06-12-2020, 02:07 AM
SR5 running board end cap
Looking for a unicorn. Not even sure the part number.
I’m looking for the drivers side front running board end cap that ties the running board into the black textured SR5 fender flare.
Seems this part is as scarce as the splash guards that occupy the same location when there aren’t running boards.
Hopefully someone has removed their running boards and has some end caps they are willing to part with.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
06-12-2020, 07:04 AM
Flare — ImgBB
is this what your looking for?
06-12-2020, 10:22 AM
Yes and no. I’m looking for that piece, but the version that ties into the SR5 textured black fender flares.
#7 post in this thread has pics of the flares.
Swapping fender flares on my 3rd gen
06-12-2020, 10:23 AM
official vendor
official vendor
Pretty sure this is what you're after if you have the wide flares.
Mike
06-12-2020, 10:34 AM
No, that’s the end cap for limited flares.
06-12-2020, 10:57 AM
Unfortunately I think the reason those are hard to find individually is that the nut and bolts that hold them on to the metal part of the running board rust, and then become impossible to remove without cutting the bolt off. The bolt is just embedded in the plastic and basically just strips out from the plastic and spins when you try to remove the nut. So you might have to just get a whole new running board instead of just that piece. That's what I had to do.
06-12-2020, 11:25 AM
official vendor
official vendor
Here you go...left front SR5 cap.
Mike
06-12-2020, 11:40 AM
That looks like the same thing you posted the first time.
06-12-2020, 12:03 PM
official vendor
official vendor
Look different to me. You pointed out the first one was for a Limited. The second is for an SR5.
Mike
06-12-2020, 12:10 PM
I have one, PM me...
edit, for these flares:
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
06-12-2020, 12:19 PM
Mike
Look at post 7 in this thread. Bottom right of the top pic.
06-12-2020, 02:00 PM
'97-'99 "SR5" flares are also known as the "skinny black" flares. '00-'02 use the wide 'sport' flares on the SR5's when installed (similar to the Limited width). Not easy to know, other than he said the 'textured black' flares - of which it can only be the ones I posted. The only other option is the chrome strips on 'non-flare' 16" wheel 4Runners that were installed for legal (body width) reasons.
06-12-2020, 04:11 PM
Provide a pic next time of what you need. Google search the 4Runner with that trim and post it.
08-31-2020, 04:53 PM
Endcap
Originally Posted by Drew76
I also am looking for that unicorn, but Drew76 this is (imgBB) exactly what I am looking for (right rear endcap to fender without flare. Do you currently have a source for this?
Hopefully someone can. I have been looking for over a year.:flypig
malcadam
08-31-2020, 10:28 PM
Too late! That was a SR5 parts truck I scrapped a few weeks ago, didn't keep any of the trim as I have a limited...
