Originally Posted by Mudeprived
My truck always started right as I turned the key to ignition. The longer crank time is very unusual. I never had a vehicle that didn't start right away. Even my 98 GMC k2500 with 210k miles starts right off the bat.
It happens almost every morning after it sat all night or when I leave work to go home. It rarely does it on a warm start.
Since then, I have just been turning key to ON after I open the door and wait a little bit and it starts normally every time. I don't mind doing this but not sure how long this will last.
Interesting. Sorry I can't be more help here.
I'll be watching to see what you end up figuring out, since my truck usually cranks for 1-2 seconds, and every once in a while in cold weather it won't start until the second attempt (always right away on the second attempt). This after new battery, fuel filter, Denso starter and starter relay, spark plugs, etc.
Based on what I've read on this forum, it seems like many people experience longer-than-expected crank times, but often those threads end up concluding "that's just the way it is."
Good luck!
