Old 09-19-2021, 08:17 PM #346
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
Originally Posted by brillo_76 View Post
This happens when you hit a pot hole in PA
I was driving this minutes before the photo was taken
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 09-20-2021, 10:21 AM #347
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
He actually was..... for some reason,the turn signals, brakes and accelerator where not working....:/
Old 09-20-2021, 11:47 AM #348
This one is for @phattyduck . Now this rot... PA Chrome at this finest. Even the engine frame area is really rusted...;)
I took a very similar picture of my California rust-bucket parts truck a few years ago:
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-20-2021, 12:45 PM #349
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes I promised you a photo of the common PA chrome... Once I got that engine out. ;-)
Old 09-20-2021, 08:52 PM #350
I was trying to hit the brake on that thing forgetting that I had removed the abs pump previously. I’m not kidding when I say I could probably break the frame in half by kicking it
Old 10-09-2021, 07:26 PM #351
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Here is how I put the timing belts on. I use 3 clamps. 2 2inch ones 1 3 or 4 inch. The 2 inch go on the camshafts holding the belt on the marks. Belt goes on left camshaft first then the right camshaft. Leave the belt tensioner bolts really loose. Use the larger clamp to hold the belt in place on the crankshaft. Then I use metal bike cycle tire iron to slide the belt onto the water pump. Seems to be a very quick way..
Old 10-09-2021, 07:31 PM #352
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Then I tighten the tensioner bolts up. Spin the engine via the crankshaft bolt twice to verify the 3 timing marks line up. The belt marks will not just the camshaft marks and the top of the crankshaft mark. [ the side mark is only use fior new belt. ]
Once I verify the the engine is in time I pull the tensioner pin.
Old 11-26-2021, 05:40 PM #353
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
@RandyBobandy and my Brother hit he local pull an pay with all you can haul out for $40 bucks.. Well 3 trips and $126 bucks later we came out with.
Injectors for Randy (BMW)steering wheels and some relays
Honda oddsay windshield sprayers
I came out with a pair of sequoia tundra front calipers
3rd gen Sport hood. 02 throttle body, 02 Master Cylinder
stainless steel real heater lines. Heater valve, rear
engine skid plate. Battery bracket and plate.
The 2 VSC sensors near the emergency brake
plus 2 of the 3 exhaust heat shields
02 headlight and Grille
My brother came out with all the seats and most
interior for his 01 VW Golf.
Granted it didn't snow and we were working
in around 28 Degrees from 9 to 3pm
Great trip.
Old 11-26-2021, 09:24 PM #354
Anyone ever try to fit a 2007 es350 steering wheel to a 3rd gen? I don’t think it will plug in to the existing clock spring
Old 12-05-2021, 12:01 AM #355
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Do you realize you posted this on my build thread instead of the general forum??
Old 12-05-2021, 12:03 AM #356
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The 1997 limited is getting a newer [lower miles 165k ]engine, transmission and transfer.
Old 12-05-2021, 02:14 PM #357
HiLife HiLife is offline
Have you found your engine prices has risen in your area?
I remember for a 5vz could be haggled down to $500. At that time, average prices were $800.
Today, that same engine is going for average of $1900 here.
I would've gotten the engine at $500 but, no where to store that huge and heavy part.
Old 12-05-2021, 05:20 PM #358
Import engines are stupid high around here, I’ve been looking for a Miata engine and they’re so expensive I could buy a whole donor vehicle cheaper, same thing with 4runners I could easily get a donor vehicle for $1900 with a good engine.
When I get a miata engine I’ll buy a whole engine and transmission from Europe and it will be cheaper than any of the clapped out engines I can find for sale locally including shipping
Old 12-06-2021, 11:08 AM #359
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes mine was from the parts mobile. A person took the transmission out and sold me the entire rig a few years ago for $400.00. The replacement transmission came from RandyboDandy manual swap so fortunately. My parts were very inexpensive.
We replaced on the gaskets on the engine and did the valve pans and timing while it was out.. :-)
Old 12-18-2021, 10:47 PM #360
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well making progress on the 1997 limited. Have the replacement engine ready to drop in all new oil seals vale pans. Timing belt etc. Even got itself new engine mounts
chassis , frame , repairs , rigs , road
MORE 3RZ builds....... ralatkins 3rd gen T4Rs 21 10-28-2022 12:39 PM
Trailer Builds Okki 5th gen T4Rs 6 12-15-2019 09:11 PM
Vehicle Builds Victory 4x4 Victory4x4 4 06-19-2019 08:44 AM
5th Gen Pre-Runner builds? PeoplecallmeIan 5th gen T4Rs 0 03-14-2018 04:34 PM
