Old 10-24-2020, 07:53 PM #1
Niteghost Niteghost is offline
Real Name: Ty
Niteghost is on a distinguished road
Real Name: Ty
Buying help 02 Sport w/ Rust and Leak
Hey T4R Fam, I went to look at a 3rd gen today and I wanted your opinions on some findings.
The frame is fairly rust free, the gas tank skid is pretty bad and will need to be replaced, it was flaking badly.
The mounts as seen in the photo all look pretty much like that.
The Axle is rusted like that on the driver side only. Looks to be mostly surface rust.
I found this leak on the driver side under the vehicle at the back of the engine, it feel like oil and as you can see it has some blow by on the sway bar and other components as well.
Thoughts on all this and if its a deal breaker. Car is 1 owner with only 115k will all the service records. Tbelt will still need to be done as it has not yet.
T4R Photos - Album on Imgur
2002 4Runner Sport -->Build Thread <--
2017 4Runner TRD ORP
2002 Toyota 4Runner - Sold
Niteghost is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 07:59 PM #2
Formidable's Avatar
Formidable Formidable is offline
Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light
Formidable's Avatar
Oil leak is prob valve cover. Mine had 127k when I resealed.
Rust on the body mount looks pretty severe. You sure the rust on the rest of the frame is minimal?
2002 Thundercloud | TRD Supercharger | TRD Headers | URD 2.2 Pulley | Toytec | Addicted Offroad | 4xinnovations | Icon | SCS | BRIDE
BUILD THREAD
Formidable is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 08:14 PM #3
Real Name: Ty
Real Name: Ty
I added two more photos of the frame itself and surrounding areas, The rust on the frame is good just a bit on the welds which from my experience is normal. I might be wrong here though.
Old 10-24-2020, 09:21 PM #4
Formidable's Avatar
Formidable's Avatar
Agree. Those shots are unimpressive. The body mounts can probably be refabricated and welded to the frame. Obviously I would use the valve cover issue and the rust to negotiate the price down.
BUILD THREAD
Old 10-24-2020, 09:29 PM #5
Real Name: Ty
Real Name: Ty
Absolutely will be. I just wanted to see if the rust was bad enough to where I should walk away from it. My last 3rd gen was pretty damn spotless which was a feat, elderly owned and only had 58k when I bought it years ago. Brother in law needed a car so now he has it. Wish I could get it back, but 2wd
Old 10-24-2020, 09:49 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The body mount on the driver side is the center mount? Is the bottom of that frame open? Maybe its just the photo angle.
The frame condition isnt bad. Weld joint always rust first due to the rapid heating abs cooling of the weld.
Old 10-24-2020, 10:17 PM #7
Real Name: Ty
Real Name: Ty
Correct, that is the center mount. Bad angle on the photo sorry, the frame is not open, that looks like a shield or something behind the frame.
Frame looked to be in pretty solid shape overall just a few areas like this that were pretty gnarly.
Old 10-24-2020, 10:38 PM #8
Formidable's Avatar
Formidable's Avatar
By the way, I would check the front body mount and where the bumper attaches to the frame. If the center mount is already rusted to that degree... this area may be toast. Pics below.
Buying help 02 Sport w/ Rust and Leak-04ecf7ac-e85a-4e80-aa82-852baf4ead31-jpg  Buying help 02 Sport w/ Rust and Leak-5aa20f6b-0d58-4865-9ea2-e3a954e66dfe-jpg
BUILD THREAD
Old 10-24-2020, 10:50 PM #9
Real Name: Ty
Real Name: Ty
Okay, I will definitely check that spot out. Your frame is unbelievably clean! Thats amazing
Old 10-24-2020, 10:58 PM #10
Formidable's Avatar
Formidable's Avatar
Nah this is expected for a west coast truck 130k.
BUILD THREAD
Old 10-24-2020, 11:20 PM #11
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Cat's obviously been replaced - very interesting.
Old 10-24-2020, 11:43 PM #12
NJ-4Runner NJ-4Runner is offline
NJ-4Runner will become famous soon enough
That rust is so minimal. Nothing to worry about.
NJ-4Runner is offline   Reply With QuoteReply With Quote
Old 10-25-2020, 12:03 AM #13
Real Name: Ty
Real Name: Ty
Haha yeah I thought the same thing, I was like well damn thats shiny.
Old 10-25-2020, 12:03 AM #14
Real Name: Ty
Real Name: Ty
I appreciate that!
Old 10-25-2020, 12:18 AM #15
mikeferg's Avatar
mikeferg mikeferg is offline
mikeferg will become famous soon enough
mikeferg's Avatar
Seems in really good shape by the photos but I cant commit on the rest, is the interior grey? supercharged?
mikeferg is offline   Reply With QuoteReply With Quote
driver , leak , pretty , rust , side
Potentially buying- too much rust? snipegoat 4th Gen T4Rs 20 07-09-2021 04:46 PM
4th gen rust/known maint. issues for buying used?? devkota 4th Gen T4Rs 31 09-18-2020 11:15 AM
Need some rust advice before buying (pics included) Juice88 3rd gen T4Rs 16 05-16-2019 10:18 AM
Buying 02- pics of rust under body parkin11 3rd gen T4Rs 16 04-04-2013 12:27 PM
Thinking of buying 2001. HOW BAD is the rust ? JT3HN86R 3rd gen T4Rs 4 10-25-2010 08:32 PM
