Old 05-07-2021, 11:46 PM #16
cas5259 cas5259 is offline
cas5259 is on a distinguished road
Originally Posted by gamefreakgc View Post
Holy rust Batman! That's a hole that I see where it's not supposed to be! I don't think your dust shield is going to last much longer.
Hah there is some rust in random places, but it’s mostly clean. 95% of that brown stuff is actually KY clay from the Kentucky Adventure Trail. Stuffs impossible to even pressure wash off.
cas5259 is offline   Reply With QuoteReply With Quote
Old 05-08-2021, 03:55 PM #17
Tundra Brake Fit Issue - resolved
Originally Posted by calimobber View Post
Sweet glad you got it figured out. Let me know how they feel? If the brake peddle gets softer or not. Seems some people have the issue and others dont.
softer longer push( feels like air in lines) but when it firms up its stronger.
Pedal feels fine. I’ve got speed bleeders all around, so that makes it an easy one person job. What’s weird though is that in the first few miles everything felt great, and then after that, light pulsing at low speed came back.
It was like that before, though, and I assumed my friend who doesn’t know about engine braking got the rotors/pads real hot on the mountains. Figured if I was gonna do the brakes, then it’s a good time for an upgrade. It’s really smooth under heavy braking, which is strange. Maybe it’s a booster issue or something, though I didn’t think the earlier ones (mines a ‘98) had a power booster?
Old 05-08-2021, 11:59 PM #18
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
no offense, but should ask if you bedded them. i followed @absalom 's procedure and they worked far better for me after that and one last bleed.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 05-09-2021, 11:15 PM #19
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I had the same thing. Bedding the brakes heavily got rid of it.
326WHP 347TQ
Old 05-10-2021, 02:46 PM #20
Yeah I bedded and bled properly. Don’t think it’s the fronts, though. Maybe it was the rears this whole time. I installed new drums/shoes/cylinder/hardware along with the wheel bearings and axle seals last year. Everything was fine for about 5k miles. I can increase the pulsing with the ebrake so it’s not the front.
Left drum is 350F after minimal braking. Right drum is 145F, so somethings going on. Bell cranks are free. I took it to the shop who turned the drums last year and they backed off the adjusters and said it was fine, no charge. It was fine for about 5 minutes, then it came back. It seems to only pulse when the brakes are warm. The first few minutes of driving are normal. Now I’m worried the heat has roasted the wheel bearing on that side - that job was a pita.
Old 05-10-2021, 05:15 PM #21
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Left drum is 350F after minimal braking. Right drum is 145F, so somethings going on. Bell cranks are free. I took it to the shop who turned the drums and they backed off the adjusters and said it was fine, no charge. It was fine for about 5 minutes, then it came back. It seems to only pulse when the brakes are warm. The first few minutes of driving are normal. Now I’m worried the heat has roasted the wheel bearing on that side - that job was a pita.
Your wheel bearing is probably fine. If you can try swapping the drums side to side and seeing if the high temps follow the drum. Is there any fluid/gear oil on the shoes?
Old 05-10-2021, 10:30 PM #22
No fluid in sight. Will swap drums tomorrow and report back. I disconnected the parking brake to each wheel earlier to no effect.
Is it possible for the auto adjusters to extend too far? I don’t know why this would be happening now, a full 5k miles after installing everything.
Old 05-11-2021, 06:58 PM #23
Swapped drums and had the same problem. Did notice that when the ebrake is pulled, the hot side bell crank lever extends all the way, but the cold side doesn’t. They’re not frozen or anything, I packed them with grease during the refresh.
Hot side ebrake pulled
Cold side ebrake pulled
Thoughts?
Old 05-13-2021, 11:55 AM #24
Real Name: Patrick
Real Name: Patrick
Thoughts?
Do you have any photos of the brake shoes right by the bell crank lever? I had a problem with the grease from my bell cranks dripping onto the drum/shoe once the brakes heated up enough.
Old 05-13-2021, 11:37 PM #25
No pics, but the shoes were dry.
Old 05-14-2021, 09:17 AM #26
Real Name: Patrick
Real Name: Patrick
I saw your other post where you swapped drums side to side and the vibration followed the drum. That tells me that the original side the drum was on (left side if I remember correctly) has a problem with getting too hot. I would bet that the adjuster is over adjusting. This could be due to a faulty adjuster assembly or incorrect setup. Have you compared the drum brake setup on both sides to see if there is any difference in setup. They should be mirror images of each other.
Old 05-14-2021, 10:20 PM #27
New drums seem to have solved it. Braking is smooth at any speed for now. Time will tell if there is over adjusting going on. I wonder if the last set of drums were so thin that they were able to get hot and possibly warp a bit.
back , bolts , calipers , thick , tundra
Spongy/Long travel Brake Pedal w/ Tundra brake upgrade 2002_thundercloud 3rd gen T4Rs 9 07-23-2023 10:07 PM
Tundra Brake Upgrade: Brake Pads Side Specific? trevo_man 3rd gen T4Rs 3 10-05-2016 11:45 PM
Did tundra brake upgrade and brake pedal mushy. 3rdgenfan 3rd gen T4Rs 5 10-25-2015 08:51 PM
Brake pedal low after Tundra Brake Upgrade ultimatt 3rd gen T4Rs 14 07-01-2015 05:12 PM
