Old 02-12-2020, 11:25 AM #1
judoant's Avatar
judoant judoant is offline
judoant is on a distinguished road
judoant's Avatar
battery cable replacement
I am in the process of putting new mil spec terminals on my rig. I also would like to replace the negative grounds off the battery while I am at it. Can I use this for the ground to the engine? They seem like a good price for 2awg wire. I plan to use 8awg car audio ground wire for the ground to the fender.
6 Ft. Inverter Cable Set - #2 AWG
99 4 Runner Limited. 3" Toytec Ultimate lift with SuperFlex rear coils. 231mm Tundra calipers. Rear diff breather extension. 285/75-16 Nitto Trail Grapplers. Savage full skids & sliders w/ kickout. ISR mod. LED gauges. Shrockworks front plate bumper w/ loop. 4xInnovations rear plate bumper.
judoant is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 01:05 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Could yet kinda long, how about this ebay product, you choose the lenght...
2 AWG Gauge 5/16" Lug Battery Cable Inverter Cables Solar, RV, Car, Golf , .... | eBay
Old 02-12-2020, 02:32 PM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
It is very simple to create your own cables, go with pure copper ring terminals and buy some solder and a small propane torch. I made my own around 3 years ago and they have held up great. Just a thought.
Otherwise yeah, shorter is better. Shorter cables have less resistance and voltage drop than longer ones. You want to make sure they are pure copper strand wiring, not solid wire or aluminum strand wires.
326WHP 347TQ
Old 02-16-2020, 08:31 AM #4
Mgyver1's Avatar
Mgyver1 Mgyver1 is online now
Mgyver1 is on a distinguished road
Mgyver1's Avatar
I agree on making your own, but I’ve switched from being a solder guy to a crimp guy after seeing this (it’s a little dry but there’s good info mixed in):
YouTube
2000 Limited. Lifted....finally!
www.OverlandNV.com
Mgyver1 is online now   Reply With QuoteReply With Quote
Old 02-16-2020, 09:27 AM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Shorter is better. Or you can increase the gauge size to reduce resistance as well [ wire diameter wider ] welding cables sizes.
Ampacity Charts - Cerrowire
Old 02-16-2020, 08:17 PM #6
nissanh nissanh is offline
Run two wires
Or run two wires parallel to lower the resistance.
I like the oem ground wire terminal over other terminals.
Old 02-16-2020, 09:21 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
That will work as well. Provided you keep the diameters of the 2 new wires half or greater then the original wires diameter. So the wires can handle the same amount of current or greater amount.
battery , engine , ground , price , wire
OEM Battery Cable Size and Terminal Replacement In later model 5th Gen mscot 5th gen T4Rs 15 02-24-2018 10:10 PM
Exact battery cable lengths for OME replacement with OEM battery oriented posts. Majindan 3rd gen T4Rs 3 11-20-2017 02:57 PM
HELP! Battery Cable not long enough for new battery TerraCrawler General Discussions 11 08-02-2017 10:24 PM
Battery Cable Harness Help T4Rfirefighter 3rd gen T4Rs 3 03-07-2015 08:21 PM
+ Battery Cable Replacement Here2There 3rd gen T4Rs 12 12-19-2010 03:08 PM
