Old 10-14-2019, 07:54 PM #1
ccurrans ccurrans is offline
ccurrans is on a distinguished road
Overheating issue
'99 SR5 here... 245k on the clock. Swapped out the auto trans solenoids the other week and now the truck is overheating. I find it strange that right after I swap these it starts to overheat when it never has before. The plan, since it is new to me, is that I'm going to end up swapping the thermostat, water pump, timing belt, serpentine belts, radiator and both hoses. I think the clutch fan is fine, but while I'm doing this, I'm debating on a separate trans cooler too and maybe an electric fan. Any ideas on what is causing the overheating or the work I'm about to do in a week? Thanks in advance.
ccurrans is offline   Reply With QuoteReply With Quote
Old 10-14-2019, 09:39 PM #2
Toy2play Toy2play is offline
Toy2play will become famous soon enough
When is it overheating? Just sitting, moving at low speed, highway speed, under load? Are you watching the gauge in the dash or do you have something to see the exact temperature? How quickly is it overheating?
97 Charged, lifted, armored, geared, locked SR5.
Toy2play is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 10:57 AM #3
I haven't checked with it just sitting yet, but not under load and was at highway speed around 60 and was watching the stock temp gauge. I'll check tonight and see if it overheats while at idle. I did notice that at one point, I let off the throttle and the temp went down, so take that for it's worth as well. Thanks for the help.
Old 10-15-2019, 11:11 AM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
1.) make sure the radiator is full of clean antifreeze
2) when you see the gauge creeping up. Turn your heater on full blast and see if the gauge returns back down. If it does, then most likely your thermostat is just sticking closed.
Was very common on the older 80's pickups and now that these are all mostly close to 20 years old, its possible that yours was never changed or just going bad.
Lots of writeups and videos out there how to change the 3rd gen thermostat. If that is indeed the cause of heat-up.
Also, lots of people bypass or put in series an After Market transmission cooler. Many threads on this forum as well on how to do that.
I myself, do not put A/M coolers on. I just replace the radiator every 10 years with a new Denso one (around 100 on rock auto) If majorly hauling might be a good idea to put one in series with the radiator. However, Liquid to liquid heat transfer is far more efficient then air cooling. { That is just me though} Lots of people don't want to take the risk and bypass the radiator cooler. So whatever you wish to do is good.
Old 10-15-2019, 12:16 PM #5
The thermostat alone is very easy. Even the rest is fairly straightforward. The only 'gotcha' is putting the thermostat jiggle valve down instead of up like it is on basically every other engine.
Hopefully it isn't a head gasket issue. Check the easy stuff first (full of coolant, etc.) and go from there.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-15-2019, 05:15 PM #6
nissanh nissanh is offline
How old is the radiator? It is probably clogged with sediments.
Old 10-15-2019, 05:57 PM #7
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
These videos might help you out:
Old 10-16-2019, 10:09 AM #8
DaveL DaveL is offline
DaveL is on a distinguished road
Had an older Camry years ago that suddenly started overheating at highway speeds. Would cool down and indicate normal at idle and slower speeds. After replacing the thermostat and flushing the radiator made no difference someone suggested the radiator hoses. They postulated that at high speeds the weak older lower radiator hose was collapsing due to the higher suction pressure. A new hose solved the issue.
DaveL is offline   Reply With QuoteReply With Quote
Old 10-16-2019, 10:14 AM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Also I forgot to mention, verify your radiator fins are clean. We had a user having issues with overheating and his radiator itself cooling fins were plugged with debris and sediment..;)
Old 10-16-2019, 12:04 PM #10
Along those lines, a slightly leaking radiator cap can do the same thing. Go OEM on the radiator cap, it is the only one that is guaranteed to work...
Old 10-16-2019, 06:24 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The pressured system should keep the rad lines from trying to fold in. Very good thought on the Radiator cap Charlie as that would cause issues. Especially if the rad was changed and still has the oem original cap with a bad defective seal on or some A/M junk one.
Old 10-16-2019, 07:08 PM #12
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Don't go e-fan unless you have a reason to, this is coming from an e-fan user. It makes the system more complicated. Mechanical fan will always work, even if the clutch seizes it will still work great just always be on lol.
Were you planning on doing the timing belt anyway or are you doing the timing belt because you figured on changing the water pump, which you figured on changing because of the overheating issue? If you are, start with just the radiator and hoses and see if that's all it was. Changing out a radiator is waaaay easier than an entire timing belt change.
326WHP 347TQ
Old 10-16-2019, 07:49 PM #13
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I agree with gamefreakgc. Stick with the standard original fan which is 80's tech that is dead on reliable.
I haven't seen a OEM toyota water pump fail that didn't leak on any Toyota cause a heat issues. Mostly when the bearings fail and they start spitting antifreeze when the heat issues start with then.
I have seen stuck thermostats, stop leak filled engine water jackets, plugged or debris clogged radiators both externally and internally and non pressurized cooling systems have heat issues.
So if your not loosing any coolant on the ground and its not in your engine oil, when you start up the engine does it have lots of white smoke?? If so, the coolant could be leaking into the cylinders from a bad or leaking heat gasket. However, you would see this in coolant level dropping too.
Old 10-16-2019, 08:34 PM #14
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
If you don't already have an Ultra-Gauge MX- with trans temp built in for 99 and newer T4R's; I highly recommend them. Spiker Engineering, a member here, has a great mount for it too.
UltraGauge, OBD II Scan Tool & Information Center
Ultragauge Mount - Spiker Engineering
Thread with more info and putting the right code in for the trans temp reader.
Ultragauge 1.3 MX Question - Trans Temp??
For under $130 total you can set alarms to sound and alert you to an overheating condition before it does damage to your engine and/or transmission. Very inexpensive permanent insurance you can move to another vehicle if you end up selling the current one.
This won't help you fix your current issue but it will help you or anyone prevent a major engine failure. I'm also one of those who bypassed the radiator with an external trans cooler so I never have to worry about the dreaded pink milkshake.
I'm so impressed with these little multi-gauges that I bought one for my 99 Mustang GT so I can monitor temps and get alarms for it too. The added 140 or so possible sensor readings are icing on the cake. I use the MPH, MPG average, and MPG instant quite a bit too.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 09:36 PM #15
Sorry for the delay in responding, lots of people leaving at work, so we are a little thin.
Not seeing any white smoke on start up. What it turned out to be was little to no antifreeze. Bought this from a guy who said it just had the head gaskets replaced. Not sure I buy that now.
No puddling anywhere of any kind. I refilled the radiator and havent overheated since. Still no puddles.
She has 250k on her and dont know if the timing belt has ever been changed so figured why not and do the water pump, thermostat, etc... still havent done this yet, mind you.
Figured I would throw more wet spaghetti at you guys and see what you think. Thanks again for the input.
fan , hoses , overheating , trans , week
1994 overheating issue 4runnerBrett Classic T4Rs 7 08-26-2018 01:19 PM
'93 overheating issue please help me :( davehaynes1 Classic T4Rs 13 07-31-2018 05:28 PM
Overheating Issue (04' V6) the_josh Problems & Warranty Issues 2 10-08-2016 07:41 AM
Weird overheating issue Steve8v92 Classic T4Rs 3 04-05-2009 02:09 PM
