Old 01-16-2024, 07:05 PM #1
Mudhen459 Mudhen459 is offline
Mudhen459 is on a distinguished road
Replace Xfer case with one from a 1st Gen Taco?
Hey fellow 4Runner owners!
As the situation with trying to solve the transfer case shifting issues on my son's '01 SR5 continues to confound me, I'm starting to consider replacing it. I don't, however, want to replace with one that uses the electronic actuator. I have come to despise these things. My '17 Taco has them, and at 45K, I couldn't switch into 4WD two weeks ago when we had snow here in Denver. Very frustrating for a solution that's nothing more than added (in)convenience. I did notice looking at 1st Gen Tacos for sale in my area that it appears Toyota added the electronic shifting in the '04 Taco (last year of the 1st Gen), so I would try to avoid those).
I started thinking about the possibility of swapping the transfer case with one from a 1st Gen Taco that had the automatic gearbox. Not sure if the 3rd Gen 4Runner and 1st Gen Taco's shared the same automatic gearbox, so my concern is if the Taco's transfer case is a direct fit. Anyone have experience with this?
Electronics-wise, I would assume all of the same sensors exist to plug into the wiring harness; 2H, 4H, 4L, and neutral.
Any thought and suggestions are greatly appreciated.
Kindest regards,
Jonathan a.k.a. Mudhen459
Mudhen459 is offline   Reply With QuoteReply With Quote
Old 01-16-2024, 11:09 PM #2
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
I believe they're the same, but don't quote me on that
Regardless, the J-Shift is what you're looking for, and there should be plenty of threads around to help you, it's a common swap when the actuators die
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 01-16-2024, 11:16 PM #3
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
they r the same, my 02 4runner has an 04 taco trans in it right now. I have used a number of taco tcase's and trans in 4runners and vise-versa, there r a # of diff tcase/trans so they need to be the same type or u need to put the work into adapting to the diff model
clearock is offline   Reply With QuoteReply With Quote
Old 01-17-2024, 02:53 PM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
There's a few threads on the subject. It all depends on how factory you want the swap to operate.
2001 Multi-Mode to J-Shift Conversion?
Transfer case question (Swapping TO a j-shift from a pushbutton)
Multimode to J-Shift Transfercase Swap
Old 01-17-2024, 03:44 PM #5
Thanks for the feedback. I'm not too concerned about the factory configuration so long as the 4WD indicator lights aren't constantly blinking. I'll search for the threads on the swap.
Kindest regards,
Old 01-17-2024, 03:45 PM #6
Thanks Rodrick! I'll search for through the threads and find what's out there. Much appreciated.
Kindest regards,
1st , case , gen , taco , transfer
xfer case seals shot? sparkyy192 5th gen T4Rs 1 10-11-2022 10:18 PM
How to tell if a Xfer Case or Tranny is failing clt750 3rd gen T4Rs 8 07-19-2021 06:45 PM
front/rear diff's & xfer case oil firebirdguy 4th Gen T4Rs 15 05-04-2019 12:36 PM
Mysterious Oil Leak Near Xfer Case - '04 4WD antidentite 4th Gen T4Rs 1 05-14-2018 02:58 PM
FS: RCI Steel Skid Plates: Trans, Xfer Case, LCA guardsred944s For Sale: T4R Items 8 07-31-2016 03:55 PM
