Old 12-03-2020, 01:00 AM #31
fixxor fixxor is offline
fixxor will become famous soon enough
This is how I did mine:
fixxor is offline   Reply With QuoteReply With Quote
Old 12-03-2020, 01:37 AM #32
Doc3g Doc3g is offline
Doc3g will become famous soon enough
Originally Posted by cblock406 View Post
It will fit, mine looks just like yours, but you seem intent on using the passenger side.
You could probably make another mount for your relays on top of the factory fuse box, or make a bracket to mount them in the fender out of site. Not sure what I’ll do when I get to that point.
https://www.toyota-4runner.org/3538657-post172.html
I've still considered trying it but I have a few issues:
1. With just the bluesea box alone, it still makes contact with the hood and it sure looks like it's bowing. I do have my insulation on my hood still and I notice that you don't, so perhaps if I cut the insulation in that spot it would close.
2. I've got two fuseblocks that I plan on running (two separate circuits) so I would have to use the entire board space for the fuseblocks (assuming I could get the hood to close) which means the breakers, relays, etc would all have to be mounted elsewhere. I didn't originally like the idea of mounting them to the firewall but I need to take a peek inside the fender like you mentioned and see if I think that would look like a clean installation
3. I'll be 100% honest, I don't know what the black box is underneath the proposed panel site (I'm assuming it has something to do w/ the AC) but I do notice that it has a green service cap on it and I am wondering if it would need to be accessed if I needed to have the A/C serviced? One of the goals of my wiring setup is to have things readily accessible and if I install the tray on the passenger side, it won't interfere w/ anything.
Originally Posted by jross20 View Post
Ah yeah i wish there was another option... I've tried to come up with some solutions...but there isn't anywhere to mount it that I can figure out ...haha
Perhaps under the dash ....?
I literally tore my entire dash apart, the only viable place would be to mount the computer in the glovebox and use that area where the computer normally sits behind the airbag. I considered it except that I don't want to lose the bulk of my glovebox storage.
Yeah, that looks nice and is likely where I'll be coming in with my weatherpack. How has the weatherpack held up? Also, did you put the pins in the female side? I see conflicting info on which side the pins and barrels actually go into.
Updated LED Interior Lighting Thread
99' SR5 HRU
Doc3g is offline   Reply With QuoteReply With Quote
Old 12-03-2020, 01:45 AM #33
I didnt know, my male terminals are in the female part (piece mounted to the firewall), and the female terminals are on the male part (the piece that screws on). Seems to be all good, if its wrong...its not getting changed now .
Old 12-03-2020, 01:49 AM #34
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
That's what I did:
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 12-03-2020, 02:24 AM #35
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Originally Posted by 4Runner4Leon View Post
That's what I did:
Oh wow, wait did you post that earlier?
I need I need to go to sleep... Haha
boot , couple , daystar , noticed , wires
Need to get some wires through the firewall Signal 5th gen T4Rs 22 06-24-2022 02:58 PM
How did you guys run all your wires through the Firewall into the 4Runner? gkatmar Engines / Suspension / Wheels / Tires / Audio / Accessories 6 02-20-2022 09:58 PM
Wires through firewall eds72 4th Gen T4Rs 17 07-26-2016 12:39 PM
Cable routing through firewall mikey's2010SR5 5th gen T4Rs 10 07-31-2012 09:21 PM
Where to run aux wires through firewall? sant6236 3rd gen T4Rs 1 01-16-2008 05:59 PM
