Old 05-11-2020, 08:58 PM #16
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
Originally Posted by Kanoe View Post
Here is a homemade oil pressure sender tool. I needed it for my corolla which hides the sender behind the exhaust manifold. Works just as well on the 3rz and May for you also.
Ratchet wouldn’t fit in so now I can use an open wrench.
wanna make another one?.... if so my PayPal is ready
Originally Posted by 19963.4lsr5 View Post
Removing the battery and Alt was the only way I felt I could get to it to put a wrench or socket on it.
Since the engine was new it came out easy. But I don’t remember having problems removing it (on the engine stand) from the 258,000 engine to get it rebuild.
yeah its pretty hard to get in that area without having the battery & ALT removed like @19963.4lsr5 mentioned....
i'm just apprehensive to keep removing things in turn opening up a can of worms... there was a member that recently was working on their engine & the stud bent & he couldn't remove the nut... literally a nightmare just off of one stud. sucks but i'm glad he got it sorted out.
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 05-11-2020, 11:00 PM #17
HiLife HiLife is offline
It's too late for me to go out and check but, can you get this through the drivers side wheel well with the wheel removed? Maybe you need extensions and a universal to get the angle.
Old 05-12-2020, 11:15 AM #18
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
The battery and alternator practically fall out of these rigs. Takes less time to remove them than to read this thread.
But, I change my oil through the wheel well by leaving one of the plastic clips off the skirting. You can look right in and see the sender. With the oil filter removed you have plenty of room for a ratchet.
I have the bigger 6 sided sockets cause you need them for the drain plugs on these rigs. A harbor freight impact set, short or long works fine. $24
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 05-12-2020, 12:25 PM #19
19963.4lsr5 19963.4lsr5 is online now
When I put the oil pressure gauge, the only drawback for me pulling the battery and Alt was it was cold outside and my EVAP readiness monitor wouldn’t set.
The plug on the back of the Alt may be a pain to pull out if a lot of grime is on it.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 05-13-2020, 01:16 PM #20
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
It is just a $10 dollar socket and a few minutes with an angle grinder. No need to buy one if you have a vise and a grinder.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
morning , oil , sensor , thing , type
What did I break? CXS 4th Gen T4Rs 8 02-16-2015 11:16 PM
Did I break something? knightsfs4 4th Gen T4Rs 5 07-25-2011 03:58 AM
hard break during 'break in' phase Fareastplaza 5th gen T4Rs 3 04-05-2011 12:16 PM
Break in ikT4R New Members 0 02-25-2011 10:55 AM
