Old 10-09-2020, 03:07 PM #16
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Originally Posted by sleepydad View Post
make sure you get the vin and make sure it's the correct part for you truck. your wire harness should have a part number on it up where it connects to the ECU. should look something like this
99 limited - D and L light up at the same time
I think the part your after is
federal = 821213G311
California = 821213G341
California spec is the one for 2x catalytic convert trucks.
Thanks for the extra information. I've pulled 6 wire harnesses but never paid attention to where the part number was lol.
326WHP 347TQ
Old 10-09-2020, 04:09 PM #17
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I have pulled a couple now... but this time I needed a very specific version of it for 1998 with the specs I have. I wish I could have found it local and would have done it myself. I was only able to find 3-4 of them nation wide.
salvage guys are always hulk smash it! I went thru the entire harness and replaced all the gunky parts. 2nd time I have done it and I'm getting pretty good at it. 2x rolls of tesa anti abrasion and new style painless split braided sleeving works out really well.
Old 10-09-2020, 05:39 PM #18
Roger.klotz Roger.klotz is offline
Roger.klotz is on a distinguished road
so you were not able to track down the trouble? or you did and figured out there is damage someplace inside the harness?
I just did it on my 98, and it fixed my issue. truck runs great again.
replaced the starter + engine harness. As @phattyduck indicated you will need to remove the upper,lower intake to unhook the injectors. most of it is pretty straight forward but it took me several hours to get it all off without destroying anything.
also took me a couple of hours to get it all back on and some new intake gaskets along the way.
I got my harness from salvage place in rancho CA
Car-Part.com--Used Auto Parts Market
searched for engine wire wire harness
called the place and neggoated price a little. $250 with shipping to my door.
you should be able to find something like this one, not sure if this is the correct one but they are out there
2000 Toyota 4Runner Engine Wiring Harness-Stock# 180076
and one more thing... I did have to repair 2x connectors on the salvage harness. not a huge deal but depinning and swapping connectors can be a pain. the salvage guys can be a little angry when they remove things... just how it goes with salvage.
I replaced the neutral safety switch and the issue is still there. I wasn’t able to pinpoint the short, but I believe it’s somewhere in the engine harness based on continuity checks with the multimeter. Thanks for the info on the harness part number. I’ll check near the ECU but if I remember right, there’s no sticker. It looks like the harness has been taped back up with electrical tape near the ECU and in a few other areas. Once I have a replacement harness, I’ll pull the intake manifold and see if I can locate the short.
Roger.klotz is offline   Reply With QuoteReply With Quote
Old 10-11-2020, 11:40 AM #19
I found the sticker on the harness and snapped a picture.
Part # is 821213G310A
I'm searching for a replacement now.
99 limited - D and L light up at the same time-unnamed-jpg
Old 10-13-2020, 08:03 PM #20
I started unplugging the harness from the trans and O2 sensors so I could fish it out and get a better look. I found a few exposed wires near the neutral safety switch connector after peeling back the plastic.
99 limited - D and L light up at the same time-unnamed-1-jpg
Old 10-13-2020, 08:05 PM #21
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Those look like they got hot and melted. I would say that's your issue.
Old 10-14-2020, 06:37 PM #22
These harness part numbers are confusing. I have 82121-3G310A Does anyone know if 82121-3G281B or 82121-3G310B is a suitable replacement?
Old 10-14-2020, 09:55 PM #23
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I agree they are not only confusing but have to match.
You really have to watch those harness part numbers. Most of the time they are not the same. Those could be 3 different harnesses
How it goes on 3rd gens. 1996 through 1998 very similar but may not be exact.
1999 thru 2000 transition years
2001 and 2002 very similar but may not be exact.
Old 10-14-2020, 10:58 PM #24
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
100% find an exact match, I used to think I was cleaver until my engine wire kicked my arse. I know better now.
do you have your VIN? handy. I will see if I can find one for you? if you want?
Old 10-15-2020, 11:54 AM #25
100% find an exact match, i used to think i was cleaver until my engine wire kicked my arse. I know better now.
Do you have your vin? Handy. I will see if i can find one for you? If you want?
jt3hn87r2x0198778
Old 10-15-2020, 12:29 PM #26
That harness is totally repairable... not sure what the issue is with finding a replacement?
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-15-2020, 12:47 PM #27
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
jt3hn87r2x0198778
82121-3G310A
821213G310 FEDERAL
821213G340 CALIFORNIA SPEC
I honestly don't think the "A" has anything to do with it. The "A" is not in any of the part numbers I see.
100% I would repair it but not everybody has the confidence, skills to repair it. even taking it off and taking it to somebody with electronics experience would be better than salvage I think? I just tossed a pile of wires into the recycle bin... I'm sure I just tossed what would have been a cut and replace section of that harness into the recycle bin, and they took it yesterday.
Old 10-15-2020, 12:54 PM #28
I’m leaning towards replacement since I don’t know the extent of the melted wires throughout the harness. I’ll see if I can unplug and free the harness enough to pull it up through the engine bay. If it’s just a small portion of damaged wires, repair shouldn’t be too hard. Having a replacement is peace of mind.
Old 10-15-2020, 01:10 PM #29
I can't bring myself to throw away the 3 or 4 boxes of wires I have... Though someday I will need to, I suppose! I like having access to OEM wire and connectors when needed. (I don't have that section for a '99 or I'd offer it up)
Old 10-15-2020, 09:40 PM #30
I exposed more of the harness under the truck and the only visibly damaged wires were white/red and black/yellow. I re-insulated with heat-shrink, but ran out of light before I could test continuity. Hopefully that's the extent of the damage to the harness, but with the light for L coming on, I thought the light green wire would be exposed as well.
fuse , gauges , issue , replaced , time
Help, highs are on all the time after fog light mod Tempsho 4th Gen T4Rs 4 11-12-2009 12:53 AM
TCS OFF light on all the time sciff5 4th Gen T4Rs 3 01-11-2009 12:43 PM
