Old 10-07-2020, 09:20 AM #1
Iffykid Iffykid is offline
Iffykid is on a distinguished road
4X Innovations front bumper winch install ?s
Has anyone installed a winch in a 4X front bumper?
4X claims a winch will fit in the front bumper with clocking which it will the problem is the control box will not.
Two options I see at this point are.
1. Remote mount the control box under the hood somewhere and add 3 longer cable leads $$$
2. Cut a area out of the top of the bumper and also remove a section out of the bottom of the grill just below the Toyota emblem so that the control box could be mounted in a normal fashion.
4X Innovations front bumper winch install ?s-toyota-jpg
Iffykid is offline   Reply With QuoteReply With Quote
Old 10-07-2020, 09:39 AM #2
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I put a Smittybilt Gen2 X20 10,000 lbs in my 4x
here
https://www.toyota-4runner.org/3523268-post210.html
and
https://www.toyota-4runner.org/3523963-post211.html
yes you will have to trim just a bit of the grill, other than that is slipped into the bumper like a glove.
Old 10-07-2020, 10:00 AM #3
here
and
I am trying to shoe horn in a HF Badlands ZXR12000 and running into similar issues, By the looks of things my control box is slightly larger which might take more trimming not wanting to butcher anything more than necessary I will have to look at offsetting like you did instead of mounting it centered over the winch. Thnks
Old 10-07-2020, 10:40 AM #4
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
I'm running a smitty gen2 xcr 9500 in my 4x. The control box is mounted behind grill to center support with a notch cut at the top of grill for the remote connection port to be accessed easily. This is the best photo I got right now. I can take more later if you're interested.
4X Innovations front bumper winch install ?s-20200506_182626-jpg
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 10-07-2020, 11:24 AM #5
Yes interested in more pics if possible, I had looked at the center support as a location but the A/C lines looked like they might get in the way and also access for the remote so I also considered a wireless remote.
Looking for peoples solutions for control box mounting.
Old 10-08-2020, 01:04 AM #6
SeaBassHWD SeaBassHWD is offline
SeaBassHWD will become famous soon enough
I put a Warn VR10 in mine. I relocated the control box under the hood. Instructions on how I did it with pics here.
SeaBassHWD is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 09:26 AM #7
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
I put a Warn Zeon 8S in mine. I just trimmed a little metal out of the back edge of the bumper, and a little off the bottom of the grille. Gives clearance for the control pack and access to the 'shifter' lever.
JohnMc is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 07:04 PM #8
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
Let me see if I can explain what I did with a Shittybilt 10k control box.
Basically I reused the brackets that mount the control box to the winch body, to mount it it to the top of the bumper just over the winch. There are "clips" that you can latch onto the rear of the top plate. Then I spanned the front of those 2 brackets with a small piece of bar stock, which I ran screw through, threading into the top of the bumper. I did have to open up the front grill to fit around it. I'm bad a describing things and it's simpler than it sounds.
4X Innovations front bumper winch install ?s-20201008_154817-jpg  4X Innovations front bumper winch install ?s-20201008_154809-jpg  4X Innovations front bumper winch install ?s-20201008_154857-jpg
Hopeless Diamond is offline   Reply With QuoteReply With Quote
Old 10-09-2020, 05:19 PM #9
Twan's Avatar
Twan Twan is offline
Twan will become famous soon enough Twan will become famous soon enough
Twan's Avatar
here
and
Good to know. I've got a 4x bumper and have a X20 sitting on the shelf waiting to go on.
2000 SR5 Sport - 4EAT and E-locker, King 2.5s, EimKeith PCK, SPC UCAs, 33" KO2s on Black Rhino Boxer gloss gold 17x8.5, Savage/Lotus skids, 4xInnovations front bumper/sliders, Shrockworks bumper & tire carrier, Lil Skip Gas Tank Skid, Magnaflow Overland cat back
Twan is offline   Reply With QuoteReply With Quote
Old 10-10-2023, 01:09 AM #10
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
Has anyone managed to mount an Apex Badlands 12k on a 4xI with no body lift option? I thought someone in the "What didyou do today" thread was replying to me saying they did it but upon closer inspection it seems that it's a Warn Zenon and they had a body lift so taller bumper >< I just got my bumper in on Saturday and am test fitting things. Relocation box and clutch handle both don't fit and there is no way to clock them on this winch. Also looking at the fairlead I'm wondering if the screws are going to crash into the winch body, even if I put the washers on the fairlead side of things. I think I might have hosed myself and either need to find a new winch or a new bumper >< At least I got both on labor day sale and hopefully can recoup my costs on either one.
'98 SR5 5 Speed
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 10-10-2023, 12:07 PM #11
After closer investigation I think the solenoid relocation isn't as big a deal, just shave a bit of the top of the box. Also the freespool won't be a big deal if I can extend it and just drill a hole for the handle to go through, anyone done this?
'98 SR5 5 Speed
Old 11-25-2023, 12:32 AM #12
DontKnowRunner's Avatar
DontKnowRunner DontKnowRunner is offline
DontKnowRunner is on a distinguished road
IffyKid, what did you end up doing? If you were successful, what winch did you end up going with?
'99 SR5 4WD V6, 176k,
Sonoran Steel 1.2 lift
B&M 70268 ATF tranny cooler running in series with OEM cooler
16" Taco Wheels, Falken WILDPEAK A/T3W LT265/75R16 265/75/R16
Tundra Brake Upgrade, The Matterhorn roof rack (Sherpa Equipment Co)
DontKnowRunner is offline   Reply With QuoteReply With Quote
box , bumper , control , front , winch
Shrockworks front bumper winch install judoant 3rd gen T4Rs 15 10-05-2020 03:14 PM
4x Innovations front plate bumper winch mount/controller location OutdoorLF 3rd gen T4Rs 5 06-28-2015 09:14 PM
Northwest Trail Innovations Winch Bumper Group Buy! djskorch 3rd gen T4Rs 32 09-26-2014 10:56 PM
Northwest Trail Innovations plate winch bumper group buy! djskorch Classic T4Rs 13 02-27-2014 04:02 AM
Northwest Trail Innovations plate winch bumper group buy! djskorch 4th Gen T4Rs 23 11-22-2013 07:36 PM
