Old 10-25-2020, 03:47 PM #1
bowrappyo's Avatar
bowrappyo bowrappyo is offline
bowrappyo is on a distinguished road
bowrappyo's Avatar
Best rear tire mount (hilux surf option?)
Looking into the best rear tire mount options.
It’s a shame the US didn’t get the awesome rear tire mounts like the proper hilux surf did in JP.
What options have people found?
Has anybody been able to convert to the full hilux surf rear Tire mount option in their 3rd gen?
99 4Runner, Bow Hunter, Los Angeles
"The powerful play goes on, and you shall contribute a verse" - Whitman | @jrapp.yo
bowrappyo is offline   Reply With QuoteReply With Quote
Old 10-25-2020, 04:03 PM #2
Ashura's Avatar
Ashura Ashura is offline
Ashura is on a distinguished road
Ashura's Avatar
A couple of people have done it but doesn't look like any of them are active anymore on here:
blktpgsr
greenbowcounty
brilliant (he got the tailgate but not the carrier; going through his thread think he wasn't able to figure it out)
I like them too and am looking for one. Good luck sourcing; they're not easy to get...
Ashura is offline   Reply With QuoteReply With Quote
Old 10-25-2020, 05:20 PM #3
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
You would have to find a Hilux surf tail gate and swing out from the same year (and colour ideally) so the wiring would match up or you'll have to convert it, then you would have to fab reinforcements with weld on nuts inside the rear passenger tail gate pillar to mount and handle the swing out weight and drill a few precision holes. Most aftermarket ones I've seen require the matching aftermarket bumper, or the drop down hitch mount style. I get the swing out look, looks awesome and solves the big spare tire storage, but functionally I prefer not having to swing out a tire every time I need in the trunk.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 10-25-2020, 06:48 PM #4
TRD 4RNR's Avatar
TRD 4RNR TRD 4RNR is offline
TRD 4RNR will become famous soon enough
TRD 4RNR's Avatar
Are you looking for a permanent or temporary solution?
Might try one of these:
Wilco Offroad UHG33187: Hitchgate Solo Standard High Clearance | JEGS
1999 "Highlander" V6 4WD E-Locker || TRD Supercharger, URD 7th Injector, 2.2 Pulley || Toytec Aluma Series Boss Suspension, SPC A-Arms, Durobumps, Overland Endlinks || B&M Trans Cooler || 231mm Tundra Brakes, SS Brake Lines || 17" TRD Pro Wheels || BFG KO2 265/70R17-C || TRD Exhaust || 01-02 Tail Lights || Original Owner
TRD 4RNR is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 02:21 AM #5
Doc3g Doc3g is offline
Doc3g will become famous soon enough
That's a really cool solution except that at the price they want you might as well throw a few more bucks at it and buy a custom bumper with a swing-out. If it was $250 I could see it being worth that, but for under $300 I can carry a CRF450 on my hitch, so it shouldn't cost $800 to carry a spare tire.
Updated LED Interior Lighting Thread
99' SR5 HRU
Doc3g is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 10:19 AM #6
ArmArak's Avatar
ArmArak ArmArak is offline
ArmArak will become famous soon enough ArmArak will become famous soon enough
ArmArak's Avatar
I built one with the same idea to carry my spare tire and a gas can for around 250-300 bucks. Ill post a thread on it soon but if you have a welder all you need is some steel tubing and paint to get something that looks really good and works very well.
ArmArak is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 12:39 PM #7
crestkid's Avatar
crestkid crestkid is offline
crestkid is on a distinguished road
crestkid's Avatar
Rather than spending the funds to buy a whole bumper to mount my spare in the rear, I modified a hitch receiver bought on Amazon to fold down. Cost less than $100 and thought it came out well. Pic for reference.
Best rear tire mount (hilux surf option?)-img_20200713_123407177_hdr-collage-jpg
crestkid is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 05:07 PM #8
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
another vote in favor of building.
I spent less than 200 bucks and thats with redoing some parts 2 or 3 times as i learned. most expensive part was the hinge that cost about 50 bucks. first time building a swingout but well worth the experience of figuring it out.
details in my build if you'd rather learn from my mistakes
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 09:40 PM #9
bowrappyo's Avatar
bowrappyo's Avatar
Was looking for something more permanent. I've seen this option before. Looks pretty ok!
Old 10-26-2020, 09:42 PM #10
bowrappyo's Avatar
bowrappyo's Avatar
This looks pretty rad. Great work. I'll be out in UT in Feb for some snowboarding with my truck.
Old 10-28-2020, 02:42 PM #11
pavelvoivoda's Avatar
pavelvoivoda pavelvoivoda is offline
pavelvoivoda will become famous soon enough
I did it to my xUN 4Runner.
Since my back door was not in good shape (there were some bents, the window wasn't moving fast enough, and wanted to make room for a future aux tank), I found a Hilus Surf spare back door at a scrapyard and bought it.
After I repainted it, I replaced everything from my old door, to the new old door and was amazed how fast and smooth everything moved and locked in place.
I said to myself that I'd go with a new custom rear bumper and attach the rear tire on it, but that was too complicated, considering the guy would sell me the whole spare tire carrier for about $100.
After some measurements and dozen tries lifting and lowering the carrier, I found the right place to drill the holes for the two mounts.
The guy didn't want to cutout the lower panel and pull out the two brackets inside the fender, so I had to make them myself.
One the 4Runners, the 3 holes exist in the pillar, but may be blocked by a weird bracket (pic shown), that must have its spot welds drilled, so it can be removed. For this, I drilled a bigger hole thru the pillar(not for the faint of heart), to be able to reach and drill out some of the spot welds. I think there were two or three.
The first four pics are of a friend who is doing this to his 4rUNner!
The top one was easier to make: all it is is just a piece of sheet metal about 2-3mm thick, and on every opening for the bolts to go thru, i welded a... I don't remember - 16mm nuts. The sheet metal was precut in the shape of the outer mount on the carrier. Sorry I dont have a pic.
The bottom one was a two piece of sheet metal, one vertical which basically follows the same curve of the lower carrier mount and then one end bolts to the front part of the internal pillar, and the other follows back then makes a turn towards the center and then turns again to the front of the 4Runner and bolts where there is a rubber bushing that the back door butts against when you close it. I also added some rubber padding between the outer fender and inner bracket to act like a bushing. It turned out ok. Sorry no complete pics.
This lower bracket is also reinforced with a horizontal piece of the same sheet metal that is precut to the same curve of the lower fender and welded to the vertical piece, to make the whole custom bracket look like a curved T beam. It's a bit awkward to bolt the carrier to it. The pic below is not the finished bracket but a test. If you don't reinforce the bracket, the outside sheet metal will bend on every swing of the carrier and eventually brake the fender. So fiddle around with it and make a sturdy bracket.
The really not-for-the-faint-of-heart part is when you realize that the lower mount bracket does mount correctly to the fender...but the whole carrier has to go left in order for the lock bracket and especially the courtesy switch for open-carrier-dash-signal to work properly.
I used a small hammer with a rubber padding to hand bend the fender to shape it into a Japanese fender...
The open carrier signal should activate the open dash light if the original back door ECU is used. In my case I used my cars ECU, because the car I got the door from was a 96 and the ECU is older than mine cars. I tried to insert a pin to the connector following the electrical diagram for the Hilux Surf, but the 4Runner's pin slot there doesn't provide any signal to the dash via the multiplex com system. Anyway I getto hacked it with a relay connected to the original door lock signal. If you want a diagram how I connected everything, let me know.
The carrier is pretty strong. I did step on the tire a couple of times during the last trip. I am around 200lbs.
I plan on mounting a small folding table, a rear fog light in the center where the spare wheel rides, a small lock box inside the rim to carry recovery gear, and maybe an HF antenna on the top mount shown in the example pics ive seen online.
Hope this guide helps.
Best rear tire mount (hilux surf option?)-01-jpg  Best rear tire mount (hilux surf option?)-02-jpg  Best rear tire mount (hilux surf option?)-03-jpg  Best rear tire mount (hilux surf option?)-04-jpg  Best rear tire mount (hilux surf option?)-05-jpg  Best rear tire mount (hilux surf option?)-06-jpg  Best rear tire mount (hilux surf option?)-07-jpg  Best rear tire mount (hilux surf option?)-08-jpg
"Sadly, unlike the Bill of Rights, the UDHR has no 2nd amendment, rendering it useless. Remember that."
2person xUN diesel T4R equipped for long distance touring w/ light-duty off-roading. 1000kms range w/ subtank
Check out my FB page Toyota 4Runner Bulgaria
pavelvoivoda is offline   Reply With QuoteReply With Quote
Old 11-04-2020, 01:08 PM #12
Ashura's Avatar
Ashura's Avatar
@pavelvoivoda THANK YOU! May have found a carrier and tailgate. This is very helpful.
Old 11-04-2020, 07:09 PM #13
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
I was really set on doing this modification as well, but I couldn't get over the hinges being in harm's way, offroading...
other than that, I think it's a great way to go
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2024
eimkeith is offline   Reply With QuoteReply With Quote
Old 11-04-2020, 10:22 PM #14
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
If you're handy with a metal-melter 2000, consider welding up your own. my coworker welds up and sells tire carriers for 4runners and it costs him very little to make. Something you want to keep in mind is the clearance between the armor and the car; if the bumper takes a hard hit it's gonna want to move, obviously, but if you have it built so it's rigid as shit and touching/flush with adjacent panels, all it's gonna do is damage whatever is next to it. Similarly if the actual arm holding the tire is too close to the hatch, or if the tire sits too high/too close to the glass, there's an equal chance to cause unnecessary damage. just something to think about, my bud isn't the best about it so I refrain from his carriers ironically.
That said, I'm probably gonna go with a CBI Hybrid carrier as it'll match my tube bumper very well. They're pricey though, but very nice looking.
I did it to my xUN 4Runner...Hope this guide helps.
That is TOO badass. I wish these were far more available, you can tell they really match and belong on the car. Not sure why someone doesn't just make them, they're obviously not that complex.
Old 11-30-2020, 09:57 AM #15
Hey Ashura,
It was you along with @Sarki that translated Japanese for me. If you happen to get your hands on a door and carrier like this, make sure to get also the rear gas pistons as well. When the Surfs are equipped with this type of carrier, the gas springs are stronger and will hold the lift gate better than the ones sold in the US.
I am trying to find the same gas springs from the translate post, here in Bulgaria. I'll write back if I have any luck...
hilux , mount , rear , surf , tire
3rd Gen Hilux Surf 185 Rear hatch + tire carrier. Seattle, WA $SOLD sogoood For Sale: T4R Items 10 06-01-2018 07:26 PM
New Winter Setup (Tire Advice Needed) Hilux Surf TOPSECRETTUNDRA 3rd gen T4Rs 6 11-16-2014 02:08 AM
FS: Hilux Surf Tailgate - tire carrier model - TN - $350 theallpowerfulme For Sale: T4R Items 4 10-31-2011 03:03 PM
Help me find a Hilux Surf Spare Tire Swing Away! LINY4Runner 3rd gen T4Rs 11 01-25-2011 03:34 PM
