Old 05-26-2020, 03:38 PM #1
Boognish_Forever's Avatar
Boognish_Forever Boognish_Forever is offline
Boognish_Forever is on a distinguished road
Please tell me this is normal.
Changing my radiator today and notice this bump on the thermostat housing for the lower radiator hose. I’m thinking the previous owner had this welded.
Boognish_Forever is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 03:48 PM #2
alumarine alumarine is online now
alumarine has a spectacular aura about alumarine has a spectacular aura about
It's hard to say from the picture.
Is it the ear on the far left? It looks a bit banged up.
Rockauto has them from like $12-$25.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is online now   Reply With QuoteReply With Quote
Old 05-26-2020, 03:57 PM #3
Here’s another picture at a different angle
I’m pretty sure it’s been welded.
Old 05-26-2020, 04:20 PM #4
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Silicate buildup. Wire brush it off. You'll be fine.
Old 05-26-2020, 04:21 PM #5
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Change it out if you can. You’ll never keep that from weeping coolant.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 04:58 PM #6
Drew76 Drew76 is offline
Drew76 is on a distinguished road
Man that looks like it was welded a while ago and then has dried coolant buildup over the welded portion.....maybe PO dropped it and it cracked or it got banged up with a tool and repaired.
Drew76 is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 05:04 PM #7
If it's the same diameter you should be able to clean it off but then why was coolant building up there in the first place unless the clamp wasn't tight enough, I've seen that kind of buildup where the T-Stat housing meets the block once the gasket got old but and seeped under the timing cover but this is just a hose on pipe/nipple.
Old 05-26-2020, 05:34 PM #8
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
This is a shot of a brand new one, it's a detent thing so you have a reference for the hose stop.
it's a factree setup.
Old 05-26-2020, 05:55 PM #9
Well I’ll be damned, you were right! Cleaned it up with some sandpaper.
Old 05-26-2020, 06:03 PM #10
I’m not sure why that tube had so much build it. The hose wasn’t leaking, but it sure did come off easy. I wonder at some point if the previous owner used tap water when mixing the anti freeze (which was red) and caused the build up. The spring clamp seems to be in good shape, but I’ll put it on the top hose just in case.
Old 05-26-2020, 07:02 PM #11
Kanoe's Avatar
Kanoe's Avatar
I've got one on my corolla like that. It continuously weeps, not enough to drip but it builds up like that. I think once the aluminum gets that pitted corroded texture it's hard to stop it.
-2001 Echo D.D.
Old 05-27-2020, 07:42 PM #12
T4R2014's Avatar
T4R2014's Avatar
It's just maintenance. Doesn't matter if you use green or red. I switched to pink. Time will tell if it does the same.
Old 05-27-2020, 07:58 PM #13
Man the original pic of the dirty pipe sure looked like it was repaired, that positive stop looked like sloppy excess filler material lol, don't remember this when I did Timing belt about 2 years ago haha, at that time I also made the switch from green (previous owner) to pink coolant, my extra coolant shelf in the garage is starting to look like a rainbow - pink for toyotas, green for my seadoos, orange dex cool for my chevy, blue for my wife's mini cooper, can't even remember the color for my dodge srt-4, might be pink/red as well....
Old 05-27-2020, 09:10 PM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I am kinda agreeing with Drew here. That either welded or a bad casting on a mold. What does the inside of the tube look like?
Old 05-27-2020, 09:29 PM #15
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Wait a min.. Isnt that just the hose stop on the casting that is just dirty? I know lots of Toyotas have a stop on their castings so the hose will not go on anymore..:/
i’m , owner , previous , radiator , thinking
Is this normal? kbach 3rd gen T4Rs 1 06-14-2013 10:26 PM
Gap in CV's normal? Hepar 3rd gen T4Rs 13 12-17-2012 03:39 PM
Is this normal? Opethlike 3rd gen T4Rs 2 08-08-2011 12:33 PM
Is this normal? SolRayz 4th Gen T4Rs 5 07-26-2010 08:33 PM
Is this normal? mushtabak2 3rd gen T4Rs 5 04-26-2008 05:57 PM
