Old 03-08-2020, 11:56 AM #1
sweet88gt's Avatar
sweet88gt sweet88gt is offline
sweet88gt is on a distinguished road
sweet88gt's Avatar
Lets talk tests
So for a guy who doesn't have all of his tools (due to a move and temp housing situation) where can I find info on coil pack values and such ? Is there a thread I have missed maybe in a search ?
I had out of the blue a stalling issue. Changed fuel filter and pcv valve. Cleaned MAF and did some visual checking. Seafoam in fuel tank. Issue had not returned until today.
Today breaking up at 35mph and flashing check engine light just like before. Pull over when it died. Try to restart with no luck.
Push gas pedal to floor and it would start.
Limped it home where it ran fine the last few miles home.
No codes with my cheap tester.
Back story is the previous owner towards the end of ownership didn't do much. So most of the items are unknown. I did change the spark plugs to OEM after a check engine light came on a week after ownership. Found 5 OE style plugs and 1 odd unit as in not correct for application.
Things that need to be addressed I am guessing are plug wires coils and a test somehow to check fuel pump.
Any other things I might be missing?
1997 3.4 Limited 4x4 197xxx miles
sweet88gt is offline   Reply With QuoteReply With Quote
Old 03-08-2020, 12:06 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Flashing cel light is mostly engine misfire. They run rough when a cylinder or 2 is not firing properly.
Old 03-08-2020, 12:08 PM #3
sweet88gt's Avatar
sweet88gt's Avatar
First thought was change coil pack and wires I just don't want to throw money at it and hope.
Old 03-08-2020, 12:18 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
This may help. You can swap the coils to narrow it down. This is the info I have gathered for the V6 . I am hoping others can contribute for the 4 cylinder.
Its a work in progress.
Spark Plugs Wires and Coil Information for the 5VZ-FE
Old 03-08-2020, 12:29 PM #5
sweet88gt's Avatar
sweet88gt's Avatar
With engine misfire I should be getting a code is my only hold back on ignition.
I will check those values once they cool off. Thanks for the link
Old 03-08-2020, 12:53 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
My ran a day with a pending codes before it kicked on the CEL light.
If nothing else you can rule out those components as the cause
Old 03-08-2020, 01:26 PM #7
sweet88gt's Avatar
sweet88gt's Avatar
2 of the 3 coil have arcing and corrosion on the secondary and the wires for both show the same issues.
Thats where I will start
My meter lead doesn't reach into the boot to get a reading there.
Reading across plug is within range all 3 coils.
Old 03-08-2020, 01:47 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The boots come off..:-)
Arching and corrosion never good. Great place to start.
Old 03-08-2020, 02:04 PM #9
sweet88gt's Avatar
sweet88gt's Avatar
I figured it out like a dummy. Tunnel vision is blinding.
Old 03-08-2020, 02:42 PM #10
sweet88gt's Avatar
sweet88gt's Avatar
Coils check out good. Cleaned them up and reinstalled.
Going to try to find new boots and get wires for sure and see what that does.
Seems to me the wires from the secondary to the other side of the engine are not a very positive fit. Doesn't have a positive feel of engagement.
Wait for parts and see.
Old 03-08-2020, 08:06 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The part numbers and links to amazon boots are listed on the coil thread. :-)
Old 03-09-2020, 02:05 PM #12
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
You have an injector issue. Pop them out, take them to get cleaned and flowtested. Your check engine light flashing is what gave it away to me. I used to have the exact same issue. To test it, when the vehicle is stalling out, disconnect the battery and let the power drain from the system by attempting to turn the key. Reconnect the battery, vehicle will drive like its brand new, untill the CPU collects enough data to function properly, at which case, it will start acting up because the injector is shooting too much, or not enough, fuel through the system. This makes the check engine light flash because your rear O2 sensor is basically telling the computer "houston we've got a problem". Then the computer tries to compensate and that is when the vehicle stalls because it simply cant.
The dunes got boring because I couldn't jump. I'm not the type to enjoy someone else's vehicle. So i'm in the process of making making the dunes no longer boring. I guess that involves jumping.... A lot.
VernySanders is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 06:52 PM #13
sweet88gt's Avatar
sweet88gt's Avatar
I don't doubt anything to be wrong at this point.
I have a new set of plug wires and boots for the coils on there way. Those needed attention regardless.
I will then focus my attention to the fuel side.
With the unknown maintenance some items need to be changed just because they are over do.
Old 03-09-2020, 09:18 PM #14
Real Name: Werner
Real Name: Werner
if you want to pull a set from the junkyard its worth it in my opinion. Its 80 - 100 dollars to get them cleaned and flow tested. Usually the shop that does it will give you information on a sheet about the performance gained through the cleaning as well, quite interesting and its about a 45 minute to an hour job to swap out injectors. You can get them for about as cheap as you want at a junkyard like most people. I paid for mine though lol.
Old 03-10-2020, 09:39 AM #15
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Nobody believes in just running good Injector cleaner through their fuel systems a few times a year. Granted the OP is most likely correct and his are fine. I just dont see the sence in pulling injectors that are working.
Then you go get a set out of a junkyard and send them somewhere to be cleaned.
Those really can be cleaned yourself and some form users show how it can be done.
Oh well to each ones own. Whatever works for the users.
I just run some good fuel injector cleaner through a fuel times a year and I haven't had the need to change an injector yet in 30 years. I am not this lucky so it must actually keep them clean.
check , fuel , issue , light , today
Fitting 295's Lets Talk WEAK_E90 5th gen T4Rs 17 09-10-2019 01:04 PM
Lets talk HIDs patricksheehy 4th Gen T4Rs 2 09-12-2010 05:58 PM
now lets talk capaciters 08medic4x4 Engines / Suspension / Wheels / Tires / Audio / Accessories 11 04-02-2010 01:13 AM
lets talk tires urcnj 4th Gen T4Rs 2 08-27-2008 12:14 PM
Lets talk about colors Falls 4th Gen T4Rs 28 01-03-2007 03:00 PM
