01-15-2013, 04:24 AM
Wheel Spacers Anyone?
Anyone have a suggestion of the best place to buy some wheel spacers for the 4Runner? And feel free to put some photos up of your rig with spacers!
01-15-2013, 04:32 AM
I use AllPro 1.5" on the front of mine.. Really like them. Any should work fine but I would stick with a company that has a reputable name. Be sure you know if you need "hub"centric or "lug"centric when you order them...
84 4runner, 37's, about 6\" lift, lockers F/R, 5.29's, 22r
03 Grand Cherokee
02 Jetta 1.8T
01-15-2013, 04:52 AM
from me..brand new spidertrax 1.25 ,185.00 plus shipping.
01-15-2013, 04:54 AM
Location: Where the sun shines and the people are shady- CA
Just keep an eye out in the classifieds, that's what I did and came up on spidertrax 1.25 spacers. I like the look a lot. The spidertrax spacers have a really good reputation as well.
01-15-2013, 04:59 AM
Dumb question, and hopefully I didn't screw myself. But I just bought a set of used spacers. I forgot to ask if they were hub centric or not. Is there a way of telling? And how do I know what my wheels are? I have FJ80 wheels the acorn style.
Giant Motosports
01-15-2013, 05:05 AM
Hubcentric should have ring around the outside of the "O" for the rim to "rest" on
01-15-2013, 05:16 AM
Hubcentric use the hub itself to align the wheel (auto locking hubs) lugcentric use the lugs to align the wheel (manual hubs) so if you shift into 4wheel and dont need to get out and turn your hublock, you want hubcentric.. But lug centric normally works with either.. The rim isnt what makes a diff.. Its the hub itself. Hub centric has a smaller inside diameter to fit snug around the hub.
03 Grand Cherokee
02 Jetta 1.8T
01-15-2013, 03:09 PM
I'm running Spidertrax 1.25" right now, but in the past I have run some from Motorsport Tech in .75". Both are high quality. Like others have said, make sure you get hub-centric. This will avoid vibrations on the highway and will allow the hub area to carry the weight instead of the lugs.
2004 Limited 4WD / 2014 FJ Trail Team Springs and Shocks + Daystar 2.5" F and Fat Bob's 2" R / 1/2" Body Lift / Level 8 MK6 17x9 -12 / BFG All Terrain KO 265/70/17 / Hella 500 FF / Yakima Load Warrior
01-15-2013, 03:29 PM
https://www.allprooffroad.com/84894runnerdrivetrain/19
i got my 1.5" from here and they are perfect they make abig difference not bad pricing either
06' Limted v6, NWTI Plate front bumper, 1.5" lift - coils on front / spacers in back, BFG all-terrain tires, yakima roof rack, LED light bar
00' SR5, deck+isr, 33x12.5 procomp, 2.5 susp lift, 2" body, cb, rear sway removed SOLD
01-15-2013, 04:23 PM
Originally Posted by muttbutt
Make a big difference in what? Rubbing? Stance? Can you rub the wheels on the fenders at compression? I'm doing a lift and 285's right now with new UCA's, jst curious.
--Anyone please jump in...
I am trying to figure out why I might need them. I don't mind getting them, but I should have a good reason. I could see a reason for the Tundra Brake upgrade on my stock three spoke wheels, but i can do the 199's instead. Right now my rotors are straight and plenty of stopping power.
01-15-2013, 06:33 PM
I'm running 1.25" Spidertrax spacers on just my front 2 wheels. I originally only planned on running them temporarily until I bought new wheels that would fit over the big Tundra calipers, but after having them on for a while, I've found I like the look and the ride.
Because I do a lot of quick cornering, I like the extra wheel base it gives me.
Papa John's delivery driver... Jimmy John's has nothing on me!
01-15-2013, 06:36 PM
I should mention, I will occasionally get rubbing on the right front if fully turned and flexed. I'm running 275/75/16 Cooper ATP's, but an old stock suspension (no lift), which is next on my list of upgrades.
01-15-2013, 11:27 PM
My tires rubbed on the control arm baaaaaad before I got them, and my wheels were so tucked in under my body it was stupid but now no rubbing at all and my stance looks much better now
01-16-2013, 12:39 AM
Not a hater, but that is nearly retail price. Wheelersoffroad.com sells them for $196 plus shipping, and no sales tax. Used (even when new in an opened box) needs to be cheaper than that, I'm just sayin'.
2000 Limited: Toytec Superflex, 255/85-16, Lil Skips gas tank skid, SaVage rear bumper and skids, BAMF Sliders
2006 SR5: FJC Coilovers +2", Toytec Superflex, 255/85-16
Sold: 2017 TRD OffRoad Prem (this rig was too nice for me!)
01-16-2013, 12:53 AM
This is exactly what was going on with mine. But if you're getting aftermarket uca's you might not need the spacers FYI.
