Old 11-19-2019, 09:17 PM #1
Garcia9876 Garcia9876 is offline
Garcia9876 is on a distinguished road
I Got a MISFIRE P0301
I have a 3rz-fe engine 1999 4runner
I got a P0301 code the day before my truck was shaking . But I removed the spark plug and what I can do.
The picture I show you the spark plug is from cylinder #1
I Got a MISFIRE P0301-f7399113-168c-4f41-839a-3cbb0cad4234-jpg
Garcia9876 is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 10:39 PM #2
T.Tech T.Tech is offline
T.Tech is on a distinguished road
from the looks of the spark plug it seems the tube seals are leaking into the tube possibly causing the plug wire to short out and not having proper spark. If you have a scan tool try putting that plug in another cylinder and swapping the wire with different cylinder and see if it follows the wire, plug it remains in the same cylinder. The picture that you have the electrode isn’t visible to look at.
T.Tech is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 05:11 PM #3
enginelover enginelover is offline
enginelover is on a distinguished road
Google brought me here when I looked up information for a P0300 (multiple misfire) and P0301 (front cylinder 1 misfire) which happened today in my 3RZ-FE with 200K miles.
This thread doesn't show what plugs to use so I will let others know Google says the spec for the plugs is probably Nippon Denso K16R-U, or NGK BKR5EYA, 0.031", 14ft-lb.
Some say never use Bosch plugs in the 3RZ-FE.
HTH
enginelover is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 06:59 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
HTH
Spark plugs need to be changed at the proper intervals. They dont last forever and are wear items. Standard change intervals are lower mileage then a iridium / platinum etc plugs.
Old 01-28-2020, 07:48 PM #5
I just tried to remove the wire and it was so stuck on the plug that first the boot broke, then the plastic broke, then the wire pulled out.
To test compression, I tried to remove the #1 (front) plug using a standard deep socket on a 12" extension bar for both 13/16ths (21mm) and 5/8ths (16mm) but one was too fat to even get into the spark plug hole (which is DEEP!) and the other isn't the right size because it's just spinning.
Anyone know what special tool and which sizes are needed to get at these spark plugs?
I can assume the cylinder head female threads are 14mm (which is what the compression gauge uses anyways) but a 5/8ths deep socket just spins and a 13/16 deep socket won't even fit into the hole opening on the valve cover.
If you need photos I can snap them but I don't know how to upload them yet.
Old 01-28-2020, 08:41 PM #6
spartacus's Avatar
spartacus spartacus is online now
spartacus's Avatar
5/8 should work or you can buy the magnetic socket from parts store
I Got a MISFIRE P0301-20200128_174447-jpg
spartacus is online now   Reply With QuoteReply With Quote
Old 01-28-2020, 11:05 PM #7
Thanks for clarifying that it's a 5/8ths socket.
Googls says there are 3 fundamental passenger vehicle sizes.
1. 10mm threads, 5/8ths or 16mm socket
2. 14mm threads, 13/16ths or 21mm socket (but sometimes 5/8ths)
3. 18mm threads, 15/16ths or 24mm socket (but sometimes 13/16ths)
My 5/8th's deep socket is 2-1/2 inches long but it just spins so 2-1/2 inches must not be deep enough. I'll pick up a deeper deep socket tomorrow. Thanks.
Is it 14mm the threads in the 3RZ-FE engine (that's what my screw-in compression gauge is, where the press-fit compression gauge can't fit because of the deepness of the location).
I don't know if it will show up when I hit submit but in the image I just tried to upload, the yellow arrows point to where the wire loom broke, which I think is Toyota Part Number 90919-22387 ($184.99), and the red arrow points to the 2-12 inch long 5/8ths inch deep socket that turns out to be too short.
I Got a MISFIRE P0301-plugs01-jpg
Old 01-29-2020, 09:51 AM #8
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Are you using regular sockets or spark plug sockets? Spark plug sockets have a piece of rubber in them to grip the spark plug to pull it out once it's un-threaded. When you buy the socket ask to see a spark plug for your vehicle and engine and verify it fits before leaving.
Old 01-29-2020, 11:01 AM #9
spartacus's Avatar
spartacus's Avatar
you can buy a ngk wire set for $40.00 amazon
Amazon.com: NGK RC-TX67 Spark Plug Wire Set: Automotive
Old 01-29-2020, 09:18 PM #10
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
Probably have metal portion of wire ( clip to top of plug ) still on spark plug..making socket "to short".
Grab some needle nose pliers or vise grip and get it off.
SaulG is offline   Reply With QuoteReply With Quote
Old 01-29-2020, 11:38 PM #11
That was the problem! No matter how gentle I tried to pry up on the spark plug boot, EVERY plug wire broke off at the top of the sparkplug.
That little tiny broken off metal tip (yellow arrow) was what had prevented the 5/8ths inch spark plug socket from fitting on the plug hex.
In the photo below the red arrow points to the plastic wiring loom holder that was so brittle it broke. Are they easy to replace?
I Got a MISFIRE P0301-plugs02-jpg
Old 01-30-2020, 12:00 AM #12
Here is a closer look (red arrow) at the other wiring loom clip that was so brittle it broke off at the valve cover.
Do I replace it by removing the valve cover or can it be replaced without removing the valve cover?
I Got a MISFIRE P0301-plugs03-jpg
Old 01-30-2020, 12:29 AM #13
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
They're just plastic press fit you can gouge/dig them out and order new.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 01-30-2020, 03:33 AM #14
That's good news! Thanks.
I don't know the full history where I won't have that valve cover off until I figure out how to tell if the valves need adjusting.
Certainly the plugs were long overdue!
I Got a MISFIRE P0301-plugs04-jpg
Old 01-30-2020, 03:14 PM #15
Greaser Greaser is offline
Greaser is on a distinguished road
I had a very similar experience with my own truck just last weekend.
IMO if the plug wire connector breaks off in the boot and is stuck in the plug there's a good chance it was badly degraded where the connector clamps to the wire, either partially or completely severed and arc'ing inside the boot and causing all sorts of issues.
Getting the connector off the plug is a pain since it renders the socket/extention useless, but I had luck using a large screwdriver in the end of the socket. There's risk involved here as once you drop the socket onto the plug with the stuck connector you can no longer connect the socket extension to the socket, so it's sortof stuck in there. I was able to stuff a screwdriver into the socket and loosen/remove the plug that way. Looks like you figured it out but maybe this will help the next poor sap.
With new plugs and wires (jesus I think those might have been the originals??) my codes/misfires/rough idle is gone, the truck starts, sounds and runs WAY better, so you have that to look forward to.
2000 SR5
2015 GTI
Greaser is offline   Reply With QuoteReply With Quote
p0301 , plug , removed , show , spark
P0301 Misfire - Fuel Pump on the Way Out? beefsix 3rd gen T4Rs 33 01-28-2020 03:13 PM
P0301 misfire, replaced "everything", still a misfire, but no CEL...what next? Heyduke 3rd gen T4Rs 7 06-25-2018 10:50 AM
P0301 when hot Brian1973 3rd gen T4Rs 8 07-28-2017 10:52 PM
Multi misfire P0300, P0301, P0302, P0303 kakarot 3rd gen T4Rs 3 12-24-2012 11:36 PM
P0301 code snowninja 3rd gen T4Rs 15 12-13-2012 01:24 AM
