Old 06-24-2020, 02:08 PM #1
Satter's Avatar
Satter Satter is offline
Satter is on a distinguished road
Satter's Avatar
How often do you replace the thermostat?
Hello all. I’ve got 177k on my runner. But it’s now pushing 23 years of age? Should I have the thermostat replaced?
The radiator was replaced back in November because it had a crack in it. Dunno if they replaced the thermostat though.
'98 4Runner Ltd 4WD.
A Ford might get you from point A to point B. But a Toyota will always get you home.
Satter is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 02:24 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I mostly replace the thermostat with the timing belts. I would change it if it's over 20 years old if you want to. They are very easy to change and get to.
Old 06-24-2020, 02:33 PM #3
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Agreed.
I've changed mine twice. Once when I did a drain and fill of my coolant about 5 years ago, then again when I had to replace my radiator about 2 years ago.
Old 06-24-2020, 04:30 PM #4
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
Just changed with my timeing belt at 155k miles. At 255k now so i should do it eventually. Maybe just check the belt and decide then.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 05:11 PM #5
The thermostat is a good place to go OEM. And make sure the 'jiggle' valve is at 6 o'clock (upside down from almost every other engine out there).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-24-2020, 06:03 PM #6
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
They should be done every 100k I'd say, but pushing an original to 300k is not unrealistic if you are diligent with coolant changes.
back , november , radiator , replaced , thermostat
How to and replace thermostat in 5th gen v6? mountainair26 5th gen T4Rs 8 10-21-2022 10:24 AM
Repair head gasket, replace engine, or replace truck? backcountrylimo 3rd gen T4Rs 31 10-01-2020 12:45 PM
How Do I Replace a Thermostat on the V6? fdbyrne 4th Gen T4Rs 12 12-05-2017 01:53 AM
Is thermostat hard to replace? Atreyus 3rd gen T4Rs 29 04-20-2016 07:53 PM
Thermostat Housing Leaking After Rad Replace Dirt Sailor 3rd gen T4Rs 5 08-30-2015 09:49 PM
