Old 11-28-2020, 02:51 AM #1
str8flexed's Avatar
str8flexed str8flexed is offline
str8flexed is on a distinguished road
str8flexed's Avatar
Oil everywhere above front skid, where’s the leak from?
I took off the front skid (to access the starter.. another story) and notice oil everywhere. The dipstick shows full oil so don’t think it’s been leaking also there was no engine light. Where could this be from? Could it be front differential oil? Or just a loose screw or oil cap.
-4fbe00da-dee0-4000-955c-deb47179b854-jpg  -2f1b4d6a-7b6b-40c0-8570-d5e565b37747-jpg
2017 TRD Off-Road Premium: Dobinsons lift, Icon UCA, Gobi Stealth, Cooper AT3 XLT 295/70r17, Race Relations Wheels -12 offset 8.5”, CBI front bumper, Xenon HID headlights, RCI skids, RSG sliders, Focal 690TOY front speakers, Kicker DS rears
str8flexed is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 03:07 AM #2
Captsolo Captsolo is offline
Captsolo will become famous soon enough
DOES IT LEAK ON THE GROUND?
I HAVE A 2005 v6 AND GET OIL AROUND ENGINE BUT ONLY OCCASIONAL 1/2 drips on the ground a week.
It is nothing to worry about IMO. dip stick is always full. It is a 15-year-old car.
It's been that way for years.
Captsolo is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 03:27 AM #3
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
OP, sorry I cannot answer your question and I have to hijack your thread for a sec:
So....even with conventional oil it leaks.
/hijack
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 07:34 AM #4
Ghostrider Ghostrider is offline
Ghostrider will become famous soon enough
Do you take the plate off for oil changes? If not the oil filter can make a real mess on skidplate
Ghostrider is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 11:58 AM #5
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Pictures didn't post for some reason
If your front diff was leaking, you would only notice oil around the diff and possibly the CVs and steering rack. In no way could it "splatter" upwards and all over the engine
You're aware this is the 3rd gen section, right? I ask because I notice you're a 5th gen owner, so I feel like typical 5VZ oil leak advice won't be of much use to you
Old 11-28-2020, 12:34 PM #6
spartacus's Avatar
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
spartacus's Avatar
Timing cover inspection plate. power steering pump fitting gasket etc lots of leak related threads in the 5th gen section.
Oil Leak?
Old 11-28-2020, 01:04 PM #7
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
While the skid panels are off take it to a car wash that allows engine cleaning. Take a creeper and look at what you want to clean while your there. When you start pressure washing have eye protection. Things not to do is don't hit the alternator, exhaust system with a lot of water or the radiator everything else is pretty much fair game. I start from under the vehicle then move to the top. After you time stops let it drip a while and see what areas need more attention. After you clean it you can drive it then take a light and see where the leak is coming from.
plcfcng is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 01:51 PM #8
TeriSerugi TeriSerugi is offline
TeriSerugi is on a distinguished road
I'd get under it and see if you can track the leak. Look at the oil filter. It could be leaking from the filter manifold. There is an o ring that seals the manifold that sometimes goes bad.
TeriSerugi is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 11:45 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Always good to know where its coming from.
In the rust belt. I call those rust inhibiting leaks. As long as they arent major leaks the oil keeps my engine bay from rusting out. .
How fast are you losing oil?
Old 11-29-2020, 06:44 AM #10
cashflow50's Avatar
cashflow50 cashflow50 is offline
cashflow50 is on a distinguished road
cashflow50's Avatar
Rear seal possibly? I bought that blue devil stuff and no drips on the floor
cashflow50 is offline   Reply With QuoteReply With Quote
Old 11-29-2020, 10:43 AM #11
Cool
Really? That's good news for you.
HG jobs are expensive and no guarantee. I like BD too, but never tried it.
I have 2005 4runner with 150,000 miles. I get two drips a week. I just watch it. In a 15 year old car that starts and runs like new, I don't complain.
I change my own oil every 5000 miles.
I bought my daughter a new Camry when she graduated from HS and got accepted to FSU. She's now driving to work in that car for a major broker so it was the best thing she could own as there is no way they would hire her without a "drive".
That's the Toyota dealer's happy salesman.
-leeann-marty-april-2015-camry-2019_02_03-18_15_35-utc-jpg
Old 11-29-2020, 11:48 AM #12
/hijack
#1, the blue devil hes talking about is the rear main sealer... not head gasket sealer...
#2... thought you said you dont get any leaks now with your conventional 10/40 & blamed your leaks on super slick synthetic?? youre really digging a hole for yourself captainkilmer!
#3, are you that bored you seek out threads in the 3rd gen section? along with reviving 5 year old threads?
LOL!
Old 11-30-2020, 11:53 AM #13
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
LOL!
I have always wondered why Captsolo is always posting his repairs and part numbers for a 4th gen in numerous 3rd gen sections. Your 4th gen starter, fuel pump, injectors, oil filter, etc do not work on 3rd gen 4Runners. Never made any sense to me...
Old 11-30-2020, 01:27 PM #14
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
There's a black light dye you can buy on Amazon for cheap and then get a simple black light flashlight. Put it in the oil, drive it around and check the engine bay periodically until you see it glow. The old oil won't glow since it didn't have the dye in it, only the fresh leak. Easiest way to find it with 100% certainty.
326WHP 347TQ
engine , front , light , oil , skid
WTB: 4th gen front skid and filler skid Mtoyotaownr Want to Buy/Trade 1 06-06-2019 01:21 AM
FS TRD front skid/RCI TRD Integration skid - Las Vegas tigger For Sale: T4R Items 8 08-23-2016 04:05 PM
Stock front skid brackets for RCI engine skid RiDE 5th gen T4Rs 3 02-25-2016 03:00 PM
Front dif leak... uh oh ellner357 3rd gen T4Rs 6 04-28-2013 10:09 PM
Skid row 3 front skid plates cheap! spitvenom For Sale: T4R Items 13 08-21-2012 09:47 AM
