Old 05-14-2020, 10:02 PM #151
HiLife HiLife is offline
Engine load?
Old 05-14-2020, 11:38 PM #152
Add tps
Old 05-15-2020, 05:31 PM #153
sweet88gt's Avatar
sweet88gt sweet88gt is offline
sweet88gt is on a distinguished road
sweet88gt's Avatar
YouTube
Here is a datalog
Who knows if I did it right.
1997 3.4 Limited 4x4 197xxx miles
sweet88gt is offline   Reply With QuoteReply With Quote
Old 05-19-2020, 03:53 PM #154
sweet88gt's Avatar
sweet88gt's Avatar
So looks like I have come to a dead end. Im about out of my area of expertise on this.
Need to find a mechanic that has a good scanner and who can figure it out.
If anyone has an input on that catalog deal Im all ears.
Old 05-20-2020, 12:29 AM #155
Gull81 Gull81 is offline
Gull81 is on a distinguished road
you have checked for a vacuum leak and found nothing correct - I have heard you can spray brake cleaner / other flammable aerosols around the vacuum lines to check for this. Perhaps the O2 sensors are bad ( I don't think they are terribly expensive or hard to replace. Have you changed out the fuel filter? Just swining in the dark.
Gull81 is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 12:58 AM #156
From another thread where the fuel filter apparently fixed an idle issue. Probably won't help, but at this point, if I am not mistaken you have already checked: Plugs, Wires, TPS, IAC, Fuel Pressure, Fuel Injectors?, vacuum hoses, MAF. May be worth it to see if its one of these weird gremlins ( O2 sensor, fuel filter), before moving on to ECU stuff.
I understand this is an old thread but i figured for the benefit of the next person that is searching for a solution, I'd add my insights here.
I had done a valve cover gasket job and replaced the air boot due to a tear. While I had the throttle body off I cleaned it along with IACV. I replaced the PCV as well. When I got it back together, my idle was high. It's been that way for about a year. Usually when the truck would warm up after driving it around, the idle would return to the normal range. I tried resetting the ECU multiple times. I replaced the MAF. Cleaned the MAF later. Replaced the air K&N air filter. Removed the throttle body and IAC again. Everything looked good. I checked the vacuum hoses looking for leaks. Nothing there either.
Today, i installed a new fuel filter and VOILA! No more high idle. Note I didn't even remove the battery ground to do this. I just unplugged the connection to the fuel pump, ran the fuel line dry (wouldn't start actually) and replaced the filter. Happy to report no high idle. If the problem should return, I will report back.
Hope this helps someone down the road
Old 05-20-2020, 04:25 AM #157
Your LTFT for bank 1 is all over the place. Anywhere from 3 to almost 20. That’s your missfire and P0171 codes.
You replaced the injectors correct? If so you may have gotten a bum set or they aren’t seated in the intake correctly.
Or there is a sensor not providing proper data to the ECU.
Old 05-27-2020, 02:02 PM #158
sweet88gt's Avatar
sweet88gt's Avatar
So I let this thing sit and walked away from it to clear my mind.
Test drive again and now no misfire codes in the 30 min ride with about 10 miles of driving. Start and stop let it sit in parking lot and such.
So no misfire codes
Just the P0171
I haven't done anything to try to fix. My guess now is a vacuum leak since I have had the intake off a few times.
I have cleaned MAF so Im hoping that is good.
Ran well with no stall. Check engine light only came on right before I shut the engine off when I got home.
Old 05-27-2020, 02:03 PM #159
sweet88gt's Avatar
sweet88gt's Avatar
I had a set of injectors cleaned and installed them.
Old 05-27-2020, 02:04 PM #160
sweet88gt's Avatar
sweet88gt's Avatar
Fuel filter was the first step.
Old 05-27-2020, 02:40 PM #161
sweet88gt's Avatar
sweet88gt's Avatar
Silicone Boost Vacuum Hose
I see people using this back in the day. Anyone use this ?
Since my local parts store has crap for selection and they collapse under vac.
Old 05-27-2020, 03:25 PM #162
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I just buy the OEM ones when they split. Shouldn't be too many that are split or rotted. I think I had to replace 3 total vacuum lines on these 3.4 liters.
Lots of folks buy silicone vacuum lines.
Old 05-27-2020, 05:45 PM #163
sweet88gt's Avatar
sweet88gt's Avatar
From the dealer or aftermarket ?
Its the size and quality I can't find here.
I might check Napa
Old 05-27-2020, 07:39 PM #164
I bought the molded PCV and the hoses from the IAC to the two injector rails from the dealer.
Old 05-27-2020, 07:51 PM #165
So no misfire codes
Just the P0171
I have heard you can try and search for a vacuum leak spraying a flammable aerosol around all the hoses while the car is running. I used starter fluid and sprayed into the airbox as a positive control and barely noticed a difference, so I am not sure if its the best test.
You can also try a smoke machine, but I don't think a small leak would cause you so many issues.
check , fuel , issue , light , today
Fitting 295's Lets Talk WEAK_E90 5th gen T4Rs 17 09-10-2019 01:04 PM
Lets talk HIDs patricksheehy 4th Gen T4Rs 2 09-12-2010 05:58 PM
now lets talk capaciters 08medic4x4 Engines / Suspension / Wheels / Tires / Audio / Accessories 11 04-02-2010 01:13 AM
lets talk tires urcnj 4th Gen T4Rs 2 08-27-2008 12:14 PM
Lets talk about colors Falls 4th Gen T4Rs 28 01-03-2007 03:00 PM
