Old 01-30-2020, 05:40 PM #1
TheShowtime TheShowtime is offline
TheShowtime is on a distinguished road
Rpm fluctuates in park
Hey guys i notice sometimes in park when in idle my rpm goes up and down slightly like I’m stepping on the gas lightly. Only when I’m in park I notice while I was getting gas today. I cleaned the throttle body and maf recently. Spark plug and wires are also fairly new. Anyone know what could be causing that? Thanks
TheShowtime is offline   Reply With QuoteReply With Quote
Old 01-30-2020, 05:55 PM #2
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
First guess is the Idle Air Control valve that lives on the bottom of the throttle body. If you're not careful with TB cleaning, you can flush a bunch of crud in there and cause issues.
Head on over to mtbtims youtube channel and look for his video(s) (I think there are 2) on this topic for more detailed info.
Brian. is offline   Reply With QuoteReply With Quote
Old 01-30-2020, 06:09 PM #3
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
Could also be the a/c compressor cutting in and out if you are in either defrost mode. Try changing settings.
There is a simple mod to disable if this is the cause.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 01-30-2020, 06:27 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
How much of an rpm fluctuation are we talking about here?
Old 01-30-2020, 09:03 PM #5
Revs up to 1500 rpm then goes back down. It’s not always like that just sometimes.
I noticed the idle is rough when I don’t drive it for a couple days and start it up also. But only for a min or two then goes back to normal.
Old 01-30-2020, 09:07 PM #6
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
This post isn’t going to help anyone, but back in the day when I got my first car (Honda Accord) I installed a pretty aggressive stereo with a large electrical load…
On cold days when the engine was high idle, anytime the bass hit the RPMs dropped like 200-300 RPM.
Probably starving the electrical system with spiked voltage drops… either way, I was rather pleased with myself.
Old 01-30-2020, 09:42 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
So sometimes it rough idles at cold?? As mostly rough idle at cold can be a vaccuum leak. Maybe I missed it and my apologies but what year is this 3rd gen?
Old 01-30-2020, 09:46 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes you took the current level below a threshold and starved your ignition, fuel pump and the entire electrical system for current.
My one buddy had a covertable ford ranger when we were in college. When his bass hit at idle it would kill the engine. ;) but this is way off topic of the subject at hand.
Old 01-30-2020, 11:06 PM #9
It’s a 2001 3.4 V6
Old 01-30-2020, 11:33 PM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
It’s a 2001 3.4 V6
Ah. Throttle by wire hybrids. [ 2001 2002]
Those throttle bodys are more complex. Quite possible it all needs clean and you have to be careful. Those are actually servo controlled and the throttle cable is a fail safe. Etc.
However, they are also more modern. As everything newer is throttle by wire.
Old 01-31-2020, 06:45 PM #11
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
My RPM fluctuations were not that large only 25 to 50 rpm at idle in drive. I happen to have my Charging light come on so I replaced the brushes in my alternator. Now my RPM is steady as a rock. Must have been a voltage issue. not a 1500 RPM difference but something to what out for.
plcfcng is offline   Reply With QuoteReply With Quote
Old 02-01-2020, 01:22 AM #12
Ryan and Jerri's Avatar
Ryan and Jerri Ryan and Jerri is offline
Real Name: Real Name
Ryan and Jerri is on a distinguished road
High fluctuations for voltage drops but ya maybe start there. Test your alternator and battery. And clean your battery terminals while you're at it. Couldn't hurt.
1999 Hilux Surf SSR-X, 140xxx kms, 4x4, 2.7L, AT, RHD, 17" Sequoia wheels, 10 ply Goodyear Wrangler A/T tires. Stock. Minty. Daily driven.
Ryan and Jerri is offline   Reply With QuoteReply With Quote
gas , i’m , notice , park , rpm
Had to park next to it... PWD4R Gallery 14 08-05-2017 10:35 AM
1984 4runner RPM fluctuates then stalls izzy434 Classic T4Rs 4 12-10-2015 05:04 PM
Idle fluctuates - when braking, > 20 mph moabjunkie 3rd gen T4Rs 1 12-19-2014 08:46 PM
that's how you park a 5th gen. TC4Rnr General Discussions 39 06-07-2010 04:45 PM
