle Air Control Valve)
Old 07-03-2020, 12:35 PM #4
Gull81 Gull81 is offline
Gull81 is on a distinguished road
Any loss of coolant or anything like that?
Gull81 is offline   Reply With QuoteReply With Quote
past , seconds , start , starting , struggle
starting issues olhobbler 3rd gen T4Rs 3 07-20-2018 02:25 PM
Starting issues f-it 3rd gen T4Rs 4 07-25-2014 02:06 PM
Unusual Starting Problem pkinfinity Maintenance/Detailing 7 10-04-2012 09:17 PM
97 Starting Issues barefoot lester 3rd gen T4Rs 6 02-13-2012 07:21 PM
