06-09-2020, 09:19 PM
Real Name: Alex
Real Name: Alex
Mystery....Need engine experts.
Ok so about a month ago the 4runner (99 3.4L Auto 150k) started shaking really bad but only at startup and only for about 10-15 seconds. So naturally as a somewhat mechanically inclined person I
Cleaned MAF sensor, replaced air filter, Replaced IACV valve, cleaned throttle body, replaced PCV valve, grommet, and hose. Replaced spark plugs with Proper OEM as well as NGK wires.
Shake did not go away as i thought it would. No codes have been thrown during this mystery also. Once the shaking stops it is smooth as butter for the remainder of the drive.
Fuel filter is relatively new. All 02 sensors are newish and proper Denso units.
I have used propane to search for vacuum leaks and did not find any, replaced some vacuum hoses as well (just to be anal).
Some of you have no doubt concluded maybe a headgasket. However, oil looks clean and radiator is full, no smoke or sweet smell out of the tailpipe.
So now I am stumped. Hopefully I missed something small that someone else can help me solve this mystery as I am about ready to take to a shop so they can charge me a ton of money only to replace stuff that doesnt need replaced and not fix the problem lol.
Thanks in advance.
Every man dies, not every man truly lives
06-09-2020, 10:25 PM
I had similar symptoms. Replacing injectors resolved most of it. My next plan is to replace the fuel pump and screen.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
06-09-2020, 10:30 PM
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
Thanks in advance.
for the engine to run we need timing, spark, and fuel.
It sounds like you are confident you have timing and spark.
I'm going to toss out a wild guess and say fuel pump. If it's consistently rough @ start up. what if you leave the key in the on for 20 seconds then crank to start?
I guess I would want to know what the fuel pressure is but that is probably something you will have to pay to find out unless you already have that setup with a fuel pressure gauge.
06-10-2020, 12:46 AM
Far as I know the fuel pump on these don’t pump until the computer sees the engine turning.
06-10-2020, 08:26 AM
Real Name: Alex
Real Name: Alex
Thanks for the replies.....
Fuel crossed my mind but it doesn’t have the symptoms I would associate with bad injectors the fuel pump is a possibility but it is only happening on startup.....there is no other stutter or loss of power or other problems associated with fuel pumps.
Not to say injectors/pump couldn’t be the cause anything is as likely to me as the next.
Is it best to just to take to a shop and have them check fuel pressure? Injectors tested?
Anything else I could be missing?
06-10-2020, 08:49 AM
When the head gasket started to go on my truck, my truck would shake for 15 seconds or so before it would smooth out. It also didn't blow any white smoke and only after a few weeks would the reservoir be down about a 1/2" or so. Never had any check engine lights for the shaking until it got really bad and I confirmed it was a blown head gasket.
I tried all of the quick "tests" for checking for a bad HG and all of them said I didn't have a blown head gasket until I did a leak down test. The second I pressurized cylinder #3 I had air bubbles coming out of my radiator.
I'm not saying for certain you have a blown HG but its a possibility. If you want to 100% rule it out or confirm it, do a leak down test.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
06-10-2020, 09:20 AM
Real Name: Patrick
Real Name: Patrick
You can't truly eliminate a head gasket issue until you do a compression and leak down test. I recommend doing it on a cold engine since you are having the issues on startup.
06-10-2020, 11:21 AM
Definitely do a leak down test and compression test. Also may want to try a coolant pressure test. Based on what i have read, its highly likely a head gasket or cracked head issue with coolant leaking into the cylinder. Mine does this currently and have found no fix for it.
06-10-2020, 12:14 PM
Real Name: Jerod
Real Name: Jerod
There is no good way to test fuel pressure, we don't have a schrader valve so the shop won't be able to do anything unless they remove part of the fuel rails (read as more $$$).
What could be possible is that one or more check valves in the fuel system have failed. It could be the check valve on the pump that holds line pressure, causing a low pressure situation at startup. Or, it could be a failed injector check valve and it's leaking into the engine.
Does the issue get worse the longer the vehicle is inactive?
06-10-2020, 12:35 PM
Real Name: Dave
Real Name: Dave
Just a thought, FJ - If you don't have a cylinder leak-down setup, there's an old-school way to check this. One evening, after you're through using the vehicle for the day, pull the sparkplugs. Let the vehicle sit overnight. Because the engine is warm, there'll be pressure on the cooling system. By pulling the plugs, you've released any internal cylinder pressure, which creates a pressure difference on the gasket surface. The next morning, crank the engine over while keeping an eye on each cylinder. The spark plug hole spewing a fine mist will be the one with the head gasket leak.
06-10-2020, 03:32 PM
To me you have a head gasket going bad or a leaking injector causing a flood condition at startup.
A cheep bore-aH-scope looking in each spark plug hole on a cold engine will tell the tale.
Until your engine goes closed loop you’re not going to get any codes.
06-10-2020, 10:42 PM
[QUOTE=gamefreakgc;3502469]There is no good way to test fuel pressure, we don't have a schrader valve so the shop won't be able to do anything unless they remove part of the fuel rails (read as more $$$).
FYI. u don't need a Schrader valve on the fuel system to check the fuel pressure, checking it is not hard and does not require u to remove part of the fuel rail, all u do is disconnect the flared fitting on the driver side (the main connection from the chassis to the engine) and connect here with fittings that allow u to connect a gauge (a good fuel pressure kit has said). u can also pull the fuel rail banjo bolt on the front side of the block (I use the pass side on as it not hard to get at) and use the special banjo bolts with a schrader valve to connect.
06-11-2020, 01:19 PM
Real Name: Alex
Real Name: Alex
Update
So just to get an idea....I called around to some shops and it’s going to be roughly about 2700-3300 depending on what they find if it is in fact a bad HG. At this point I don’t think I’m able to drop that amount of $$$ on it. So I may get a diagnosis professionally and see if that what it is but I’m having trouble justifying paying that much currently.
I live in Indianapolis IN if someone happens to know of. Guy that can do it somewhat cheaper.
Thanks for everyone’s input. Hopefully it’s just an easy fuel delivery something or other.
06-11-2020, 02:14 PM
Real Name: Jerod
Real Name: Jerod
[QUOTE=clearock;3502749]
Yes, one definitely can be added. But he's taking it to a shop and they won't have all those little bits on hand and will charge an arm and a leg or just flat out say they can't do it.
