Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 02-18-2020, 06:39 PM #1
G_Raw's Avatar
G_Raw G_Raw is offline
Member
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
Member
G_Raw's Avatar
Flashing air bag light
Hey all. This morning I moved my truck from the street to my driveway and noticed that my airbag light on my cluster is flashing. It was parked for an hour or so before I drove to run an errand, the light did not turn on for this drive. Leaving that parking lot and every drive from there on has had the light flashing again.
Help me trouble shoot this...
I've checked the connections under both front seat and they all seem to be connected. Should i clean the prongs on these connections? If so which are for sure the airbag sensors? I can find it in my manual...
I'm now thinking it the clock spring/ spiral cable ( whatever you want to call it)
Cruise control seems to be working, horn definately working.
Thanks for and insight.
G_Raw is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 07:07 PM #2
brillo_76's Avatar
brillo_76 brillo_76 is offline
Elite Member
Real Name: Jon
brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute
Elite Member
brillo_76's Avatar
Real Name: Jon
That light will continue to flash if your airbag system has an issue. I bumped the connector behind the glovebox for the air bag once. My light flashed. Once I verified everything was snug and tight. It never flashed again.
Any recent work in the areas where the seat wiring is. The bags or the body sensors themselves?
As if you did I would take the neg terminal off and verify everything is good so you don't accidentally set your bags off when checking all the connections.
I could be wrong but that system has all the self checks in it and will only flash when there is an issue with something.
Sent from my SM-J337V using Tapatalk
__________________
7 3rd gens listed in the build thread (2 are parts mobiles)
Build Thread: https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer: https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information: https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
brillo_76 is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 07:12 PM #3
G_Raw's Avatar
Member
Member
G_Raw's Avatar
I haven't done anything behind the glove, but have opened and closed it a bunch. I cleaned my broken window glass with a shop vac last month. This included sticking vacuum hose under seats. My passenger seat also has a sub the hits decent, maybe enough to loosen a connector?
Old 02-18-2020, 07:17 PM #4
brillo_76's Avatar
Elite Member
Real Name: Jon
Elite Member
brillo_76's Avatar
Real Name: Jon
Mostly though it dosent stop flashing or the airbag stay on if the system has a problem.
You can check those wires are making good connections but if the light goes out the system is self checking ok. :/
You only seen this once? I guess keep an eye on it and see how it behaves.
__________________
Old 02-18-2020, 08:18 PM #5
gamefreakgc's Avatar
gamefreakgc gamefreakgc is offline
Elite Member
Real Name: Jerod
gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future
Elite Member
Real Name: Jerod
The airbag is a small explosive device, please be careful. Normally I don't disconnect the battery when I am working on my car but DEFINITELY do it before checking the wiring on the air bag system!
The seat occupancy sensor are indeed the sensors on when to deploy the front airbags. You'll also want to check the wiring connection of the dash airbag by opening the glove box and next to the light to the left (yes, your glove box does have a light it's probably just burnt out) you'll see a hatch. Pop that guy open and you'll see a yellow connection. Yellow designates an airbag circuit and should be handled with care. Make sure it's snug and not dried out, it should be caked up good with grease. If you have a newer 01-02 (may also apply to 99-00 though not sure) you also have the front seatbelts with miniature air bags that lock the seat belt instantly upon impact. You'll have to remove the lower door trim pieces from all four doors and the lower B pillar trim to get to those connectors.
In the engine bay, you'll find an Air Bag Sensor that looks something like this:
There are two bolted to the frame above the wheels. One is hidden below the air box, the other just below the battery tray. Make sure those are also clean & connected.
That should be enough to figure out where the issue is.
__________________
'98 4Runner SR5 - 4x4 JDM 5VZ-FE Supercharged - 249K miles.
326WHP 347TQ
AEM F/IC 6, 11 PSI, 3" Intake and 3" Exhaust
Jerod's Supercharged T[u]RD Build
gamefreakgc is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 08:21 PM #6
G_Raw's Avatar
Member
Member
G_Raw's Avatar
Light doesn't stop flashing. On 3 seconds off 2 seconds as long as power is on.
Connections all appear good. Did a second check. Anyone know where the wires run to the passenger airbag?
I removed and replaced 2 screws I use to keep my phone mount from bouncing. I'm wondering if I was lucky the first time I mounted but not so lucky when I adjusted the mounts screws yesterday. That is the only thing I can think of... see photo.i can't imagine wires run here...
Flashing air bag light-15820715617781401525078-jpg
Old 02-19-2020, 08:06 PM #7
Elite Member
Real Name: Jerod
Elite Member
Real Name: Jerod
No, they don't run there. From the passenger airbag, there's the connection I mentioned above and then they run down from there to the base of the center dash. If you remove the center dash bezel (not as hard as it looks but yours will probably disintegrate if you try) and remove the shifter trim bezel, you'll find the ABS Assembly module bolted on the bottom on the body, covered by a piece of clear but probably very dirty plastic. All air bags and sensors connect to this module:
They normally have to replaced only after an accident and air bags have deployed but yours might have gone bad. I am unaware of any testing procedure though. The are held in place by large Torx screws which are notorious for stripping. I've removed 5 of them and 3 of them stripped, 2 so bad I never actually got them out.
Between the sensors in the engine bay, the seat belts, the assembly module and the air bags themselves, that's the entire circuit.
__________________
326WHP 347TQ
Reply
Tags
airbag , connections , drive , flashing , light
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
A/C light flashing?? webshot Problems & Warranty Issues 138 07-26-2020 11:37 AM
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
Check Engine Light and Skid light flashing, truck runs rough tkeratt 5th gen T4Rs 7 07-04-2017 08:44 PM
'O/D' Light Flashing - Help! 2fast 4th Gen T4Rs 4 03-15-2008 06:26 PM
Flashing A\C Light fix a77boy Problems & Warranty Issues 0 03-14-2007 10:34 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
