Old 08-20-2019, 07:42 PM #16
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
Thanks for being the test subject, glad to know it will work. I think the difference is the gear on the axle shaft that sends the signal to the abs.
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 08-20-2019, 07:49 PM #17
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
Yeah it was way too hot and I was way too impatient for me to get out the calipers haha
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 03:58 PM #18
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Running a 2002 axle in my 1998. The 1998 ABS sensor plugged into the 2002 axle.
Old 08-27-2019, 07:46 AM #19
ToyotaBrah's Avatar
ToyotaBrah ToyotaBrah is offline
ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about
ToyotaBrah's Avatar
Originally Posted by thezentree View Post
Well, near as I can tell, the axleshaft/brake assemblies are totally interchangeable, or at least later assemblies will work in an early housing.
I put my 01 axles in the 97 housing (with the new-style seal) and with the "grease test" the seals look like they're riding in the same place on the 01 retainers as they are on the 97 retainers.
I reused my 01 ABS sensors with the 01 axles, and got no ABS lights. The 97's ABS sensors looked like the same part to me.
Awesome, thanks for the update! I can't wait to do the swap on mine.
ToyotaBrah is offline   Reply With QuoteReply With Quote
Old 08-27-2019, 08:08 AM #20
Taylor20's Avatar
Taylor20 Taylor20 is offline
Taylor20 will become famous soon enough Taylor20 will become famous soon enough
Taylor20's Avatar
If I only I had seen this earlier. I swapped a 98 axle in my 02, only changed out the rear brake lines on the axle. Everything else was plug and play, minus the locker harness, and a couple small brackets.
02 Sport
Toytec Boss/LJ - TRD Pro & 255's - TBU - 4:30's - Elocker
4xI - AED - Savage
Taylor20 is offline   Reply With QuoteReply With Quote
Old 08-27-2019, 12:13 PM #21
thezentree's Avatar
thezentree's Avatar
No big deal, I wanted to use my 01 axle shafts anyway since the 97s backing plates were trashed. I’ve got about 200 miles on this Frankenstein setup so far and it seems to be working just fine!
Old 10-03-2019, 10:07 AM #22
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE will become famous soon enough
STI_MECE's Avatar
I am in the middle of this same process as well. My 2000 4runner is leaking at the rear seals.
I pulled 2 x inner axle shafts from a 2002 4runner.
If I read this correctly, the wheel bearings, and seal that goes around the wheel bearing are, for lack of a better word, year specific (to a certain extent). In other words:
NOTICE THE BEARING HOUSING IS THE SAME PART NUMBER, BUT WHENEVER I WAS LOOKING AT THE PART NUMBER FOR 2002 IT ONY WHEN DOWN TO 2001. AND WHEN I SEARCHED 2000 IT ONLY SHOWED FOR 1996-2000
1996-2000
  • Wheel Bearing: 90363-40020-77
  • Axle Shaft Outer Oil Seal: 90313-48001
  • *Wheel Bearing Housing: 42421-35030 (or not needed at all)
2001-2002
  • Wheel Bearing: 90363-40068
  • Axle Shaft Outer Oil Seal: 90313-54001
  • *Wheel Bearing Housing: 42421-35050 (or not needed at all)
1996-2002
  • *Bearing Retainer: 42423-20010
  • *Snap Rings for Retainers: 90520-36045
  • Inner Axle Oil Seal: 90310-50006
  • Bearing O-Ring: 90301-88077
The ones marked with * are optional depending on how you go about this job.
In short, the parts that are year specific that interface with the outter most portion of the axle.
Hope this helps someone....Time for more partsss
2000 SR5 4x2 Resto/Maintenance
STI_MECE is offline   Reply With QuoteReply With Quote
Old 01-19-2024, 09:44 PM #23
GG2000-4Runner GG2000-4Runner is offline
GG2000-4Runner is on a distinguished road
1996-2000
2001-2002
1996-2002
Don't forget the different backing plates. There are a couple of differences, but the most important one is the hole for the adjuster. It is on the other side. I made a comparison table with images in this Google Doc: Rear axle-hub-and-brake assembly comparison - Google Docs.
By the way, production on the new axle and related parts started in 08/2000. Check your door sticker to see which month your 2000 was made to see if you have the old or new designs.
Also, another difference I haven't seen mentioned is the with the wheel lug studs. They changed the design slightly in 09/1999. I don't know if they are backwards compatible, but I don't see why not.
GG2000-4Runner is offline   Reply With QuoteReply With Quote
abs , axle , brake , differences , lines
Early versus late 3rd gen T4R Carnutbmw 3rd gen T4Rs 24 12-31-2018 05:22 AM
Late spring/ early summer road trip... -dustin 5th gen T4Rs 5 10-27-2016 03:27 PM
Which drives better, an early 3rd gen or a late 3rd gen? StreetCreeper 3rd gen T4Rs 60 02-10-2016 07:24 PM
Anyone else listen to late 90s, early 2000s rock? Millerad1651 Off Topic 17 12-15-2013 04:58 AM
Late 3rd Gen Steering Wheel onto Early 3rd gen? PitbullRescuer 3rd gen T4Rs 9 01-19-2012 11:14 AM
