03-20-2020, 11:56 PM
‘99 fog light wiring diagram
Hi-
Does anyone have the fog light wiring diagram for a 1999? I have the diagrams from 2002, but I think the lighting circuits were slightly different.
Thank you!
03-21-2020, 11:35 AM
Here's the '00 version. I couldn't find one for the '99
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
03-21-2020, 03:38 PM
Originally Posted by BostonJon
Hi-
Thank you!
I have the diagram here Toyota 4Runner Highlander Electrical Modifications Fog Light Mod
03-23-2020, 05:55 PM
Any one know how to down load the pic on here? Lol. 99 4runner foglights wiring.pdf
1999 4runner limited 4x4 millenn silver with rear elocker! with front toyotec boss front suspension, rear boss shocks, rear 3" ome 890 coils, front cbi bumper without grilled hoop, 315x12.5x16 bfg, old school 16x10 wide wheels, front IPF 968 6" lights.
03-23-2020, 06:50 PM
Hey Heat how did you manage to get that pic in here like that? Lol i being trying for the past 1/2 to get my wiring picture on here, but i cant get it to work. I have used google drive, iCloud drive, and even send the pic my email. Any help? Even tho im trying to help by providing with the wiring diagram thanks.
03-23-2020, 07:04 PM
You're trying to display a .pdf file. It's not an image file, though it can be
downloaded from your post.
Software here lets you attach "Valid file extensions: bmp doc gif jpe jpeg
jpg pdf png psd txt zip" but doc, pdf, txt, and zip aren't image files and won't
display.
I opened a pdf on my computer, took a screen capture of the page I wanted,
loaded it into an image editor, and exported a jpg. That's what I attached here.
03-26-2020, 12:03 PM
Hi-
Thank you!
The DRL and non-DRL versions are different... need to know which one you need.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
03-30-2020, 12:56 AM
Non-DRL please.
Don’t think DRL was standard in the US back then but not sure about that.
03-30-2020, 04:05 AM
Non-DRL please.
It was in Canada.
My '99 is paper, so I'll wait on Charlie.
My Backyard Frame Swap
03-30-2020, 02:39 PM
Originally Posted by TheDurk
It was in Canada.
So is mine!!
03-30-2020, 02:50 PM
Originally Posted by phattyduck
So is mine!!
OK. I fired up the scanner.....
04-20-2020, 09:11 AM
Thank you to everyone who assisted here. With the help of these wiring diagrams and some info on other threads here on the forum, I was able to troubleshoot the issue to a faulty bulb with an internal short between the filament (+ lead) and the base of the bulb (- lead). Given that the car is 21 years old and I was installing the OEM fog lights for the first time, I had assumed that there was a cracked/shorted wire somewhere between the connection under the front bumper and the fuse box. I did not expect the issue to be caused by a brand new Philips bulb. Upon closer inspection of the bulb, I noticed that the cloth sheathing on the positive lead was worn away near the area where it is soldered to the filament. Therefore, this positive connection was arcing with the base of the bulb when the two should have been electrically isolated. Always start with the simple stuff!
Thanks again!
