Old 03-17-2020, 08:43 AM #1
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
A/C / Heat turns off by itself.
I'll have it on full blast and it will shut off. Intermittently. But getting worse over time. The first time it happened I just moved the switch from off to HI and immediately the unit turned off. Does this have anything to do with my pulleys? (Bearing going out) of is this electrical?
The dunes got boring because I couldn't jump. I'm not the type to enjoy someone else's vehicle. So i'm in the process of making making the dunes no longer boring. I guess that involves jumping.... A lot.
VernySanders is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 08:58 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
What MY ya' got?
I'd guess right now at electrical and it is giving a warning of where it's headed so act promptly....maybe get FSM and test controls for current, resistance, etc?
Old 03-17-2020, 09:28 AM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Full blast what? Heat or cold? AC on or off?
Old 03-17-2020, 09:49 AM #4
alumarine alumarine is online now
alumarine has a spectacular aura about alumarine has a spectacular aura about
Is it the fan that turns off?
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is online now   Reply With QuoteReply With Quote
Old 03-21-2020, 01:54 PM #5
Real Name: Werner
Real Name: Werner
its only happened on full blast, its the actual blower though, so a/c on or off hasnt made a difference, nor has the actual temp of air blowing through. It will go from full blast to zero flow, as if ive turned the actual unit off. It doesnt slowly happen though its an instant thing.
Old 03-21-2020, 01:55 PM #6
Real Name: Werner
Real Name: Werner
yes but it must be all the fans in the front of the vehicle because it happens to both sides at once.
Old 03-21-2020, 01:56 PM #7
Real Name: Werner
Real Name: Werner
Originally Posted by jgue467 View Post
What MY ya' got?
Ive got a 2000 SR5 with 260k on the clock. Thus far many of the parts I have replaced have appeared to be what came on the truck 20 years ago.
Old 03-22-2020, 01:36 AM #8
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
So---the blower motor (fan) is intermittently going on and off, right?
1. There's only one blower motor. It's under/behind the glove box.
2. I'd test the motor to find out if the motor is intermittently going off, or the power to the motor is intermittent.
3. My hunch: Likely to be intermittent power---Could be bad fan (blower) switch, or bad blower motor resistor. Or, if you're lucky, a simple wiring connector that is loose and easily pushed back into place.
Intermittent electrical failures are sometimes tedious to sort, but you have to decide the balance between the tedium of waiting for it to fail against the cost of just blindly replacing parts.
pluton is offline   Reply With QuoteReply With Quote
Old 03-24-2020, 10:29 AM #9
Real Name: Patrick
Real Name: Patrick
Here's a link to a 2000 EWD for ac operation. Dropbox - 2000 4Runner Electrical Wiring Diagram (EWD383U) - Printable - Simplify your life If you scroll down to the 3rd page it lists power flow for HI operation. Under high operation there is no power going through the blower motor resistor so that would lead me to believe you have a blower motor speed switch problem. If it was a power/ground problem then it would likely happen at other speeds than HI.
If that link doesn't work here is the whole 2000 EWD. You're looking for section 244. Dropbox - 2000 4Runner Electrical Wiring Diagram (EWD383U) - Printable - Simplify your life
Old 03-24-2020, 12:37 PM #10
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Had a bad fan once in my 2005 4runner. That's my best guess!
Captsolo is offline   Reply With QuoteReply With Quote
Old 03-24-2020, 06:14 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
+1 with Pluton. I agree as its most likely one of those things.
When the blowers go bad they mostly wine for a while. Or they will not start and have a dead spots on the armature. Once in a while, they will burn up while your driving. I had that happen in a 87 Toyota pickup truck. Filled my cab with smoke when it went. That was fun to roll the windows down when that was happening as I couldn't see a thing in less then 10 seconds. So good thing our windows are power windows on the 3rd gen. :-)
a/c , immediately , time , turned , unit
Another No Heat/Warm heat thread.. please help troubleshoot bentos1 3rd gen T4Rs 39 12-08-2022 12:23 PM
No heat diagnosis and solution, heat blend door servo actuator 4by4runr 4th Gen T4Rs 4 09-15-2019 09:10 PM
Compressor no longer turns on, and trying to turn it on turns off the speakers. 4rcybr 4th Gen T4Rs 0 06-17-2018 01:16 PM
Radio turns on, speakers pop, and then turns off lloydster 3rd gen T4Rs 9 08-09-2017 11:45 AM
Cold heat coming out but auxiliary heat? Gremcat Classic T4Rs 4 11-19-2014 09:57 AM
