01-15-2021, 11:06 AM
Originally Posted by thor999
Those screw on type are good to get you home but they are a pretty poor connection. Not really recommended except in a pinch. They leave your cable open for corrosion.
You'd be better off crimping a nice lug on the cable and using the Toyota style, then you'd be good for another 20 years.
If the price of the toyota terminal scares you, the exact same part can come from the nissan dealer for much less money.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
01-16-2021, 08:29 PM
I agree completely, just needed a new terminal in a pinch and went through a few other options that didn't fit the stock lug. Once it gets warm enough I'll get a proper setup!
2001 SR5 4x4
01-17-2021, 09:18 PM
Yes, those connectors are garbage. I think "The Eric the Car guy" once show a voltage drop just at the battery clamp.
01-18-2021, 03:01 AM
Real Name: 3 Bears
Real Name: 3 Bears
do you have the nissan #. Right now I have garbage posts on this 4runner that need to go
01-18-2021, 04:51 AM
Real Name: Miah
Real Name: Miah
Amazon.com: Genuine OEM Toyota (+ - ) New Battery Terminal Set 90982-05035 90982-06022: Automotive
here ya go same price as nissan .... and better yet there Toyota OEM Terminals this is what the OP I believe meant to use and post. Since you could have easily ordered these instead and no need for any returns or settling on in a pinch garbage for only $4 bucks more. (note their not copper though) assuming from pic.
Enjoy
4th Gen 2WD to 4WD CONVERSION
2003 SR5 T4R Pac Blue Metallic w/rear locker, on 35" Mastercraft MXT’s, TC uca"s, TC lca"s, 2.5 King C/O's w/remote resi TC lca gusset kit, Taco Tabs, 2.5 Icon remote resi w/adj on rear Shock Hoops, adj panhqrd A 3.5" lift springs, 10" HD Series AirLift bag, hidden winch W/ 10k Smittybuilt, DMZ eng mounts
01-18-2021, 05:03 AM
Originally Posted by Oneluv13T4R
I think they are tinned copper.
01-19-2021, 03:14 AM
Real Name: 3 Bears
Real Name: 3 Bears
ordered, thanks
01-19-2021, 11:37 AM
Thanks for this, added to the shortlist
01-19-2021, 04:22 PM
Real Name: Christian
I used SDHQ terminals. They are pricier than oem or what you'd find on Amazon, but they look amazing and are very functional. Here is the link: SDHQ Built Billet Battery Terminal Upgrade Kit
01-27-2021, 02:47 AM
Originally Posted by Outxider
Not the same set I had ordered at first? But the mil spec I had gotten initially from Amazon snapped with very little tightening...
2001 SR5 4x4
01-27-2021, 02:50 AM
I ordered these as well but at the time they were 1-2 weeks out on shipping for me, hence me jumping on the shitties I posted here, and I needed them quick! I haven't installed the OEM's yet, but I will update when I do.
2001 SR5 4x4
01-28-2021, 02:06 AM
Real Name: Jarrod
Real Name: Jarrod
These are the ones I used when I added my auxiliary fuse box. You can clamp onto a post that screws into the side, or use one of the screw terminals integrated into it. They’re pretty sweet for adding power to your rig.
Amazon.com: KnuKonceptz Ultimate Positive and Negative Battery Terminal Pair: Automotive
96 5-spd w/E-locker, SS1.2 lift, JBA UCA’s, 1” BL, Other stuff
02-22-2023, 08:12 PM
Originally Posted by cblock406
Did you ever upgrade your battery to AGM? Im wondering if the hood will close with these terminals mounted on my XPower AGM deep cycle battery? any obstructions with these?
Any feedback is greatly appreciated
1999 4Runner SR5, 3.4L 5VZ-FE V6 | Tundra/890 coils | 5100 Bilsteins all around l 199mm Tundra brake upgrade | 265/75/16 Falken Wildpeak AT3 tires | ARB Bull Bar
