Hi all,
I'm having a hard time figuring out how to get one of my front bleeder screws to stop leaking from the threads!
I'll try to make this clear and step-by-step:
I am running 199mm 01-02 Tundra calipers up front, which have a 1.0x10mm thread pitch brake bleed screw.
I just put some Stoptech SS lines up front, and an extended Toytec line in the rear.
I did a full brake fluid flush with OEM Toyota Dot fluid.
I did a full bleed, and the pedal feel is now excellent.
I crawled back under after riding around some, and noticed my front passenger bleeder screw had a stream of brake fluid coming out of the threads. I cranked down on it with a proper flare nut wrench, and it didnt help the leaking at all. I probably tightened it way too much to be honest.
No fix.
Went to the auto parts store and got a new bleeder screw--- Didnt fix it
Wondering what the heck to do now. Really not wanting to get a new caliper if I can help it Hoping the bleeder seat isnt screwed up? How could I tell if it is?
Thanks!
No fix.
Thanks!
