Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 04-05-2021, 03:40 PM #1
TurkVU TurkVU is offline
Junior Member
TurkVU is on a distinguished road
Junior Member
Transmission replacement - options?
Hi all - I've had my 4runner for 21 years now, only 140k miles on it. Was driving down the freeway the other day and after some serious metallic grinding it just dropped out of gear and wouldn't go back. Got it towed to a transmission shop and they're saying the transmission is definitely done, but there's also metal in the transfer case, so that may or may not need to be replaced.
Wondering what my best options are & if it's even worth getting her running again. Not going to be able to do this job myself. I'm in Austin, TX if that makes a difference.
Dealerships in the area are quoting $3500+tax for a toyota remanufactured transmission (+$1k core charge). Transmission shop is saying they can drop and replace for $900. I found a salvage yard that is selling a used one w/ approx 140k miles on it for $600 w/ a 3 month warranty.
Currently leaning towards the used one and having the shop do the install...and then hoping the transfer case isn't the next domino.
TurkVU is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 04:21 PM #2
spartacus's Avatar
spartacus spartacus is offline
Senior Member
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
Senior Member
spartacus's Avatar
Salvage yard Transmission should work fine. Drain and fill the transfer case also.
spartacus is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 08:31 PM #3
3bears 3bears is offline
Senior Member
Location: north east of Fairbank out there in the frontiers Alaska
Real Name: 3 Bears
3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold
Senior Member
Real Name: 3 Bears
wait....i thought the transfer case and the tranny were basically 2 different units..they dont share fluids...then why if a tranny is bad and throwing metal shavings is it showing up in the transfer case.
scam ????
are you throwing any codes ?
super fine metal dust is common on the magnets.....maybe you just need shift solenoids , well forget that , you said you had grinding noise right?
A transmission shop you knew or one the towing company is friends with ?
2nd opinion ?
__________________
2000 SR-5 Highlander version 4:30's, factory locker , green, bought 6/21
2001 SR-5... bought 11/20..sold 6/21....
2000 SR-5 moded, lifted, e locker, other cool stuff, totaled 10/20
3bears is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 09:36 PM #4
tx_shooter's Avatar
tx_shooter tx_shooter is offline
Member
tx_shooter will become famous soon enough
Member
tx_shooter's Avatar
I had a pretty similar situation a couple years ago with my 4Runner. I had a complication in that my rig is supercharged so none of the aftermarket shops would warranty a reman transmission. I ended up going with a Toyota transmission from Ft Worth Toyota. Looking back it was expensive but the 1 year/ unlimited mileage warranty was worth it since the supercharger complicated it. The peace of mind now is still worth it.
Root question is how much longer to do you plan to keep the rig? Do you want confidence the problem is resolved the whole time?
tx_shooter is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 11:20 AM #5
nissanh nissanh is offline
Senior Member
nissanh has a spectacular aura about nissanh has a spectacular aura about nissanh has a spectacular aura about
Senior Member
I think you have a problem with the transfer case and not with the transmission. Even if it is manual, transmission and transfer case are TWO things and are NOT related. Nothing can get exchanged between the two, not even fluid.
__________________
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
nissanh is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 11:26 AM #6
Junior Member
Junior Member
I've actually brought it to 2 shops - the first is one I've been to many times and I trust. They said transmission - I then had it towed over to a transmission shop that the first shop works with often and they are the ones that said definitely transmission but also maybe transfer case. They didn't claim that one corrupted the other, just that there was metal in both.
I actually have a new vehicle ordered, but not likely to take delivery until sometime late this year...so basically I'm looking for fix that will get me through the next 6+ months. After that, I was hoping to keep my runner around, but she'll no longer be my daily driver.
Old 04-06-2021, 02:06 PM #7
gamefreakgc's Avatar
gamefreakgc gamefreakgc is offline
Elite Member
Real Name: Jerod
gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future
Elite Member
Real Name: Jerod
Salvage yards will often mark transmission as '2WD' or '4WD' versions. The '4WD' versions often will come with the transfer case attached so you're actually getting both.
__________________
'98 4Runner SR5 - 4x4 JDM 5VZ-FE Supercharged - 249K miles.
326WHP 347TQ
AEM F/IC 6, 11 PSI, 3" Intake and 3" Exhaust
Jerod's Supercharged T[u]RD Build
gamefreakgc is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 09:50 PM #8
Junior Member
Junior Member
Quote:
Really wishing I'd read this before I drove out there! The transmission did indeed have the transfer case attached, they said they'd remove the transfer case...but instead of saying 'no, it should come with it', I said 'no, how much more for the case'. Cost me an extra $200.
Old 05-15-2023, 09:36 PM #9
brillo_76's Avatar
brillo_76 brillo_76 is offline
Elite Member
Real Name: Jon
brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute brillo_76 has a reputation beyond repute
Elite Member
brillo_76's Avatar
Real Name: Jon
Yes, lots of videos oyr there for changing transmissions. I already changed an engine and transmission in one. It's not horrible it just takes time. I am sure you can do it.
Just make sure when changing the TC and transmission. That TC is fully in before putting the bell housing bolts in. Verify that the flex plate can move independently from the TC.
Sent from my SM-A536V using Tapatalk
__________________
7 3rd gens listed in the build thread (2 are parts mobiles)
Build Thread: https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer: https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information: https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
brillo_76 is offline   Reply With QuoteReply With Quote
Reply
Tags
metal , options , replaced , transmission , wondering
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Transmission options Clownmeat 3rd gen T4Rs 3 02-26-2017 12:37 PM
Transmission fluid options nicolasballia 3rd gen T4Rs 11 07-14-2013 08:59 PM
Transmission Options?!?!?! 92TXT4R Classic T4Rs 4 12-21-2009 12:28 AM
talk to me about transmission options onesojourner 3rd gen T4Rs 1 08-06-2007 07:58 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
