08-09-2019, 02:40 PM
#16
Originally Posted by Bad Luck
You can try to be quick about connecting new hoses, but you will need to bleed the air out of the cooling system due to new hoses and rear heater core having air in them.
Good call. Thanks for the tip.
"Bettie" - 1998 4runner LTD E-Locker Evergreen Pearl 275K+, Alpine HU, Infinity Reference Speakers, Airraid MIT, B&M Cooler, Light Racing UCA, RCI skids, Bilstein Tundra 5100 and 4runner Eibach Coils in front/ Bilstein FJ 5100 and OME 890 rear, LC80 wheels wrapped with MT Baja ATZ 285/75/16, 99+ overhead console, 99+ center console, sound-deadening, Ditch lights
08-09-2019, 03:06 PM
#17
Originally Posted by anniesball72
Any chance you have the part numbers? I just did the upper and lower radiator and oil cooler hoses. But using the online parts catalogs ( Camelback ) is very challenging to find all the hoses....
Post #12.
@ anniesball72
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
08-09-2019, 03:11 PM
#18
Originally Posted by 2TH4IST
Thanks, my bad, I didn't read the full article.
02 SR5, manual hubs, 3” lift, airbags, 5-speed swap with locking center diff, 1st gen supercharger, URD 7th, BAMF sliders.
08-09-2019, 03:17 PM
#19
With 225k miles on my 1999 is it recommended to swap the hoses out? My mechanic said nothing needs to be done yet except my UCA is looking like it needs replacing, but he never mentioned hoses and such.
Thanks ahead of time
08-09-2019, 04:18 PM
#20
Of the things that have left me stranded over my years of driving old cars (non-Toyota), coolant leaks are #1. That's been water pump failure and hose failure. After that, it is brake hose failure. Luckily no flats. Keeping good hoses is cheap insurance. Old hoses either get softened and thin with age, which causes bulging, or get hard and brittle. Just inspect them and see if they appear soft/bulging or brittle. Also look for any evidence of mineral deposits/dried coolant at fittings.
08-09-2019, 04:20 PM
#21
Everything on your truck is 20 years old. Age and heat play havoc on rubber... thus anything rubber ought to be suspect. That's all the rubber coolant lines, all the vacuum lines, the bushings, fuel lines, brake lines, even o-rings. That stuff does okay so long as it sees constant use, but there IS a finite life. And keep in mind, most recommendations are to change the coolant hoses out every ~5 years... so if they've never been done, they're 15 years over-due. (I think that's a BS, CYA estimate, but how far up the creek without a paddle are you willing to get yourself when something finally gives?) If you're going to risk it, at LEAST learn about emergency repairs and buy the supplies to keep in the truck full time.
As a FWIW, there is a silicone kit from HRS for $138 that contains the lions share of these hoses used with the heater ~ 57-1798-BLK (they have red and blue too, I'm not into bling). Plus another kit for the main upper and lower hoses... 57-1217-BLK-1, though I found cheaper options. Just leaves the oil cooler and for those that have them, the throttle-body that must come from Toyota.
08-09-2019, 06:33 PM
#22
I saw the HRS kit but adding the rad hoses were more then oem hoses, and since oem lasted 19 years I went oem. Only thing I'm a bit pissed about is I just replaced my radiator (hole in it) and then a month later koyo comes out with a full aluminum radiator...go figure. So when funds permit I'm going all aluminum koyo and the new used rad (also koyo) will go up for sale.
08-09-2019, 07:52 PM
#23
Yes I want to do all of that and replace all hoses and whatever else you think, I’ve been looking at them and they look and feel fine, but I’m no mechanic so I can’t tell but as being 20 years old I feel like none of it was replaced during its lifetime
I got the belt and pump changed but I’d like to do more work on it before it becomes a problem
Any recommendations on where to buy these parts?
Thank you
08-10-2019, 02:27 AM
#24
I would also check/change the transmission cooler lines that run to the radiator. Twice I have had these fail on trucks with over 200,000 miles because no one ever changed them.
Now when I buy an old car/truck I check them right away and the last few old vehicles I bought they were soft and not in good shape. I changed them out on my 4Runner when I put in a new radiator so they should be good to go for years. If these fail they will of course leave you stranded if you lose fluid.
08-10-2019, 01:23 PM
#25
Location: Southern California (please don't hold it against me)
Real Name: michael
Real Name: michael
don't forget about the heater valve they get brittle.
05-07-2021, 01:57 PM
#26
Real Name: 3 Bears
Real Name: 3 Bears
@ Brian.
Okay, there are a few vin splits, so this is your responsibility to double check to make sure they fit your 4runner.
Since my vin is above 200008 I used 200008 and up part #'s.
Once again double check your vin split with hose part numbers, they have up to 4 different hoses, it's not my responsibility if you order the wrong part #'s.
My 4runner is a 2000 4wd SR5 V-6 w/rear heater.
Perfectly fine to run 100% water UNLESS YOU ARE IN FREEZING WEATHER!!!!!!!!!!! Antifreeze is exactly that, prevents the coolant from freezing (along with some rust preventative), does ZERO to help cool the engine, its actually bad to run to high of a concentrate of coolant vs water. I ran 100% distilled water and rad flush for 3 weeks in my 4runner. I also only run distilled water in my miata with water wetter. My 4runner is running 50/50 and water wetter as it will see winter weather.
Look at corresponding pics to match up the hose locations.
1. 87245-35770
2. 87245-35451
3. 87245-35461
4. 87245-35700
5. 87245-35690
6. 87245-35680
7. 87245-35710
8. 87245-35670
9. 87245-3D090
10. 15778-62030
11. 15777-62020
12. 16261-62060
13. 99556-10300
14. 16571-62070
15. 16572-62090
thanks so much for this....was getting ready to figure this out for my next timing belt/pump job
thanks
05-07-2021, 11:45 PM
#27
I had completely forgotten about this. Your welcome, glade you got some use out of it.
11-16-2021, 06:24 PM
#28
Challenging for sure since Camelback does not list these hoses by the original PN, for example the hose to right of tee is 87245-35720. Doesnt show up on their part search. Camelback parts guy sent me a diagram, new PN 87245A (and B, and E for the other hoses off heater valve.) Plug that into their search bar and NOPE, doesn't work. Then they gave me a superseded #87245-3D230. Plug that in and it says "won't fit your 97 4runner. What the actual FORK!
01-27-2022, 03:32 PM
#29
Real Name: jim
Real Name: jim
87124-35010 clamp
I recently replaced all the coolant hoses. For a 19+ year old car it's probably a good idea to do it. They will most likely spring a leak at the worst time possible in the most horrid location. The ones that fought with me the most were the oil cooler hoses. The heater core and rear heater were a piece of cake. I highly recommend getting a set of long needle nose pliers. To do all the hoses OEM toyota, was somewhere around $205 for all oem hoses. Since oem lasted 19+ years I went with oem.
i know this is an older thread but i'm currently purchasing all the hoses and clamps to do this same project. there is a clamp that is no longer available, it doesnt look too important. but i was wondering if anybody has had to replace theirs with something else? mine seems fragile and i'd like to replace it without getting another old one from a salvage yard.
99 sr5 manual 4 wheel drive
01-27-2022, 03:46 PM
#30
Do you have a photo or part number of the clamp you’re asking about?
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
