01-26-2024, 12:38 AM
Real Name: 3 Bears
Real Name: 3 Bears
cold
so after twenty miles...my trans temp ( according to torque) reached 145. so with my radiator completely blocked ( we call it a cold front) my cooling system hit 185. I love these 4runners...heating is marginal. But I do not think the engineers did not think of these temps i deal with. Im not alone with 1st, 2nd 3rd gens 4runners....i talk with lots of older taco and land bruiser folks. the agree... when its minus 40...these heaters barely cut it.
supposed to hit minus 43 tonight. yehah
01-26-2024, 02:59 AM
Real Name: N/A
Real Name: N/A
I'd be happy it's running within a few degrees above gasoline flash point, and a few degrees below the freezing point of 50/50 coolant.
You could install heated seats out of another car, a few 3rd gens had them as options.
Or tell us how the car space heater works. Just look at those flames, must be shorting out to get that with only 12V. Battery hand warmers are a thing too, they can charge over a car charger, and you can put them in your jacket pocket.
1998 4runner 2.7 manual
01-26-2024, 09:09 AM
Real Name: Ron
Real Name: Ron
I feel for you! Live just west of Chicago and we had about a week of zero and below weather, I don't even like to drive my 4Runner when it's that cold, We're in the 30's day and night now and much better for everything.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
01-27-2024, 10:52 PM
Real Name: 3 Bears
Real Name: 3 Bears
cold...minus 50 today...tires frozen...wump wump wump for a mile and a half...heater barely did sh*t, been plugged in for 24 hours....auto start for 15 minutes. yahoo
01-28-2024, 01:33 PM
WOW - we got a measly 16 for about 2 days here in austin, which doesn't even compare yet it helps me relate (just a hair) to your situation, I don't know how you do it, on the flip side we hit 42 days last year with temps at or over 105 - not too fun.
2001 Limited 4WD - 349+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
01-28-2024, 01:37 PM
Real Name: 3 Bears
Real Name: 3 Bears
minus 49 and an earthquake this morning......guess its cold enough that the earth cracked
01-28-2024, 10:32 PM
Real Name: Lukas Weber
Ah, the joys of winter driving in our beloved 4Runners! It's impressive how they handle the extreme temperatures, but I feel you on the heating struggles. Those chilly German winters have nothing on what you're dealing with! Have you considered installing an auxiliary heater or a radiator muff to help combat the cold front blocking your radiator? It might give your engine a bit of a head start in those frigid temps. Just a suggestion!
01-29-2024, 01:06 PM
Real Name: 3 Bears
Real Name: 3 Bears
yes my radiator is completely blocked off. Up here when you block off a radiator we call it.. a "cold front".
like people will say....do you have a cold front installed
01-29-2024, 01:29 PM
Real Name: Devan
Real Name: Devan
You should consider a supercharger. That'll really help build some heat.
01-29-2024, 01:31 PM
I should probably do this too. You have all the heaters installed as well right?
That being said... it was past -40 here 10 days ago and now its back above zero
01-29-2024, 05:53 PM
Real Name: Jon
Real Name: Jon
It mostly doesn't get that cold here in southwest pa. What I will do is when it hits 20 degrees or lower, I switch to recirculating air.. That way I am pulling air from the cabin and heating it. Occasionally, I have to switch it to outside air if around the freezing point. As when it hits 0 or below that is the only chance I see you getting any heat.
Too bad there isn't an easy way to just control your thermostat. That way you can just shut off he radiator. Then you have to bypass your transmission cooler with a bypass valve as well. This way all your engine heat can be routed into the cabin to keep you nice and toasty.
I probably look into installing electric heat for the seats as well to help keep you more comfortable during the very cold temperatures. :-)
01-29-2024, 07:49 PM
The thermostat is probably nearly closed and most of the engine heat is used in the heater core if you are heating -40* air up to something semi-comfortable...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
01-30-2024, 04:52 PM
That's not cold, that's cryogenic
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
01-31-2024, 11:33 AM
I wonder, do they let the diesel trucks run all night in Alaska. Because even with block heaters the work trucks take a good 30 to 40 minutes to heat up when it's close to zero out here.
01-31-2024, 12:30 PM
Real Name: 3 Bears
Real Name: 3 Bears
depending on temps etc, than yes some of the big rigs run 24/7
