Old 07-31-2020, 01:57 PM #1
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
rear upper control arm bushings ?
am I looking up wrong. I find entire upper arms but not bushings. arm # 48710 35040
want to stay original toyota...when I did a search in this forum I saw threads saying not available and have to buy entire arm
still true ?
when I do other searches it takes me to the panhard rod
want to refresh my rear suspension,,,thats only parts I cant find..
.rear lowers no problem finding those...or panhard...and of course shocks and springs are no issue to find
thanks
Old 07-31-2020, 02:07 PM #2
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
I just replaced my rear upper control arm bushings.
I am not sure if Toyota makes a replacement bushing for these. The bushing encapsulates the entire circumference of the control arm on either side of it.
In fact, I had to cut the bushings before being able to press them out, so i have no idea how it would be possible to replace them with OEM pieces.
I used Whiteline Poly bushings for my replacements, Part# W63379
Rear Upper Control Arm Bushing Replacement - YouTube
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 06:40 PM #3
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
still true ?
thanks
@WeakSauz is correct. Toyota does not offer them on the parts diagram.
last time around when I did mine I used white lines both upper and lower.
W63379 - Trailing Arm - Upper Bushing
W83374 - Panhard Rod - Bushing Kit
W63378 - Trailing Arm - Lower Bushing
They are surprisingly expensive for what you get.
Old 07-31-2020, 07:31 PM #4
Real Name: 3 Bears
Real Name: 3 Bears
thanks guys
to be honest....not sure I want to go whiteline when stock lasted me 240k..and they are not worn out...just want to replace while doing a suspension refresh...so maybe 200 for both uppers...new toyota...is not that crazy and no press work...but I have a press so ?????? argg...i dont know...i just dont want to pull things apart again in a bunch of miles ...hate doing things twice.
Old 08-01-2020, 12:16 AM #5
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
The aftermarket upper arms are decent enough. Mevotech or Moog seem fine.
They are really easy to replace, 4 bolts and maybe 2 plastic clips.
If your not lifting lots or rock crawling....would think your money would be better spent elsewhere.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 08-01-2020, 01:07 AM #6
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
I replaced the bushings of the lateral rod and the rear UCAs using red PUs from Sonoran Steel.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 08-02-2020, 08:21 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Tetanus 1 has a complete set of rock auto control arms uppers lowers in it. I went that route because it was quick and solved my bushing issues. The upper control arms are tubes and wider diameter then stock. The bottoms are very close to OEM thickness.
arm , bushings , entire , find , rear
Rear upper control arm Bushings ( short ones ) JetTech 3rd gen T4Rs 10 09-26-2018 07:47 PM
rear upper control arm bushings? where to buy? D Farms 3rd gen T4Rs 0 08-28-2014 01:25 PM
95 4x4 upper & lower control arm bushings replacement HELP!!! and rear bushings??? mark808 Classic T4Rs 18 07-08-2013 01:11 AM
Upper control arm bushings (do poly bushings exist?) jamess 3rd gen T4Rs 20 02-21-2011 04:07 PM
Upper control arm bushings Run 4 est Run Engines / Suspension / Wheels / Tires / Audio / Accessories 3 11-29-2010 12:59 PM
