Old 12-31-2021, 02:30 AM #376
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The other driver side spindle now completed with new [ both sides ] upper and lower ball joints. Drilled and tapped brake line bracket bolt. I have stainless steel flanged bolts coming to replace these brake line bracket bolts as it seems they rust and swell causing the head to just break off. I figure this will correct this issue forever being the stainless steel bolts will nut rust.
Old 12-31-2021, 05:00 AM #377
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
I guess if you go in expecting the worst, it's a little less of an uphill battle.
Don't know if I'd have your patience. I'd finally have a reason to make sure
the oxy-acetylene bottles were full :-)
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 01-02-2022, 10:29 PM #378
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I don't use cutting torches much anymore. The plasma cutter does a better job. Except for heating up steel to get bolts and nuts to come loose. Then the acetylene is very helpful. Sometimes a few cycles of heating up and cooling down can break the rust bond. Unless the bolts swell from rust. Then it's game over and drill and tapping is required. I am planning to swap out the smaller bolts like the 10mm x 12mm hex head ones with stainless steel flanged bolts and nuts in the heavy rust areas as I figure those are less likely to get stuck and snap. Granted stainless steel is harder so that makes them brittle. As the rust belt is hard on things.
Old 01-12-2022, 05:35 PM #379
Yeti2k3 Yeti2k3 is offline
Real Name: Joe
Yeti2k3 is on a distinguished road
Real Name: Joe
Brillo's brother joining in on the fun here! Great thread!
Yeti2k3 is offline   Reply With QuoteReply With Quote
Old 01-12-2022, 05:45 PM #380
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Oh boy @RandyBobandy ...looks like @Yeti2k3 found us... The thread will never be the same now..lol
Old 01-12-2022, 06:48 PM #381
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
If any more of your type show up here it will end up becoming a German car forum
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 01-16-2022, 07:36 PM #382
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Gee I wonder why the passenger side axle seal l was leaking?
I guess whoever worked on it in the past didn't know how to change axle bearings and retainer probably...:/
Old 01-30-2022, 09:40 PM #383
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well lucked into the axles being correct in the e locker that we pulled @RandyBobandy and my axles had new brakes and wheel cylinders in them. So we swapped the hardware onto the there axles put oem axle seals in and bolted them up. They even have replaced wheelbearings in them as well. Cut the dust shield around the drum off as it was about rotted off anyhow. Plus makes it a lot easier to pound the drums off when the holes are stripped to press them off if the ridge occurs on the drums..
Old 01-30-2022, 09:41 PM #384
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Drilling fluid film holes in the front frame brackets before I weld them back on.
Old 01-30-2022, 10:51 PM #385
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Went to the drill press to make life easier
Old 01-30-2022, 10:52 PM #386
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Got the front plates welded back on I raised them slightly on purpose. As possibly going to plate bumpers on this one done the road
Old 01-31-2022, 09:51 AM #387
jsnppp jsnppp is offline
jsnppp will become famous soon enough
That will do it! Looks great.
~jason
jsnppp is offline   Reply With QuoteReply With Quote
Old 01-31-2022, 11:00 AM #388
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Great idea, Fluid Film is a way of life in our area to keep these rigs from turning to dust.
Mine lived it’s life in midwest prior to my ownership so some damage already done.
My goal is to try and keep it at bay as long as possible as can’t imagine car life without a 4TR in the garage.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 01-31-2022, 02:53 PM #389
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well inside the frame is the only place fluid film will it stay. It washes off the metal fairly quickly.. I think I am going to cosmoline underneath on the metal ..:-) and just use Fluid Film inside things.
Old 01-31-2022, 06:52 PM #390
Any experience using Woolmax?
I’ve heard it’s a bit thicker/heavier than Fluid Film and holds up better.
Picked some up but haven’t tried it yet.
Brillos Builds-782c10e9-fea3-4301-81ab-5056e4db89c0-jpg
2002 SR5 Sport 4WD
chassis , frame , repairs , rigs , road
MORE 3RZ builds....... ralatkins 3rd gen T4Rs 21 10-28-2022 12:39 PM
Trailer Builds Okki 5th gen T4Rs 6 12-15-2019 09:11 PM
Vehicle Builds Victory 4x4 Victory4x4 4 06-19-2019 08:44 AM
5th Gen Pre-Runner builds? PeoplecallmeIan 5th gen T4Rs 0 03-14-2018 04:34 PM
