09-22-2019, 09:52 AM
A $12 Part That May Have Cost Me Dearly
Well, did the Pumpkin vent cap and after taking the old one out it appears
the rust belt may have contributed to the demise of my axle seals going bad? This vent cap is in the worst spot when driving in a winter area that's salts roads................
I decided to go the extra step that "Timmy The Tool Man " showed in his video and let me tell to the one tip he gave was to drop the spare, should have listened to his words of wisdom, lol Now that the vent is inside the gs cap area that sucker won't need replacing again. The 02 has 170K on it so well past it's needed replacement time frame in these parts.
LMS
Reason: corrected to axle seals
09-22-2019, 12:54 PM
Originally Posted by brillo_76
Yup it amazing how bad those rust up. I figure better check every 5 years replace every 10. Same as the denso radiator.
Extending the vent hose up the fuel filler neck is a great mod. I find that the Denso radiator trans coolers fail at about 15-20 years. It's something I recommend as a precaution to customers with 3rd gen T4R's, Tacos, and 1st gen Tundras with automatics.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
09-22-2019, 03:45 PM
MaineRunna,
Thank you very much for that suggestion as I had not thought of that in my lineup of upgrades to the 02!
LMS
09-23-2019, 10:01 AM
If that was stuck and forcing oil out past the seals, it's very likely that fixing it will stop the leak. The seals are spring loaded, it's not like a little oil pushed past them will make them go bad. You will need to take the drums off and clean up the mess inside though. And probably put new shoes on - there's no good way to get oil out of the linings.
09-23-2019, 11:38 AM
JohnMc,
My other concern is has the grease been washed away from the bearings as well? There is the elephant in the room
09-23-2019, 11:51 AM
Are your brakes contaminated? If so, I would think it is beyond a stuck breather and now Leaking seal time.
When I caught my leaking seals, it was still in the abs cavity and not beyond. The bearings were essentially grease free at that point with the sludge in the abs cavity. I replaced the bearings as they were original at 175,000 km. New ones were tighter.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
09-23-2019, 11:52 AM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
What does the rear main seal have to do with the rear diff? Were you referring to your outer axle seals?
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
09-23-2019, 12:01 PM
Yes, my bad......Corrected the mistake in above post. Thanks
09-23-2019, 12:25 PM
Real Name: Jon
Real Name: Jon
I did that for a while and changed it back. Being mine are mainly DD and road use. No need to extend my breather. Great tip of the rads if closer to 15-20 years I would exchange them at 10 years. Not much worse then the milkshake..:/
09-23-2019, 04:03 PM
Real Name: Jerod
Real Name: Jerod
Originally Posted by Last Man Standing
JohnMc,
They will let you know if they have gone bad. Just lift the wheels in the rear, shift to neutral and give them a good spin. Make sure the brakes aren't dragging but if it sounds quiet with only a few clicks and such you are good.
I replaced my bearings 2 years ago only to have the seal fail again a few months later. I didn't replace the bearings a second time and they are just fine. Not much, if any, oil made it past the outer seal.
09-24-2019, 07:31 AM
gamefreakgc,
Thanks for the thoughts and suggestions!
I did spin the wheels however I was not paying attention to this point during my repair of the parking brakes. I will try and do that this weekend? The fact your seal failed has been on my mind especially after watching Tim's video on the method he used to solve this by inverting the bearing retainer so the bevel faces the hub instead of the oil seal? Seems like he only gained an additional 1/16" of increase on the surface of the retainer! To bad someone hasn't made a larger retainer due to this issue.
LMS
09-24-2019, 09:33 AM
LMS
Thing is, there isn’t room in there for a larger retainer. It’s a space of mm between the retainer and the axle housing as it is. That’s why the flip and maybe scootching 1 mm in is about as good as you can get. Then you run out of clearance.
-2001 Echo D.D.
09-24-2019, 09:53 AM
Kanoe,
Makes sense then, wonder what the designers had in mind for such a limited
amount of surface contact with the retainer? Perhaps a wear issue to the seal
surface? I don't want to go thru the process to see it fail or be short lived that's for sure.....Thanks for the insight on this.
LMS
09-24-2019, 07:07 PM
Real Name: Jerod
Real Name: Jerod
gamefreakgc,
LMS
That's what stopped my leak, flipping the retainer. The poor machine shop was so confused and almost refused to do it because it's wrong but it worked so far, no more leaks.
