Old 05-16-2020, 11:27 PM #1
Ruiner's Avatar
Ruiner Ruiner is offline
Ruiner is on a distinguished road
Ruiner's Avatar
Tried to crank no start , hot negative terminal
So it ran up until today. no smoke, it feels like the starter engages and stops the engine from turning over, the negative terminal is so hot it burned my thumb when i touched it.
Im hoping its something in the starter itself shorting and not my engine is blown. ideas?
Ruiner is offline   Reply With QuoteReply With Quote
Old 05-17-2020, 08:17 AM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Negative so hot ut burnt your thumb surr sounds like a dead short.
What's the current draw with everything off?
Old 05-17-2020, 10:27 AM #3
Ruiner's Avatar
Ruiner's Avatar
Thats what i was thinking, the only time I've ever had a wire heat up was a dead short, i disconnected everything so it didn't burst into flames, gonna go see if there is a draw when its off. The terminal only got hot when i try and start it and its a few years old reman started so im hoping that's it
Old 05-17-2020, 11:58 AM #4
Ruiner's Avatar
Ruiner's Avatar
good news bad news, when i go from the positive terminal end to the body of the alternator i get a tone and only about 3.5ohm resistance so deff grounded out
Old 05-18-2020, 11:27 AM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Looks like you found your short.. Yes the alts are always the fist place to check. :-) Glad you found it..
Old 05-20-2020, 07:45 PM #6
Ruiner's Avatar
Ruiner's Avatar
i think this is my 3rd or 4th parts store alternator on this car. Doing the big 3 while im at it
Old 05-21-2020, 01:21 PM #7
There's your problem. Get a Denso reman.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-28-2020, 07:25 PM #8
Ruiner's Avatar
Ruiner's Avatar
actually this time it wasn't the starters fault. If I'm lucky the oil cooler cracked and let coolant into the oil, and oil all over my driveway. There's no oil in the coolant though so it makes me think that's the only place that could happen and not be a cracked block. The starter and or ground to the engine just had oil on them causing the short
Old 05-28-2020, 07:32 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Wow...
Old 05-28-2020, 08:50 PM #10
Ruiner's Avatar
Ruiner's Avatar
it ran fine and likely still does, though i wont be starting it till i fix the issue. The only reason i think it could be the oil cooler is the puddle of oil under my car, that and no oil in the coolant. Just coolant in the oil. Ive done headgaskets before and while not fun Its not outside of my skill level. I just don know how id pull the engine if it came to that since my driveway is sloped a bit.
engine , hot , negative , starter , terminal
Tightened negative terminal and it broke sugjavier 3rd gen T4Rs 1 10-28-2018 06:59 PM
Replacing Negative Battery Terminal? Kirk_B 3rd gen T4Rs 2 06-04-2018 12:20 AM
metled negative negative terminal conecter secondary-system Classic T4Rs 4 10-19-2014 04:53 PM
metled negative negative terminal conecter secondary-system Classic T4Rs 0 10-18-2014 07:26 PM
Car honks when I connect the negative terminal back norwei 4th Gen T4Rs 3 07-11-2014 08:10 PM
