04-10-2024, 09:50 PM
#706
Real Name: Jon
Real Name: Jon
Originally Posted by poleclimber63
Holy crap! Unbelievable it took several tries to get the correct calipers! I think youre right about the core returns, however, I would have thought they'd catch that at the reman facility as they'd have to ensure the correct rebuild kits are used in the reman process!! I've been using Rockauto for years and I have to admit, I've never had to return anything... I did receive the wrong caliper boots once and a wrong caliper pin (not for the 4Runner), but seeing as these parts were < $5 and return shipping from Canada to the US was double the cost of the parts, I didnt bother...
Maybe I should buy a lottery ticket..
Looks great by the way, you won't be disappointed. I did the TBU back in 2015 and have never warped rotors since---- or experienced brake fade while towing...
This is my 2nd one running the S13WE Tundra Rotors. I really can not stand warped rotors. I took the rig today and just about got the brakes burned in. I believe I need to bleed them again as they are working decent. I just think I still have some air in the system yet. I use stainless steel speed bleeders as well. They work great but you need to add that white paste in place of plumbing tape to threads. As if you remove and reuse them a few times you need to reapply of thread sealer as if you don't. The air can seep around the threads. The speed bleeders come with a thread coating and its available to order I will Thread Sealant bootle when I order more bleeders. ;-)
04-11-2024, 08:30 AM
#707
Originally Posted by brillo_76
Finally got the correct drivers side caliper... Took 2 weeks . I tried twice from rock auto and they kept sending me S13WM castings in S13WE boxes because people are sending the wrong calipers back as cores.. Or the re-mfg company is boxing them wrong. I am suspecting its folks putting the 3rd gen calipers back i as cores and messing up the supply chain. As I got 2 S13WM. What a mess this made. :-(
Knowone has any attention to detail anymore.
04-11-2024, 12:30 PM
#708
Real Name: Robert
Real Name: Robert
Or uses spell check, apparently
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
04-11-2024, 02:36 PM
#710
Real Name: Robert
Real Name: Robert
Easy. I understand what he was saying. :-) No need to nick pick. :-)
He helped and contributed a lot more then most users have. He can misspell and have horrible grammar all he wants on my thread.
Hehe, had to poke fun at someone talking about attention to detail, and then writes “knowone” lol
#711
Brillos Builds
Some people “like me” do not pay attention to detail anymore?
Is that better?
04-11-2024, 02:42 PM
#712
Real Name: Robert
Real Name: Robert
some people “like me” do not pay attention to detail anymore?
Is that better?
Sent from my iphone using tapatalk
100%!
04-11-2024, 07:13 PM
#714
Well no reason to poke fun. Its a mute point. Plus when using cellphones the auto correct will sometimes get you. Everyone knew what he was trying to say.
That is what counts. :-) Careful, you may make a typo and karma will get you. Things happen, folks have bad days get in a hurry and sometimes type badly.
Ah, yes, most defiantly (or definitely ).
Moot Point or Mute Point, Which is Correct? | Merriam-Webster
Haha
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
04-13-2024, 06:14 PM
#716
Real Name: Jon
Real Name: Jon
I got a chance to re bleed all 4 corners on Shitbox after I replaced the 2 front calipers with S13WE and Tundra Rotors. Like I suspected from the feel of the pedal I had some air in the system that needed purged out. I know some folks don't care for speed bleeders. However, when living in the rust belt and you buy the stainless steel version. They work great provided you keep the thread sealant on it. By letting one person do the job instead of 2.
Now around less then 1/2 inch pedal movement and brakes are applied. Very nice as no rotor surface warpage. Much much better.
