Old 01-27-2020, 04:01 PM #16
Jidaran's Avatar
Jidaran Jidaran is offline
Jidaran will become famous soon enough
Jidaran's Avatar
Originally Posted by plcfcng View Post
Took the wifes 2001 threw the car wash today. For got to hit the switch to send the Radio Antenna down. I'm sure I'm not the first to do this one. Got a new one on order
this is probably a bone head question - but the switch you have is a mod, right? there's no stock antenna switch in my truck i've somehow missed..... right?
2002 Limited 4Runner
2001 Jeep Cherokee
Jidaran is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 04:03 PM #17
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Washed my switch pro power module in my engine bay. Then I bought a new one and build a cover for it. $$$$$$$$$$$$$$
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 04:10 PM #18
Rolling_Thunder Rolling_Thunder is offline
Rolling_Thunder is on a distinguished road
Was fighting the transmission when I did the 5 speed swap... had done the entire swap in one day, in a garage, when it was -3* I wouldnt get the bellhousing to seat against the block and fought and fought until I said F*** It... in the process I got a little heated and ended up breaking a finger as I fought it --- Pull the whole thing back out and saw the dowel in the block... then noticed the dowel that had been stuck in the bellhousing.... in the same hole -
Rolling_Thunder is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 04:18 PM #19
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Originally Posted by TonyB66 View Post
Odd. I've had the Borla ProXS Muffler 40665 for a couple years now, and really like it. Wife and kids do also.
Is it bigger than the 40664?
Old 01-27-2020, 04:34 PM #20
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
Would have bet serious money that the clattering sound under my truck was a dying catalytic converter, so I cut it out with my sawzall (the bolts were seized and I couldn't get get good leverage on them with the cat in the way).
Turns out the noise was the rear DS front u-joint (I swear I checked them before). So I ****ed up a good OEM cat for nothing and had to install a Walker direct fit unit.
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 04:44 PM #21
levee-11's Avatar
levee-11 levee-11 is offline
Real Name: Levi
levee-11 is on a distinguished road
levee-11's Avatar
Real Name: Levi
Took out the front passenger seat, and when putting it back in cross threaded the bolt and nut like an idiot, and in the process of trying to fix it snapped the tack welded bolt off the body with the bolt in. This nut was like the only one hidden in a small metal channel in the body, so I had to drill a hole underneath to get to the inside of the channel to get the nut off the bolt, and ended up fixing with a new bolt and nut and plugging the hole
2002 Thundercloud Limited 3.4 4x4 M/T (Manual Swapped)
1998 Desert Dune SR5 3.4 4x4 A/T (Totalled, R.I.P)
levee-11 is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 04:45 PM #22
spartacus's Avatar
spartacus's Avatar
Broke the overflow nipple coming out of the radiator filler neck while doing the timing belt job cause I didn't remove the radiator after draining.
Old 01-27-2020, 09:11 PM #23
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
yes it is a mod real easy to do I just ordered a switch on amazon and put it in on the power wire on the new stereo. I put it out of sight under the cigarette lighter on the shifter bezel. I was talking with the wife and wasn't paying attention as we went threw the Car Wash.
plcfcng is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 02:53 AM #24
Theallsmith Theallsmith is offline
Theallsmith is on a distinguished road
Replaced a rad support with frame damage
Bought my 99 used with frame damage (that I didn't notice when purchasing) and replaced the radiator support. My hood is now off and wont close. I need a new grill and headlight assemblies, and a new bumper.
Plus the bumper that goes to the frame is non-existent and probably could not bolt a new one on anyway because its off 1/2 inch.
But hey, timing is currently brand new at 237789 miles!
Theallsmith is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 09:20 AM #25
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE will become famous soon enough
STI_MECE's Avatar
I bought the 4runner.
2000 SR5 4x2 Resto/Maintenance
STI_MECE is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 10:20 AM #26
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
Originally Posted by RunningForNow View Post
I’m on a similar boat. I have a Borla Pro XS installed on mine. The drone isn’t terrible, but it’s there, and I’m not sure I want to put up with that.
I have a borla XR-1 with no drone! Well a tad bit now that I have 33s but it will go back to none once I regear.
VernySanders is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 12:20 PM #27
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy has a spectacular aura about Wedgy has a spectacular aura about
Wedgy's Avatar
Originally Posted by jross20 View Post
Just installed a borla 40664... The drone makes me want to shoot myself... Somehow I suck at this haha
My brother in law put one on my sisters Explorer and it drove her crazy so she made him put in an all new sound system and sub to drown it out.
Wedgy is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 01:14 PM #28
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
Exact same dimensions. However, the Borla 40665 Turbo XL has a 2.5" inlet/outlet, compared to 2.25".
In experimenting with other vehicles, that did make a difference...
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 01:15 PM #29
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Oh come on. Dont blame the Vehicle for PO messing them up...;)
Old 01-28-2020, 01:21 PM #30
Ripper238's Avatar
Ripper238's Avatar
Pulled into a parking space that had a shopping cart partly in the space. Thought i would get close and move it. Well i wedged it against the curb and the fender. I tried to pull it away and scratched the front fender.
antenna , order , radio , send , switch
My 91 4runner won't move! Valkyrie_4Runner General Discussions 0 12-23-2017 05:49 PM
4Runner won't move kevin8629 3rd gen T4Rs 8 12-06-2016 09:20 PM
FS Central NJ: 2000 4Runner Limited 103k miles diff lock bone stock USSEnterprise For Sale: Vehicles 2 08-20-2015 07:50 PM
What a bone head!! (I also have a question) 4RUNNERgeo 3rd gen T4Rs 0 11-27-2011 11:21 PM
