Old 07-01-2022, 11:36 AM #91
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
great to see you back, I've been looking into the TBU for when I get my 4runner back.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 07-25-2022, 07:25 PM #92
Iron duke's Avatar
Iron duke Iron duke is offline
Iron duke has a spectacular aura about Iron duke has a spectacular aura about
Iron duke's Avatar
So I did a thing…
For parts:
- Duralast extended cv axles
- Fox Performance 2.0x12” shocks w/resis
- 333Fabrications can eliminators
- Top hats
Upcoming Maintenance:
- Valve cover gaskets
- Oil change
- Alignment
Finally finished up my summer internship and with the extra dough I decided to get all the maintenance I’ve been pushing off done and then treat myself to some nice suspension. My buddy (HewIndustries) is making an osr kit for me in a couple weeks so that will be awesome. Decided to keep the 5100’s up front for now because after extensive research I found that they had the longest stroke length of any front shock/coilover for our rigs…besides fox’s 2.5 coilovers with the same stroke @5.49”. This means that the shock will not be the limiting factor in the travel, the cv axle binding would. Hence, the extended length cv’s. These are longer, designed for 2-4” lift. They also have 30% more angle to them. The shaft is also beefier than the stock cv’s. Finally, the boots are longer and designed not to rip. A lifetime warranty is nice too. So now that the cv’s and shocks aren’t the limiting factor for travel anymore, it’s literally down to the bumpstops. If I take those out or replace them with durobumps, I think the Uca would technically bind up before the LCA hit the frame, but it would be very close. I need to get UCA’s at some point, but that will be later. There is a 1” spacer on my front shocks that I’m getting rid of and my tops hats are cracking, so I thought I might as well get new ones and then get an alignment. And if I’m going to get an alignment (my alignment is already super bad, my tires have been suffering) I might as well get cam eliminators so it won’t get knocked out of alignment. Wow, diarrhea of the mouth…anyways, stay tuned for the crap ton of work before I have to go back to school.
Iron duke is offline   Reply With QuoteReply With Quote
Old 08-08-2022, 10:01 AM #93
Iron duke's Avatar
Iron duke's Avatar
Welp as I was trying to replace my top hats and remove the stupid spacers, I snapped the shaft of the shock. Everything was so rusty on it that I had to dremel and angle grind the top hat bolts to even remove the shock. Getting new B8 5100's now as I can't afford to drop 1500 on coilovers. Going to reuse the springs I have now and I already have the new top hats, just a pain with the first week of school to be out a car. At least I'll have new suspension in all 4 corners when I install the Fox's with the OSR kit. I don't think this had anything to do with the overall rust factor of the vehicle, rather the previous owner probably decided to leave the stock top hats from 211k miles in when he decided to switch out suspension and that area can pool with water. Anyways, all the new parts should be on the rig before too long.
Old 08-14-2022, 01:52 PM #94
Iron duke's Avatar
Iron duke's Avatar
Waiting on all new suspension to arrive but for now sheeeesh
Old 08-16-2022, 07:40 PM #95
Iron duke's Avatar
Iron duke's Avatar
Finally got front shocks in and new rear coils to lower the rear end now that I don't have so much junk in the trunk. Looks soo good.
Old 08-17-2022, 01:10 AM #96
looking good dude! glad to see it all together
281k Miles
Build Thread
Old 08-17-2022, 01:13 PM #97
89T4runner's Avatar
89T4runner 89T4runner is offline
89T4runner is on a distinguished road
89T4runner's Avatar
Love the look!
Sent from my SM-G998U using Tapatalk
1989 4runner 'Marilyn', 3.0 5 spd, ball joint spacers with KYB monomax, OME springs with 5100s, 33x12.5 duratracs, 4.88s, ARB fr, open rear, smittybilt fr, trailgear rr.
2000 4runner SR5 sport w/ elocker, Fox 2.0s fr, tundra 5100s with OME890 rr
89T4runner is offline   Reply With QuoteReply With Quote
Old 08-17-2022, 11:38 PM #98
Storm01's Avatar
Storm01 Storm01 is offline
Storm01 is on a distinguished road
Storm01's Avatar
Looks awesome! Did you end up going with those 891s?
Storm01 is offline   Reply With QuoteReply With Quote
Old 08-19-2022, 09:40 AM #99
Iron duke's Avatar
Iron duke's Avatar
Yes, pretty sure 881/891 front/rear but not positive because they were from previous owner
Old 09-26-2022, 02:31 PM #100
Iron duke's Avatar
Iron duke's Avatar
Much overdue was a radiator skid plate. Just wanted to make one myself so after a couple hours of getting material, grinding, bending, and welding we have it. It's super basic and I will be doing a redesign, but for $60 I wanted to try it out and see if I like fabbing my own stuff. It was a lot of fun and I have better ideas for a better looking and higher clearance one. I did create new mounts to where the upper bolts go, but reused the stock mounting locations for the bottom. The reason I needed one is because the aftermarket Champion Radiator sit lower than the factory one, which made it impossible for the stock skid to mount. Anyways, just thought I'd share the little update.
Old 09-28-2022, 03:46 PM #101
Melindamartinez121 Melindamartinez121 is offline
Melindamartinez121 is on a distinguished road
Boy, you've done so much, it amazes me how good this one looks! I also now have mun project related to college, with this it helps me https://edubirdie.com/buy-thesis-paper from where I buy thesis paper and freed up my time to be able to take care of my car, now I basically finished the project and soon I will be able to drive it, besides this my grades from college also stayed at niverl which I am very happy about!
Melindamartinez121 is offline   Reply With QuoteReply With Quote
Old 10-27-2022, 08:05 PM #102
Iron duke's Avatar
Iron duke's Avatar
Really haven't had too much time to post anything, but I've been doing a lot on the 4Runner.
Freedom UCA's
Cheapo LCA's with poly bushings
Moog LBJ's
Duralast Gold Extended cv's
333Fab Cam Eliminators
Its was a total pain and took forever but hey I'm pulling over 10" travel up front and 28" fully flexed out.
Also, today is the 2 year mark for my ownership of this rig...hopefully things will progess a bit faster in the coming months
Old 12-08-2022, 07:31 PM #103
Iron duke's Avatar
Iron duke's Avatar
Exams are finally over, now I can have fun. went mountain biking with my brother and friend. It's fun because you actually have to use 4lo to get to the trails so I was able to get off the fire roads for a little bit. Also got to climb up an abandoned fire watch tower. I had a friend make me some wood shift knobs and I switched back to the chrome grandpa front end for now. Going to make some descent LED retrofits now and keep the chrome look.
Old 12-13-2022, 09:00 AM #104
Tin Ark Tin Ark is offline
Tin Ark is on a distinguished road
Man I thought that was my 4Runner for a minute. I just bought a 99 one owner with 211000 miles on it original Florida truck in outstanding condition, just brought it in for service yesterday and have a new set of wheels on the way and a few more things planned. Not a ding dent or scratch on the body.
Here it is The 3rd Gen All Questions Allowed Thread
Tin Ark is offline   Reply With QuoteReply With Quote
Old 12-13-2022, 09:15 AM #105
Owl.. Owl.. is offline
Owl.. is on a distinguished road
Very nice build!
Owl.. is offline   Reply With QuoteReply With Quote
4runner , 4runners , budget , rust , speed
College budget build HCWatson997 General Discussions 1 01-13-2018 02:07 AM
The Frankenstein College Budget Build JohnBill53 3rd gen T4Rs 140 10-02-2016 05:16 PM
Freak's 97 Limited 4WD V6 College/DD Build Freak 3rd gen T4Rs 32 11-25-2013 11:12 PM
