02-16-2021, 03:10 AM
4WD issues..
Hey all,
I went to use the 4WD the other day-but it didn't engage. I was able to physically get the Gear selector into position but still no 4WD.I was hearing the relay from the kick panel when i was shifting from 2H to 4H but still nothing.
Then after playing with it for about 25 min the Light came on and i was in business. I had fun in the snow for about 30 minutes never exceeding 35-40 MPH.. I then switched out of 4WD and back into 2WD and then back to 4WD still working.I switched it back to 2WD when i got home.
I went to use it the next day- Same thing shifter engaged no light and no 4WD. About 20 min went by shifter still engaged orange light popped on and the 4WD started to work. I know it might sound crazy but does the light actually dictate when it's supposed to work? Maybe the Fluid has to heat up or something? xfer case?
If anybody has any ideas. Please share.
Thanks.
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
02-16-2021, 03:39 AM
How long since activating? On my 5th gen, it was really a struggle to get in and out of 4wd when I first got it at 35,000 miles. Made sure to cycle it several times a month and now it engages and disengages quickly.
Also, old fluid may contribute to shifting issues.
Between outfits.
02-16-2021, 03:49 AM
Hey there,
I will have to admit...i dont exercise the 4wd as i should.. I was also thinking that might have a lot to do with it.
As for the fluid I'll bet it could use changing. it's going in for an oil change shortly.. i will have them look at it if i dont figure it out before then.
Thanks for the reply!
Currently 194K
Cheers
02-16-2021, 11:44 AM
Real Name: Patrick
Real Name: Patrick
What year is your 4Runner? Is it a limited trim?
02-16-2021, 11:57 AM
Originally Posted by giguchan
... does the light actually dictate when it's supposed to work? ...
No, the light only reports if the 4WD is engaged, it doesn’t cause anything.
Not sure what could be causing this though.
I would definitely check the fluid and do a drain & fill.
Just off the top of my head, I’d check the vacuum hoses near the 4WD VCV (under/near the evap system). Make sure those are holding vacuum consistently and are not torn or have little holes or cracks in them.
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
02-16-2021, 12:14 PM
Hey there,
There is a wire connector on the actuator underneath on the driver side . Sometimes the contacts get dirty. Spray it with electronics parts cleaner and see if it helps.
02-16-2021, 08:31 PM
It's a 97 SR5... No Limited here!!
Thanks Guys.. I'll have a look for that Wire Connector and also have the Fluid in the Xfer case Drain/ filled.. and check the Hoses too.
I'm going in for a oil change and a few other things also.. i'll add this on the list. Sooo.. Just so i am clear regardless if i hear the relay clicking or not
If i dont see the orange light... there isn't any 4WD.
Currently 194K
Cheers
02-16-2021, 09:09 PM
Correct. Unless there’s a problem with your sensor/indicator light. 🙂
On my truck (2000 SR5), I could hear the relay clicking, but had no 4WD indicator light, and no 4WD, despite my front propellor shaft locking up correctly. I found vacuum leaks in both hoses for the 4WD VCV. When I fixed those leaks, my indicator light worked and all four wheels were spinning again.
FWIW, my 4WD indicator light is green, not orange.
@Y2K_4X4
02-16-2021, 10:32 PM
Thank you,
I'll have a look at the Hoses.. it would be wonderful if it were this simple.
I'll report back.
*VCV stands for what?( i know i'm going to hate my self for asking.)
Currently 194K
Cheers
02-16-2021, 10:43 PM
Vacuum control valve
@Y2K_4X4
02-16-2021, 11:29 PM
Thank you
I had no idea..
Currently 194K
Cheers
02-16-2021, 11:45 PM
I was just watching a YT Video and HIS light was green also. Maybe i just had a Case of the stupid and mine is Green too.. dunno why i thought it was orange. after i get it fixed i'll know for sure.
Currently 194K
Cheers
02-16-2021, 11:53 PM
Good luck! And please post a follow up once you get it figured out. 👍
@Y2K_4X4
02-17-2021, 01:20 PM
Toyota normally calls them VSV = vacuum switching valve... but same thing.
On the '96-'00 non-Limited, the only actuator is the vacuum ADD actuator on the front diff. A switch on the transfer case activates the relay in the passenger footwell, which powers the VSV's to swap vacuum direction on the ADD actuator. When the ADD actuator moves, it hits a switch that turns on the dash light.
Since you hear the ADD relay working, the transfer case portion of the system is working. Check the ADD vacuum lines. Check the VSVs themselves. If 4WD *feels* engaged but the light is off, it could just be the indicator switch on the front diff.
Also, things could just be sticky due to non-use. The system should be actuated at least 1 a month. Toyota says 5-10 miles every month. Just pick a straight section of road and engage 4WD every so often. I just do a couple of side streets every month (put it in 4WD at a stop light/sign - then disengage next time I have to turn).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
02-18-2021, 12:34 AM
Thanks Guys...
I'm going to try to check myself before we get another snowfall. I had way too much fun the other day before this happened. It would be nice if i could get this fixed myself.
Currently 194K
Cheers
