Rough riding after suspension upgrade...
JoshuaDudee
Alright, so it’s been a couple weeks since the upgrade for my suspension.
When I’m driving and hit bumps in the roads it feels very rough. Some pumps literally pull the wheel.
Do you guys think it’s because I don’t have the weight added yet in the front and rear from the bumper upgrades?
Right now the rear sits a little higher than the front due to the LC 8.5’s, but hopefully the rear bumper will even that out once I install it.
Here’s my setup:
Front:
-Bilstein 5100’s (BIL 24-261425)
-Toytec FRONT LIFT COIL SPRING (TT 112-620)
-Heavy Duty Disconnect Front Sway Bar Links (Very rattly over bumps and turns. Might just replace with solid ones rather than the disconnects)
-SPC Adjustable Control Arms (25460)
Rear:
-Bilstein 5100’s (BIL 4R5100)
-LC 8.5 Wrap Springs
-Toytec panhard drop bracket
-Heavy Duty Rear Sway Bar Links
Let me know what you guys think please [emoji848]
What is the center of hub to fender lip measurement front and rear? What clip setting are the fronts at?
I'm guessing you are topping out in the front.
What tires are you running and at what pressure?
